Question about Pioneer VSX-516-K
Connections I am having problems connecting devices. This is my first receiver for a home theatre and I am struggling. I have a Sony 51 wide screen HD projection televison, model kp-51ws500, a toshiba SD-4980su hdmi dvd player, a Sony slv-n51 hi-fi vcr and a pioneer hd cable box provided by time warner. can you help me with the best way to connect. I would like to use the receiver as a monitor and have all video and audio running throught the receiver, except the video for the dvd and hd video for the tv.
4 Suggested Answers
SOURCE:
SOURCE: No Video
have you gone through the menu to assign which signals the receiver recognizes?  I had to change the source when i switched to the Dish Network HD receiver.
Posted on Dec 13, 2007
SOURCE: Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Posted on Mar 29, 2008
SOURCE: no sound from speakers after connecting to pioneer a/v vsx81
I had the same problem and resolved it last night. You'll also need to connect an audio cable (EVENTHOUGH YOU SHOULDN'T HAVE TO - to bad pioneer didn't fully implement the HDMI standard in this receiver) solution. I suggest using an Optical cable. This really annoyed me...see the manual on P.17 section #3.
Posted on Jan 03, 2009
How do I attach sony w60b to sonny DAV-HDZ 284 DVD Home Theatre System?
You can use the Component Video, composite video or HDMI connections to connect the DVD home theatre system to the TV.
See the manuals on this site.
DVD Home Theater System
Sep 15, 2014 | Sony BRAVIA Televison & Video
Sony Home Theatre System Turning Off
Appears that you have a bad cap in the power supply that is changing value as it heats up. Hard to find - only thing you can do is go to suspected units and replace them hoping that you got the bad one. Or just wait till it finally pops.
Apr 02, 2017 | Sony Home Theater: DAV-DZ870W ALL REGION...
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
Lots of components , need proper hook-up
I reccomend a Denon AVR-2809. It had 4 HDMI inputs, all 1.3a and higher, and one HDMI out for your TV!
Jan 07, 2009 | Audio Players & Recorders
Wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
Connecting a sony blu ray 350 to denon 1601/ home theatre
Yes select audio optical out on your Blu Ray Player under Audio settings and make sure the Denon is set to Optical or Auto in. You should be set to go
Sep 27, 2008 | Denon AVR-1601 Receiver
TV Ears
if you have a satellite receiver or cable converter box get the sound there and put into home theatre.... my sony has blown audio amp and this works for me retired santa
Mar 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Pioneer VSX-516-K Logo
46 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
