Question about ASUS A8N-E Motherboard
Bios problem, i guess
For some time my computer freezes and only thing i can do is manual restart. But, few days ago, even that didnt help. Now i cant power up my comp. When i start only i can see is black screen and no sounds that something is wrong. I did clrcmos and manage to start comp but when i turned off next time i wanted to start up same problem happened. I tried with other memory, power supply, graphic card.
Current configuration: Asus A8N-E, AMD Athlon64 3200+, ATI HD2400, 1GB Ram Apacer, Maxtor 80GB HDD
  • amroth22 Nov 28, 2008
    I already done this, but only with vacuum cleaner. I'll also try what you sugest and let you know if there is any use. Thanks.
  • 30 Answers
Your problem is very common with old computer.
The reason might be humidity or dust.
Please consider taking your m/b out of the case and the rest of the components (like video card and memory simms) and with a brush dipped in alcohol clean the whole m/b everywhere you can (both sides) scrub it hard especially places you see dust or rust.
I use it all the time although I have to say you need to do it at your own risk.
Good luck and thank you for using agadycom.
Posted on Nov 28, 2008
Alienware m17x r3 random freeze lockup have to hard reset
More details please. Description is too vague.
Jun 06, 2017 | Computers & Internet
My HP netbook keeps freezing. I don't know whether its due to overheating. But everytime when it freezes, its very hot. Another problem is, when i shut down my netbook, it always restarts by itself....
Hi xinyi pang17,
I have heard of this problem many times and it is usually due to overheating and motherboard problem. But first thing that you need to check is if the fan is working properly or not. You can use a canned air to blow out dust and accumulated particles from the fan.
However, freezing may also be caused by faulty processor. The unit may freeze (and overheat) while booting up, while using the computer or before the operating system loads if the processor is failing. To verify if the processor is failing, just access the BIOS (Basic Input/Output System) setup and test if it will overheat from there. If it does, surely the processor and/or motherboard needs to be replaced.
Hope this helps.
Jun 10, 2011 | HP Mini 1000 Netbook
I installed my deep freeze software in my laptop.now i forgot that password. so really i cant store anything in my laptop.
Hi!
Sorry I was unable to provide you exact help on this one as I don't know the deep freeze version you are using but you may want to try these steps, if it doesn't work out, please coordinate with us with the version of the deep freeze.
For Deep Freeze Enterprise:
  1. Open the Deep Freeze login dialog on the workstation for which you need to generate the OTP.
  2. Write down the Token code which is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered):
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options available to assist you.
Or if you may want, you can also back up all your files then reformat the computer. Thanks for reading my suggestions.
Hope this helps even a bit.
Apr 17, 2011 | Computers & Internet
Hi i have i minor problem: my pc reported this issue: chasiss intruded system halted , i restarted my pc and system booted normaly . this is the second time it reported this error, it reported this 5 days...
you need to enter your bios and change the setting for chassis intrusion to disabled
you can enter the bios by pressing del or f2 when you switch the pc on
if this info helped you please vote
Feb 26, 2011 | Computers & Internet
My pc was working fine with 128 + 256 ram. few days ago it didnt boot.it was restarting automatically. then i removed 256 ram and it booted normally.means pc works normally with 128 ram but not with 256...
i guess u have 2 different RAM cards in the RAM slots....
the main issue is both dont work together...the primary reason is compatibility....or one of the RAM cards have worn out...
u must use exactly similar kind of RAMs in both slots....
i suggest u use one 512 MB if your motherboard supports....
RAM technology has advanced so mush that you wont get RAMs for old PCs (motherboards)....so u decide...
pls revert back...and kindly leave a feedback and rating for this solution...it will help me move to Guru" here from Expert at Fixya....
regards...
Sep 29, 2010 | Gigabyte GA-8I845GV Motherboard
Dell laptop won't restart. No lights coming on. No power when hooked up to AC outlet with battery in it. What do I do? It did the same thing a few days ago,then I removed the battery,pluged it in and it...
if no sing of power when you plug in i would check AC adapter if is there voltage on it,
adapter plug could be interrupt conection (if yes you should change it)
- try to run it without battery
if it not battery or adapter problem i would go to restart BIOS setting to default, (when u finnally run computer) press F2 or esc when u turning on computer it will turn u to bios.
Hope it help
Mar 02, 2010 | Computers & Internet
No video displayed after updating bios
Yes, it is true and common. Anytime you update bios, also find the method for resetting/undoing the bios update.
go to the mobo mfg website and find how to reset the bios. This usually involves removing the battery, and jumpering the reset.
The reset may not reset/undo the update, but simply reset the bios to defaults.
Depending on the bios type the restore may vary.
Jan 24, 2010 | Computers & Internet
Hello my computer was working properly but when i started it few days ago it shows "password have been cleared. place back the clear password switch to its original position then restart your pc. boot...
Hello there smohsin_p574.
Here's your geek-steer ...
Let me guess ...
You have just recently (or at least prior to this latest bootup attempt) performed a mechanical reset of the BIOS/CMOS password by either removing the motherboard battery, or (more likely) manipulating the JBAT reset jumper from pin position 1-2 to 2-3 ... right? Furthermore, you did this of course to reset a forgotten/lost password ... right?
If so, don't get out the panic button, you simply forgot to REPLACE the jumper back into the original 1-2 pin position. Don't feel bad ... it could happen to anyone, even me :)
Now read that message you computer is telling you ... makes much more sense now doesn't it?
I gotta know if I'm right on this one, so PLEASE do post back EITHER WAY ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 11, 2009 | Intel Motherboard
IBM R40 - 2897...not resonding
disconnect any power remove battery .remove mem and check the mem slots for dust and debris replace mem.remove hd check connections(hd pins)check connecter for dust.refit ;make sure properly housed.reboot,enter bios.reset to default.save settings and exit.pc should now restart.any indications of fault maybe mentioned at startup if not window should boot
Mar 04, 2008 | IBM ThinkPad R40 2897 Notebook
ASUS A8N-E Motherboard Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
