Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Motor never turns itself off
The motor operates continuously. Is this correct. Everything is working well otherwise.
  • Elizabeth Manion Jan 15, 2007
    Thanks so much for your response. Ultimately, it means that I will need a refrigeration mechanic to check it out. Now I know what has to be done. This fridge has always done this ever since I bought it and has always been a concern. It has had a rest from being used as the main fridge for a few years and recently re-instigate to the kitchen. The first customer to purchase it, returned it to the electrical shop under warranty, and then it was supposed to have been 'fixed' (and I don't know what the problem was, as they would not tell me) and then re-sold without the full warranty, but with a 3 month warranty and with 25% discount. My grandson, right now, has just commented that it is not 'cold' and turned up the thermostat. I will contact a reputable mechanic to take a look as I really like this refrigerator otherwise. The interior plan won the Australian Design Award year of production. Thanks again from Elizabeth for your help, much appreciated.
  • 237 Answers
If by motor you mean the compressor itself then no, it should not run all the time. The compressor should run until the thermostat senses the temp. is at where you set it then turns off the compressor. A couple of possible things... if the unit has a leak in the refrigerant then it may run almost continuously since it can barely reach the cold setting you have selected. Or the temp. sensor thermostat may be bad and the unit doesn't know to turn off. There is also a defrost cycle that happens about every 12 hours for a few minutes (depending on make/model on how it works) but that should also turn off the compressor and fans until the defrost cycle is completed. Basically it should turn off when the temp. setpoint is reached or when it's in the defrost cycle.
Posted on Jan 14, 2007
Room fan operates continually
the capacitor is correct for the motor
all it does is supply an over voltage burst to start the motor turning, then to keep it running while the switch is on
if the capacitor was faulty in the original motor then the motor will burn out as that over voltage is not there but the current to run the motor is so the motor over heats and burns
as to the constant running it is important to check how you attached the wires to the new motor as you may have a power wire direct to the motor instead of through the switch control
May 14, 2016 | Televison & Video
Troubleshoot heater problems 1999 buick century
The first thing to do is determine if the engine is reaching proper operating temperature. If the engine thermostat is defective the heater will not work at cruise speeds but will warm up at idle after a moment.
Jun 23, 2012 | 1999 Buick Century
I have a 2000 Nissan Xterra and the 2 blower fuses keep blowing causing the the heat not to work. When I went to switch out the fuses the first time the motor and heat worked right away but only for a...
you have a problem with the motor circuit drawing more amperage than the fuse will allow. it could be the motor itself, or something that is keep the motor from turning freely. otherwise it's a wiring problem. i would suggest unplugging the motor, and then turning on the fan. hopefully, if there is some short to ground, which sounds unlikely, the fuse will blow. otherwise i suggest replacing the blower motor. good luck!
Jan 13, 2011 | Nissan Xterra Cars & Trucks
Wipers don't work on intermittent. They run but stop in they middle of the windshield and don't go to the bottom like normal, Then they run again and stop some other spot. When put on continuous they...
Intermittent Speed Windshield Wipers
The intermittent wiper speed is activated with grounds controlled by the multifunction switch inputs to the windshield wiper motor module. The windshield wiper motor module then activates the windshield wiper RUN/PARK relay coil and switches voltage through the windshield wiper high/low relay. The high/low relay remains deactivated supplying the voltage to the wiper motor low speed input and activates the windshield wiper motor. When the windshield wiper motor module receives the grounded input, the motor continues to operate until Hall effect senses magnet to turn off RUN/PARK sense the output to the windshield wiper RUN/PARK software, deactivating the relay and disconnecting voltage to the wiper motor. The windshield wipers remain parked until the windshield wiper motor module completes a time-out and then repeats the intermittent windshield wiper cycle.
  • The intermittent windshield wiper speed does not operate correctly
  • Multifunction switch.
  • Circuitry.
  • Windshield wiper motor.
  • Go To Pinpoint Test D .
