Question about Philips 32PF7320A 32 in. LCD Television
Philips 32PF7320A black screen
I've had my Philips 32 in LCD TV for quite some time now and recently started to experience a strange problem, after about 20 minutes of watching TV it goes to this black screen of death exactly like this one posted on YouTube. Then it comes back and intermittently back and forth. http://www.youtube.com/watch?v=VAW7BoV4PRI Anyone have any clues as to what might be causing it and how it could be fixed.. Thanks
  • 1 more comment
  • Goodluckruck Jan 24, 2008
    Black Screen Problem: Sounds like I may have the same problem, although I haven't seen the YouTube you referenced......(I also posted a question on this site to ask if a download would fix it.) I've read you can download "updates" directly into your TV via the USB connection. Have you tried that?
  • wattzat Feb 24, 2008
    Have the same problem with tv purchased in December 2008. Anyone have a fix - we are remote and no service agents within 100km
  • Anonymous Mar 25, 2014
    Recently ordered a movie from Mgo,started watching it & screen started chopping up.Went back to restart movie and wasn't able to bring up Roku on TV. Roku device installed new 1/2013.
    Joe Buchheit
    Code: TRNSZ
    joe@joebuchheit.com
Upgrad the firmware in the TV. This problem was resloved by philips with the software fix. you can locate the firmware on philips.com. good luck!
Posted on May 25, 2007
    Sergeant:
  • 308 Answers
If the power lamp is flashing 5 times when it does this, you may need a new power supply. Otherwise, I would suspect a bad (solder) connection in the power supply.
Posted on Jan 14, 2007
My t.v was on and my daughter threw a stick of deoderant and it hit the screen and the t.v. shut off and it will not come back on...Is my t.v. broke? Can it be fixed if not?
Tv LCD Screen panel now is crack or broken?Yes,tv can't be repair only can be replacing the LCD screen panel itself.Sorry tv now only worth as a salvage tv only for it electronic boards for parts,that it.Because tv will cost the same as a new tv,if tv require a new LCD screen panel.
Feb 25, 2011 | Philips 32PF7320A 32 in. LCD Television
Philips 32PFL5332D 32 won't power up.
U have a LED green light indicator on the LCD panel blinking?Yes,the tv is worth fixing.The power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.The average price of a refurbish power supply board is between $100-$120 plus shipping.
May 06, 2010 | Philips 32PFL5332D 32 in. LCD Television
My Phillips Plasma tv MENU pops up unasked and obscures screen.
there is a soft ware upgrade for that problem on there web site you can down load it to a thumb drive and upgrade your set
Oct 31, 2009 | Philips 32PF7320A 32 in. LCD Television
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
My Philips flat screen tv model 37PFL5332D/37 will not come on...what should I do to reset my tv
The only way to reset it is to leave it unplugged for 24 hours. If resetting it doesn't help let it turn on, you may have to replace the power supply
Jul 09, 2009 | Philips 32PF7320A 32 in. LCD Television
My 37" LCD Philips TV has mind on its own.
your internal controller board is going bad in lcd
Jan 19, 2009 | Philips 32PF7320A 32 in. LCD Television
Want to know if my flat panel tv is prepared for digital change?
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=FLAT_TV_CA&sct=LCD_LARGE_30_40_SU&session=20090118163435_71.196.251.239&grp=TV_GR&ctn=32PF7320A/37&mid=Link_UserManuals&hlt=Link_UserManuals
I also have the pdf form of the user manual , please email me for it,
jscruggs420@gmail.com
Jan 18, 2009 | Philips 32PF7320A 32 in. LCD Television
Philips 32 inch lcd remote will not work
The TV is in some kind of factory modus, you have to simultaniously hold the VOLUME down (-) and PROGRAM down (-) buttons on side of the TV for 3 seconds.
Jan 10, 2009 | Philips 32PF7320A 32 in. LCD Television
32 Philips hd flat screen #32pf7320a/37b on for a time,then black
check the capacitors in the power supply that is the first thing to do, just check if anyone is swallen or pregnant jajajaja that's how some people call it
Dec 15, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Philips 32PF7320A 32 in. LCD Television Logo
546 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
