Hi Jimbo, generally this issue is from defective LED lamps, the inverter is shutting down because of over current because of shorted LED's. All the main board knows (the board that issues the error codes) is the inverter shut down, it has no way of knowing why.
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months
From Manual:)
5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on.
6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off.
A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now
ready for use.
7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above.
8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the
channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and
the connection LED should change from red to green. You may hear an audible beep during this process.
9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down
both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while
pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate.
Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and
the bottom LED will be red.
10. Repeat steps 5
Intermittent won't start, power supply LED's may be intermittent
Cause: Power supply regulator I901 P/N CZ00868 is leaky, may verify the problem by freezing I901.