Pinpoint Test D: The Intermittent Windshield Wiper Speed Does Not Operate Correctly
Normal Operation During normal operation, the windshield wiper motor receives voltage at all times through battery junction box (BJB) fuse 1 (30A), circuit 65 (DG). The windshield wiper motor also receives power with the ignition switch in RUN or ACC positions through central junction box (CJB) fuse 33 (15A), circuit 1002 (BK/PK). Ground is provided to the windshield wiper motor through circuit 676 (PK/OG) and circuit 57 (BK). The run/park and high/low relays are contained in the wiper motor electronics. Mode of operation is dependant on the signal(s) received from the multifunction switch.
    Possible Causes
  • Open in circuit 57 (BK), 56 (DB/OG), 61 (YE/RD) or 63 (RD)
PINPOINT TEST D: THE INTERMITTENT WINDSHIELD WIPER SPEED DOES NOT OPERATE CORRECTLY Test Step Result / Action to Take D1 CHECK THE MULTIFUNCTION SWITCH
  • Key in OFF position.
  • Disconnect: Multifunction Switch C202b.
  • Carry out the multifunction switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Did the multifunction switch pass the component test?
Yes
GO to D2 .
No
INSTALL a new multifunction switch. REFER to Section 211-05 . TEST the system for normal operation. D2 CHECK CIRCUIT 57 (BK) FOR OPEN
  • Measure the resistance between multifunction switch C202b-6, circuit 57 (BK), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to D3 .
No
REPAIR the circuit. TEST the system for normal operation. D3 CHECK CIRCUITS 56 (DB/OG), 61 (YE/RD) AND 63 (RD) FOR OPENS
  • Disconnect: Windshield Wiper Motor C125.
  • Using the following table, measure the resistance between multifunction switch C202b harness side and windshield wiper motor C125 harness side:
    Multifunction Switch C202b Windshield Wiper Motor C125 Pin 2, circuit 56 (DB/OG) Pin 10, circuit 56 (DB/OG) Pin 4, circuit 61 (YE/RD) Pin 1, circuit 61 (YE/RD) Pin 1, circuit 63 (RD) Pin 9, circuit 63 (RD) Pin 3, circuit 58 (WH) Pin 11, circuit 58 (WH)
Yes
GO to D4 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. D4 CHECK FOR CORRECT WIPER MOTOR OPERATION
  • Disconnect all wiper motor connectors.
  • Check for:
    • corrosion.
    • pushed-out pins.
  • Connect all wiper motor connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
GO to D5 .
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. TEST the system for normal operation. D5 CHECK THE WINDSHIELD WIPER MOTOR
  • Carry out the windshield wiper motor component test as outlined in this section.
  • Did the windshield wiper motor pass the component test?
Yes
The system is operating correctly at this time. Concern may have been caused by incorrect binding pivot arm adjustment. REFER to Wiper Blade and Pivot Arm Adjustment in this section. TEST the system for normal operation.
No
INSTALL a new windshield wiper motor. REFER to Windshield Wiper Motor in this section.
Feb 19, 2018 | 2006 Ford F 350 Super Duty
How to change the belt in the kenmore dryer model number 110.62822101. Dryer is not spinning so I would assume its the belt correct?
It is indeed a belt issue if the dryer blows hot air, which means the motor is running, but the drum does not turn. Otherwise, the thermal fuse (part number 3392519) mounted on the blower has failed. This thermal fuse is wired in series with the motor circuit and its failure results in the motor not running and the dryer not working at all.
Remove the dryer real panel to access the blower housing and check the continuity of the thermal fuse. Grab a volt-ohmmeter and set it to the R X 1 scale then disconnect one wire from the thermal fuse terminals then check the continuity of the thermal fuse. Replace the thermal fuse should it read open.
May 29, 2010 | Kenmore 64602 Electric Dryer
Lower part of fridge freezes no matter what the set ting.
