Question about HP Office Equipment & Supplies
I bought a second hand computer and have used the printer before and never had any problems with it; now the paper has jammed in it and I can't get all the paper out of it. It's a HP photosmart C4180 All-in-one printer. Help, I don't know how to get the paper out
  • 903 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00651302&dlc=en&lc=en&jumpid=reg_R1002_USEN
Go here and read info and watch a video on clearing the paper jam.
I hope this helps
Posted on Nov 28, 2008
Hp 5550 fuser jam
Paper sticking in the fuser is usually a sign of the fuser needing replaced.
Mar 27, 2013 | HP Color LaserJet 5550hdn Printer
Paper jam
Hi Ruth,
This should help you fix the issue.
Remove Jammed Paper
If business card sized paper loaded sideways is jammed:
1. Power the printer off.
2. Open the top cover.
3. Remove the jammed paper with your hands.
Note: Be careful not dirty your hands. Do not use tweezers or other metal instruments to remove the jammed paper or printer damage may occur.
4. Close the top cover and power on the printer
5. Load the papr correctly in portrait orientation to resume printing.
remove foreign objects
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once.
The images below show the iP2200 model.
2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. If there is any foreign material, remove it by hand or with tweezers.
3. Open the front cover and confirm that there is not any foreign material in the printer. If there is any foreign material, remove it by hand or with tweezers.
Note: Avoid touching inner parts.
4. Power the printer on and confirm that the printer operate normally.
Use a flashlight to find any possible jam.
Regards,Suhail
May 19, 2012 | Canon iP2600 series
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
A paper is jammed in my printer and although it gives directions to open cartridge 1 and then take out paper cartridge then remove jam, I cant see any paper jammed, but I did hear it jam when it happened....
in right side of the printer one green color lock is there pull that luck ......paper feed unit will come out there you can see the paper ......
if you want manul send me your mail id anantakumarjena0@gmil.com
Nov 02, 2009 | Kyocera Mita FS 1900 Laser Printer
Paper light blinking, paper tray full, won't print
hi,
i recently bought a second hand hl-5140 and when switched on had the fault you have described - on checking machine over i found a small piece of torn paper stuck in the paperpath. after clearing, the printer worked fine.check over for paper again as mine was only a very small peice.
hope this has been of help.
pete
Sep 04, 2009 | Brother HL 5140 Laser Printer
5110 ERROR ON PIXMA PRO 9000
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Solution: Removing paper jams MP800R / MP830 / MP530
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
  1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
  2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
  1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note: Be careful not to touch the components inside the printer.
  2. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  3. Load paper back into the ASF.
  4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
  3. Open the rear cover to check if the paper is jammed.
  4. Pull out the cassette and check if the paper is jammed inside the cassette area.
  5. Stand the printer with the rear side down, holding the document cover.
  6. Press the tabs together and pull the green cover toward you.
  7. Check if the paper is jammed.
    (If you were not doing Duplex printing, you do not have to follow this procedure.)
  8. Close the green cover and place the printer back to a normal position.
  9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  10. Load paper back into the ASF or cassette.
  11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
We are suddenly experiencing 2 problems. First,
The fuser needs to be replaced, it is causing your smears and the wrinkling/jamming problem.
Apr 28, 2009 | Lexmark T430 Laser Printer
Paper jam
there is a sensor which detects if there is a paper jam in the printer.that sensor is bit moved from its orignal position so it is continuously detecting the paper jam in your case.
Oct 06, 2008 | HP DeskJet F380 All-In-One Printer
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
22 people viewed this question
Seeker5211
Seeker5211
