Question about Breadman TR4000 Ultimate Dream Bread Maker
Problems starting a tr4000
Hi. We received our breadmaker yesterday. There are two problems. The machine will not let you program the internal clock. The time will program in, but once you hit the set button the time will not change accordingly, it is stuck on the original time you set it. It doesn't move. The second problem is when you start a bread program it will act like it is fine until you hit the start button. It will then have a wait sign, and will not start the motor to knead the bread. I waited for over 20 minutes and the motor will not start. I did the self test and the motor, heater, and other parts worked fine. I hope you can help. Thanks, Susanne
SOURCE:
SOURCE: Bread pan jumps off of its fastener clips.
I have the answer to the TR2500BC pan popping off the base!! My husband and I made a loaf for testing the jump off. Ah HAH! I set the pan in, ok. felt it was down all the way. When it started to knead the ball and stop to reverse...it popped off. We looked at the side hook on top. ok. It popped off again. It was when my husband made sure the two tabs on the under side of the pan was in the opposit direction of the two buds in the base. at that point you MUST set the pan down with force until you get that distinctive click, click. Rock the pan front to back a bit as you push down. It has worked every time since I started that process. I make two loafs of bread a week with no problem of it hopping off. ENJOY.
Posted on Jul 20, 2008
  • 25 Answers
SOURCE: I have a Breadman Ultmate
2 solutions 1st is the belt on the bottom eother slipped off or broke.\
Remove the bottom cover 2 screws have special screws.
You can get the security bit at harborfreight.com.
Then check the belt.
Also check to make sure the passle shaft is not frozen. See pther cure on how to do this.
The pan jumps either because the shaft is frozen or the side clips that hold the pan are not locking you must bend them to hold the pan if they are too tight the pan is hard to remove.
This to me is not as good as a design as the twist lock on other bread machines.
Posted on Jul 24, 2008
bobjrdns
  • 84 Answers
SOURCE: my breadmaker serial no is tr555lc
http://www.megaheart.com/pdf/breadman_op_manual_TR555.pdf
If any parts are missing or defective,
DO NOT return this product.
Please call our Consumer Service Department for assistance.
800-233-9054 Monday - Friday 8am - 5pm CST
Posted on Oct 23, 2008
Alleluia
  • 69 Answers
SOURCE: kneading blade stays in bread after cooking.
This sometimes happens. I have a Panasonic.
When you place contents in pan with some machines it is important to place contents
in a particular order. I should try to keep contents away from the kneading blade as you place them.
Another thing that might possibly help is to put a litter olive oil around the blade before adding ingredients.
Hope that this helps
Alleillia
Posted on Dec 02, 2008
SOURCE: unable to locate a bread paddle for my bread maker
Amazon.com has paddles, new and used.
Posted on Dec 29, 2008
Hello I need receipies for Bredman TR440SPR. Lost my book.
Recipes are interchangeable as long as you follow the recipes for the capacity of your machine. In other words you can't make a 2 pound loaf in a 1.5 pound capacity machine.
Jul 05, 2011 | Breadman TR4000 Ultimate Dream Bread Maker
I need a breadman bread maker tr4000 pan replacement.
Hi, you can get the replacement pan part for your breadman bread maker on this LINK.................
Apr 13, 2011 | Breadman TR4000 Ultimate Dream Bread Maker
My TR4000 machine is leaking liquids. The washers under the paddle are loose. I would like to purchase a new insert for my machine. Is this possible?
It is difficult to find such small parts or even find them. I recommend you just replace what is called the pan assembly which is the pan and parts under the pan, washers, pins, etc. already assembled for you. You just won't have the paddle so be sure to keep yours until your new pan assembly arrives..here is the site you can contact to order your parts. Best Wishes,
http://www.breadman.com/t-customer-care.aspx
Dec 16, 2010 | Breadman TR4000 Ultimate Dream Bread Maker
I need a replacement pan for a Breadman TR4000
here is the page from a supplier website that has your pan. If this helps please vote/rank/ or leave a testimonial....thanks!
http://www.vendio.com/stores/breadmakerguru/category/tr4000/catId=3449974
Nov 22, 2010 | Breadman TR4000 Ultimate Dream Bread Maker
Breadman tr4000 manual
here u go buddy:
http://www.breadmachinedigest.com/reviews/bread-machine-reviews/breadman-tr-4000.php
Aug 30, 2009 | Breadman TR4000 Ultimate Dream Bread Maker
What number is the pizza dough cycle on a Breadman bread machine?
It may depend on your model. On the TR900s, it's 12. What model do you have?
Jan 02, 2009 | Breadman TR4000 Ultimate Dream Bread Maker
BreadMan TR440SPR
Hi you need to contact Salton who make it
Salton, Inc.
3633 Flamingo Road
Miramar, Florida 33027
Phone 954.883.1000
Oct 25, 2007 | Breadman TR4000 Ultimate Dream Bread Maker
Breadman TR4000 Ultimate Dream Bread Maker Logo
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
Steve Allison
Steve Allison
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