IM guessing your icemaker is not working either. these symptoms are caused by your evaporator fan motor not blowing air throughout cabinet. However, your problem could be the motor itself not operating correctly, wr60x10185, or the main control board is not operating correctly, wr55x10942. the problem with the board can and often will be caused due to a faulty motor, so both have to be replaced. It would be much too long for me to explain how to test everything you need to test to see source of problem, but your symptoms are definitely caused by that fan motor not running.
www.FixMyFridge.net
Mar 08, 2010 | GE GSS25JFM Side by Side Refrigerator
Motor will not operate
Found spare parts supplier on web thank you. Hopefully it will be the correct turntable motor - otherwise, I will just have to buy a new Microwave.
PR
Jan 27, 2010 | Sharp Microwave Ovens
Codigo C7760 de una Kyocera kilometros 1635
C7410 C7800 C7810 C8010 C8030 Drum unit connector insertion problem • Absence of the drum unit is detected continuously for 1500 ms while there is no error on the copier. Broken external temperature thermistor wire • The input voltage is above 4.5 V. Short-circuited external temperature thermistor • The input voltage is below 0.5 V. Finisher* paper conveying motor problem • The paper conveying motor lockup signal is detected for 0.5 s or longer. Finisher* paper conveying belt problem • An on-to-off or off-to-on state change of the paper conveying belt home position sensor is not detected within 2 s of the paper conveying belt clutch turning on. Drum unit connector inserted incorrectly. Defective drum unit connector. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the paper conveying motor connector terminals. The paper conveying motor malfunctions. Defective finisher main PCB. The paper conveying belt is out of phase. The paper conveying belt clutch malfunctions. The paper conveying belt home position sensor malfunctions. The paper conveying belt home position sensor connector makes poor contact. The internal tray is incorrectly inserted. Reinsert the drum unit connector if necessary. Replace the drum unit. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper conveying motor and check for correct operation. Replace the finisher main PCB and check for correct operation. Adjust the paper conveying belt so that it is in phase and check for correct operation. Replace the paper conveying belt clutch and check for correct operation. Replace the paper conveying belt home position sensor and check for correct operation. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Check whether
Jan 19, 2010 | Office Equipment & Supplies
Kichenaid Mixer K5SS Electrical Problem - All gears have been removed. Motor shaft turns easily. With speed lever in off position, 0 volts go to motor via red and white wires. With lever in any other speed...
I had this problem also: power to the motor, motor not running.
Solution was simple: remove the 2 stators things from the sides of the main housing, clean all the black dust off them, re-insert and everything works fine.
The dust problem is similar to model train sets that I had as a kid at Christmas, the black dust acts as an insulator, preventing power from travelling between two metal parts that you'd think otherwise would conduct.
Aug 26, 2009 | KitchenAid Food Mixers
Soap dispenser does not open during wash cycle
  • Hi,
    please try this...
    imer:
            On mechanical set ups the timer is attached to the detergent cup by an actuator arm. This arm is usually plastic, and if it is broken or otherwise defective then the detergent cup wont be opened. Check the linkage to make sure it is functioning correctly.
    Bi-metal switch or wax motor:
            The bi-metal switch is simply a very precise device that warps, bends, or otherwise deforms when power is supplied to it. The timer operates the bi-metal switch, which inside the dishwasher door. Then the switch is supplied with power and it is working properly, the bi-metal switch deforms away from the latch holding the detergent cup closed and the cup opens dumping the detergent into the washer.
            Some dishwashers have this switch wired through the motor power feed or the heating element. If they are defective then the detergent door will not operate correctly. If the switch itself is defective then you will need to replace it. Another type of mechanism is a wax motor. Wax motors are sealed units filled with wax and found in newer dishwashers and work by heating the wax and forcing up a piston which in turn mechanically opens the detergent cup door. This type of device is also controlled by the timer.
    Detergent cup:
            Sometimes the detergent cup becomes built up with old detergent that prevents it from opening correctly. It's usually a simple fix to clean this out. If cleaning it is impossible then you may need to replace the cup assembly.
    please rate my suggestion..
Apr 14, 2009 | Dishwashers
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
160 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
