Question about Teac AG-D8900 Receiver
Power comes on but speakers do not make noise
I have a Teac AG-D8900. Last week as I was hooking up speakers, with the power to the unit on. (I know ?idiot?) Everything was gonig great unil something hit the wrong thing and now no sound. Is there a fuse that went?
Hey! If your speakers work when you run the automatic setup for channel control and balance (FL, FC, FR, RL, RR and subwoofer) the the culpret is probably a button on the front panel (to the left of the volume know called "Digital Input". With a component on and running an audio signal, push that button until it cycles through the list of available inputs. You may find that this will fix the problem.
This has happend to me a couple of times, when one of the kids has accidentally pushed the Digital Input button while plugging in an aux source.
Hope this helps.
Posted on Jan 09, 2008
    Problem Solver:
  • 8 Answers
Stereo Tech: yes their is a fuse inside that possibly opened, but does the unit show PROTECT across the display? if not you may have goten lucky and just did a fuse small PC board just behind the transformer. Good Luck
Can I hook a turntable to a Teac AG-D8900. Where do I input?
only if the unit has a PHONO input never plug a turntable into any other jack as teh voltage is different.
I have seen an adapter so that you can plug a turntable into an ordinary input I believe Radio Shack but that was along time ago try ebay
Jan 08, 2010 | Teac AG-D8900 Receiver
Teac AG D8900 II sub woofer not working
click on the blue "teac sub woofer" link top of page, solution is in my response to another with same problem-that is at least 3 of us with this now.
JS
Dec 26, 2008 | Teac AG-D8900 Receiver
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
Jul 30, 2008 | Teac AG-D8900 Receiver
Connecting An Equalizer
you will need 6 equalizers or 3 stereo equalizers.
connect the 5.1 analogue outputs of your media player (DVD Player) to the equalizer and then connect the analogue output of the equalizer to the AVR.
now you can equaize the sound for extra boost and cut.
Warning: it is not recomended to do so unless you have a powerful amp and high quality and higher wattage speakers, as equalizers are ment to be used mainly for entertianment zones and outdoors in professional applications.
the home speakers annd electronics are not really capable of taking such electronic stress as they are designed to work indoors in a confined space.
but if you are confident go ahed.
Jan 21, 2008 | Teac AG-D8900 Receiver
Problem
please check for any short circuit at the binding post speaker output of the amplifier and also at the speaker inputs.
if all seems to be ok also check the + and -- at the speaker and amp
if this is also ok then it could be an internal problem which could be only solved in a service center by a qualified service personnel.
Jan 13, 2008 | Teac AG-D8900 Receiver
NO SOUND
Check speaker terminal connections, then source input, then surround mode choice.
Dec 12, 2007 | Teac AG-D8900 Receiver
Teac AG- D8900
Stereo Tech: Check speaker switch(A or B) also be sure you have selected FM, AM, Video, CD ect., somtimes if you do not have a stereo signal the unit will mute best to fist try tape or CD input. Hope I helped good luck.
Nov 27, 2007 | Teac AG-D8900 Receiver
Teac AG-D8900 Receiver - No power
Hello meml,
Since you mention that there is no standby light at all, the problem could be related to the receiver's main power supply, which is not uncommon for a unit of this age.
Now, if you decide to take the unit to a repair shop, do not let the cost of repairing the unit be the only factor that determines if you bring it back to life or to use it as a door stop.
Consider the replacement cost compared to the repair cost, also, have in mind that newer receivers can supply more output power per channel and have more advanced decoding technologies among other features. Hope this helps your decision. Let me know.
cancerags.
Apr 11, 2007 | Teac AG-D8900 Receiver
Setting Up The System
You can find the requested details at: http://www.teac.com.au/file/product_manual_408.pdf
Mar 09, 2006 | Teac AG-D8900 Receiver
Teac AG-D8900 Receiver Logo
277 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
