Question about HP Pavilion F1703 17" LCD Monitor
HP LCD Monitor w1907 Blowing fuse - no display
Have disassembled screen, found blown fuse (ceramic time delay fuse) not just blown, but blew ceramic apart, too! Have replaced fuse, only to power back up and hear little 'puff' - blown immediately again (didn't even get chance to press the power switch). Obviously this is a dead short somewhere, but need some kind of guidance so as to test circuit - if anyone can help.
Thanks in advance
  • fixya919 Dec 01, 2008
    Fix-4U:
    The scren is out of warranty - 18 months old! Typical. eh!
    Blue ESR Meter sounds interesting, will look into that. Thanks for tip.
    Kim_Cu:
    1. No visible damage I can see.
    2. It's a 240V and definitely is 240V from 5KVA UPS
    3. Nothings seems out of ordinary here.
    4. Never had a chance to SEE it running - just acquired it. No fan, I was a little concerned about the rectifier circuit, but do not know how to isolate and test without removal of many components..
    5. Yes, I've heard this - how do I identify a filter capacitor?
    1. No assumptions here - all checked out.
    2. ??
    Thanks for good suggestions guys.
    So far we can only determine it is shorting somewhere - a capcitor sounds good, but I didn't want to remove all the capacitors from the board to be able to isolate them, does this ESR meter allow one to test whilst in circuit?
    Cheers
  • Bob Morris
    Bob Morris May 11, 2010
    fixya919:
    Is your monitor less than one year old? If it is, contact HP and have the whole unit replaced under warranty. Just a thought.
    Binary Bob
    Champion:
  • 293 Answers
Sure, you can testing it both ways... in-circuit or out.
Posted on Dec 01, 2008
    Champion:
  • 293 Answers
HEY...919,
Are you sure you replaced with the right voltage or installed backward... What you need is a good meter...I recommended you get the Blue ESR/Low Ohms Meter by Ana Tek Corp.
Posted on Nov 29, 2008
    Novelist:
    Scholar:
  • 70 Answers
1. Visual inspection of the board, wires, etc. for short (expect you have already done this)
2. Start at the source. Need a meter to test voltage coming into the system (is it really 110VAC?)
3. Then the obvious, which is not so obvious or you would have fixed it by now. Need a meter to test components. Test switch. Maybe the power swtich is shorted!? Test all other components one at a time. Including all the wires. Do any of them feel stiff or look like the insulation might have melted a bit? Might need to remove wires to isolate components to test.
4. Since the power switch is not part of the problem then it is before the switch. When it was working, did anything run while the power was off? yellow LED? fan? Components like power diodes, bridges and rectifiers are typically blown by now also.
5. A filter capacitor, usually large, when shorted internally, can be the problem. Only test for short. Must remove one lead, watch polarity.
6. You can only blow so many fuses before the real problem, which the fuse is protecting, will appear...usually a disasterous end. I blew up a power supply to a washing machine after the third fuse. It fried the whole board with a very loud pop, bright flash and fragments of shrapnel flying everywhere. Please be careful!
Troubleshooters rules:
1. When you can't find the problem you are looking in the wrong place. Look somewhere else. Suspect everything, even the smallest detail is often the real problem. Like, what have you ruled out? Did you already assume the switch was good, the wire from the wall was good, the outlet was good, the power was good?
2. When you don't know what else to do, do something. Deliberately break something to see what will happen. (This is not a rule that I would use in this case but might serve you well in troubleshooting other problems in the future.)
  • Kim Parker
    Kim Parker Dec 01, 2008
    ok...good start...elimination of possible problems. The ESR meter seems to be ok but, as the documentation states: "...it's quite useless for identifying leaky and short-circuited capacitors; that's what the resistance ranges of normal multimeters are for! ".
    A filter capacitor is electrolytic and can be identified by a cylindrical shape. Typically the largest cylindrical shape on the board. Typically "radial" (standing up on the board with the leads through the board and soldered on the rear). The capacitor will have a very large minus sign and stripe down one side. If it is soldered to the board and is "radial" (laying flat on the board with the leads coming out both ends) then you might not see the stripe - it will be underneath the cap and the board.
    It will also be very large in size...typically 1000, 2000, 4000 or even 6000mfd (or ufd - actually "mu"fd) if you can read the numbers printed on it.
    Test: using the meter on ohms, touch both leads while it is in the board. If the meter reads "0" ohms then it is probably shorted. Reverse the leads and test again...another 0? Shorted. Otherwise you will need the Equivalent Series Resistance (ESR) tester. From the description of your problem, a cap is shorted. Ordinarily there will be one large one for the major power and smaller ones for each of the output voltages needed for the system.
    Good luck.
Ii have one hp w1907 lcd monitor. It will work few second and goes black screen When the lcd on .again i off and on the screen goes black at this time.
may be this is you are mentioning there is no display in your monitor or u have already getting the boot display. if u getting the boot display it must be the problem of your monitor inverter board in side ur lcd. otherwise it must have your computer memory not working properly so u must clean and re install your memory first.thank you.
Sep 07, 2011 | HP Computers & Internet
Upper section of my HP w1907 LCD computer monitor is faint. How to fix it?
From the sound of it, you most likely have a blown CCFL bulb in your monitor (there is one on the top and one at the bottom).
You can either buy new bulbs for it and try to replace them (risky and difficult without experience as I had found) or you will need to buy a new monitor.
It is a common problem with them unfortunately.
May 11, 2011 | HP w1907 LCD Monitor
Monitor will come on, monitor status box will come on and then screen goes blank. How can I fix this?
rwhite97, If your pc is working fine with substitute monitor, and w1907 lcd unit does same (black screen, or blanknblack screen) when connected to a "known good" pc, then you should visit and read some stuff at this 2005 blog. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Then learn the flashlight test and what it means. Then go to YOUTUBE for video clips on lcd monitor disassembly and lcd monitor repair if you are into do-it-yourself repair. Remember this!!! Your w1907 unit uses the same basic design and operation principles that ALL brands of ccfl back-lit lcd monitors use. Good luck with the repair. Come back here and leave comment after doing your research/investigation and then rate this response. 12fixlouie
Jul 16, 2010 | HP w1907 LCD Monitor
Hp w1907 monitor stays on for a second when turn computer and then screen goes black; have turned on and off; reconected cables and turn on and off. Power light is blue and then turns orange.
It acts like it is not getting signal from the video card or it goes into shutdown mode to protect itself.
Try it on another PC first, if it still does not work then you will need to open iy up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | HP w1907 LCD Monitor
HP monitor w1907 lcd switches off to standby.
your hp monitor has an electronic component problem inside, probably some busted capacitors or ccfl lamps that failed to light...best is to bring the unit to a qualified LCD repair center near you..
May 09, 2010 | HP w1907 LCD Monitor
Hp w1907 has white screen in vga and dvi-changed computers doing same thing-tried another monitor and it works on both computers
The all white screen indicates loss of 5 VDC to the LCD panel. Either the connector is not plugged in good or (more likely) the panel itself had failed. They can develop a short that blows the 5 V fuse on the panel. Replacing the fuse normally does not fix the problem.
Monitor Mike
Apr 30, 2010 | HP w1907 LCD Monitor
Monitor Hp w1907 has no input signal, how do I get connected and keep it from going to sleep
If you set the PC to go to sleep after certian amount of time than it will not put out signal to the monitor. You need to go to display properties (right click on the desk top)/screen saver -power/set the display to never turn off.
Nov 30, 2009 | HP w1907 LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
443 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
