Question about RCA 20F420T 20" TV
Tv won't work
I have a older RCA tv with guide plus. When I try to bring up the menu for my VCR on the TV to set a program , the screen says unusable signal. What does this mean? How can I fix it? I can play a tape and fast forward and rewind. There does not seem to be anything wrong with the remote. Hope you can help. Phyllis Reed
  • Daniel Martinez
    Daniel Martinez May 11, 2010
    to add to what MEDIARICH said..............
    You are no longer receiving the signal that you use to receive..
    BUT!! you said....""bring up the menu for my VCR on the TV to set a program ""; does that mean that you are trying to use the VCR programing, NOT the TV programing? For instance...are you trying to use OSD [on screen display]?? and can't. are you trying to use the VCR program timer to set a program record time???
    Other then that mr. MEDIARICH is right with the analog siginal to digital signal...
    p.s. I have the same RCA TV with GUIDE PLUS and I love or loved it until I lost the GUIDE PLUS function...
    Scholar:
  • 188 Answers
I downloaded this off of Wikipedia. You are not the only person having the problem with the switch to digital television. The complaints are nationwide. the old TV Guide Plus has gone away for many viewers and soon for all viewers as the transition to DTV gets nearer. If you are using an antenna be sure to get the digital converter. They are practically free with a government sponsored coupon.
Digital television
The new service, launched in the United States in 2006, is entirely digital, using the ATSC digital television standard. While this will significantly improve the service, older systems will no longer be able to download listings once analog shutdown is done in early 2009.
It should be noted that the Program and System Information Protocol (PSIP) within the ATSC standard already allows for each station to send out its own EPG information, and in the U.S. the FCC in fact requires stations to do so for OTA (but not cable, unless they are rebroadcasting an OTA station that provides the PSIP data). However, actual implementation is rather spotty, and usually very minimal -- stations often don't have full descriptions (or even correct information) on the current show, much less the next 3 hours required of them, or the 16 days worth of guide information that can be transmitted. Additionally, ATSC tuners are not required to even show the EPG, only the very limited information for the current show on the current channel.
While the TV Guide service also requires software in the TV or other device, and licensing fees or royalties to be paid to Gemstar TV Guide, it also offers a more complete solution for broadcast television, more like digital satellite or digital cable.
Posted on Nov 29, 2008
Menu keeps popping up
If you have the guide plus feature go into the setup for it and when it asks if you have a cable box, indicate no, when it asks if you have a Vcr also indicate no. Last if it asks for the zip code enter all 9, This should rule the Guide feature out of service and you will know if it is your problem or not---it created a lot of problems in sets that had it, especially RCA or GE sets.
Dec 20, 2012 | RCA F36650 36" TV
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Rca guide plus gold 32'
pull the ac plug for about 5 min and start your set up again paying atention to the features you want and don;t.set the menu to suite your requirements.
Jan 16, 2008 | RCA 32F531T 32" TV
Rca tv f27628
http://sci.tech-archive.net/Archive/sci.electronics.repair/2006-12/msg01203.html
Turn on the TV
using original remote:
Bring up TV Main Menu and select option 7 (TV Guide Plus Menu)
Select option 1 (TV Guide Plus Setup)
Find the MENU, GO BACK and Input button on your remote
Press the MENU Button then immediately:
Press the GO BACK button then immediately:
Press the INPUT button.
Note: It is important to press the Menu, Go Back and Input buttons quickly (within a second of each other)
Nov 11, 2007 | RCA F27628 27" TV
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
RCA 20F420T 20" TV Logo
250 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
