Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Kp-51w5510 convergence intermitten
I am having a convergence problem . i pulled the back off and taped in the area i thought was the convergence board and the problem cleared up. now it is back agian. i have been a tv repair person for over 16 years but haven't worked on any sence 1990 . I have found that these types of problems are usually a loose connection as a solder joint broken circuit board plugs and pins have come loose by just heat and cool over time and then you can find just a broken wire w insulation still intact. the set in question is not mine but my daughters inlaws. Can you direct me to where to look for the convergence board or circuitry that controls the convergence. or where i can get a sams for this tv.
  • Sony Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from
Posted on May 15, 2010
Sony kp-51w5510 colors are bowed down
Thats almost always a convergence circuit failure. Installing a convergence repair kit should solve the issue. Your model uses the Sony #1 convergence kit whichh comes with the parts and the CD with repair instructions and its available at the following link.
Apr 02, 2013 | Hitachi 53UDX10B 53" Rear Projection...
Our 7 year old Sony TV KP-51W5510 has the following problem. Picture has 2 colors, writting has 2 colors the skin tone has 2 colors, writting on the screen will show 2 colors black and red in shadows pls...
a ladha,
You have lost the convergence circuitry. I have a tip at which will explain the problem, tell you where to get parts and explain how to do the repair.
Thanks for using FixYa and for the great rating!!
Sep 12, 2010 | Sony KP-51WS510 51" Rear Projection...
I have a 7 year old Sony KP-51W5510 rear projection tv. The right side is all yellow and the left is all blue. In the middle the colors line up but gets worse towards the left and right. My convergence...
No.This problems it not the projection lamp problems.Yes,this problems is the tv convergence board problems,it dead.The tv convergence board the 2 STK covergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the convergence problems.U have tools like a soldering iron,desordering pump,know basic electronic and soldering?Tries websites like, to buy a convergence kit to repair it ur self.Or the shop will cost u $300-350 for parts and labors.
Sep 04, 2010 | Sony KP-51WS510 51" Rear Projection...
My tv is displaying a double picture.. i pulled the back off and covered the red lamp and the picture goes back to normal but no red in the colors.. pull my hand off the red lamp the picture doubles...
Problem cause is red convergence output chip failure that will be replaced to fix the issue.
If you have experience of electronics stuff repair and can replace parts in circuit board as it requires soldering work with proper tools then can replace convergence output IC in your tv by yourself.
Let me know if you have additional question.
May 03, 2010 | Sony KP-51HW40 51" Rear Projection...
Green projection light not alligning with red and blue. Flash focus will not bring them back. Sony Rear Projection KP-48S70
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
Note:The convergence/defletion/power board (the one the IC's are on) of this model is on the left hand side (when facing the back of set) also check for blown pico fuses when replacing the convergence IC's The best way to replace the IC's resistors and possibly fuses is to remove the entire board.
Oct 19, 2009 | Sony KP-48S70 48" Rear Projection...
Blue converence was intermitten now out on sides
If the IC's say have STK printed on them, then they are the convergence IC' s. should be three of them, replace all 3 , and the burned green coils, sometimes these burn as they supply the volts to the STK's. good luck, be safe..
Mar 11, 2009 | Sony KP-61V45 61" Rear Projection...
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony KP 51WS510 convergence problem
Please check pico fuses in D board and confirm +22 & -22 volt supply to convergence ICs.
Fuse numbers are as follows...
PS8001, PS8002, PS8003, PS8004, PS8005, PS8006
Dec 21, 2008 | Sony KP-51WS510 51" Rear Projection...
it could be either convergence or the velocity boards. Are you able to move the red and blue convergence in all four direcctions with the convergence adjustments?
Jul 12, 2008 | Sony KP-61XBR48 61" Rear Projection...
Convergence IC replacement
some have plastic clips that need to be pressed back to release the board. There should also be 6 screws holding the D board to its frame.
Jun 21, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
127 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
