Question about KLH HTA-4100 System
Subwoofer VERY weak
I've had trouble getting adequate sound from the subwoofer w/this speaker set. i've got the subwoofer set to PLUS on my receiver, and the relative level for the sub on 10 (as high as it will go), and the gain on the subwoofer itself almost ALL the way up, and it still sounds weak. i'm not trying to shatter my windows, just get a nice full warm sound, but i'm barely getting anything out of it. i've tried the sub on multiple receivers, so i know that's not the problem. any thoughts?
    Problem Solver:
  • 7 Answers
According to the KLH manual for the 9906 "6 pack" with the BassBite sub... it says "if your sub is connected via the speaker - level terminals, your reciever must be set for "NO" subwoofer - even though you are using one. VErify proper polarity on your speaker connection wires. (red or gold to +, black or silver to -). Depending on how you have your woofer connected to the reciever, if connected to a reciever without a subwoofer out then set your reciever for LARGE speakers and turn the subwoofer setting "OFF". Failure to do so will result in little to no bass. If you do have a subwoofer out from your reciever adjust your speaker size setting to small or large speakers as appropriate. Set the recievers sub output to ON. Connecting small speakers to a reciever set for LArge speakers can result in damage to small speakers.
Hope this helps.
Posted on Mar 07, 2011
I have Denon AVR-2310...but lost operating manual ! In audio set up, more specifically speaker configuration, a choice is given between " FTE", and "FTE +main". What is the...
The manual... http://www.retrevo.com/support/Denon-AVR-2310CI-Receivers-manual/id/23452bh638/t/2/
I'm pretty sure you mean "LFE + Main".
You need to identify the speakers to the receiver as Large or Small regarding their bass-handling capacity more than their actual size.
"LFE" removes the possibly overloading bass in a given speaker channel containing 'small' speakers and sends it to the subwoofer.
"LFE + Main" is sort of explained on page 29 "Bass Setting". The intent of LFE+Main is to task your subwoofer with the bass that ALSO exists on all other speaker channels regardless of their ability to handle it all by themselves. As you can imagine, this might make the subwoofer respond to sonic events that are actually supposed to be directional from, say, the rear channel(s). In that case the event might seem to come from wherever the sub is located instead of the intended direction; or at the very least it might seem to come from both places which is probably not what the sound engineers intended when they recorded the piece.
Having full-range speakers 360-degrees around PLUS a subwoofer, I don't subscribe to the 'bass-is-non-directional' school of thought. If you've ever felt the concussion from and subconsciously glanced toward one of the speakers after, say, a huge explosion, the system is working.
Sep 03, 2011 | Denon Audio Players & Recorders
Only subwoofer works at high volumes
It could be your receiver but you can try seeing if the Woofer has a input knob at the back, maybe this down, or maybe.if possible turn down the amount going to the woofer with your receiver.
Dec 27, 2007 | Kicker 02S10L74 Car Subwoofer
I just bought a subwoofer and I cannot get it to work. I changed the receiver setting to SW = YES. Where is the correct place to plug it in the receiver, there are two subwoofer outlets.
Here's your manual. Check Pg. 9 for correct Sub Woofer connection. Leave the SW=YES setting as is if you any small speakers in the system. It can be set to SW=PLUS if you want all bass signals sent to the Sub Woofer. It should only be set to SW=NO if no Sub Woofer is connected. Experiment between the YES and PLUS settings and leave it where it sounds best to you.
If this was helpful, please rate it "4 thumbs up" - thanks & good luck!
Aug 04, 2011 | Pioneer VSX-D514 Receiver
I get a red light on the back panel labeled power. No green light. I don't think the PV 600 is working but when I run the channel check through my Pioneer THX receiver I hear sound. Any thoughts?
The PV600 and PV400 have auto-on circuitry that turns the subwoofer on when a signal is presented, and turns off if no signal is detected for 15 minutes.
http://www.retrevo.com/support/Boston-Acoustics-PV600-Subwoofers-manual/id/522dj484/t/2/
Not knowing which Pioneer receiver you have I have dropped in the steps for No Sound from Subwoofer:
• Check that the subwoofer is connected properly, switched on and the volume turned up.
• If your subwoofer has a sleep function, make sure it is switched off.
• Make sure that the Subwoofer setting is YES or PLUS (see Speaker Setting on page xx).
• The crossover frequency may be set too low; try setting it higher to match the characteristics of your other speakers (see Speaker Setting on page xx)
• If there is very little low frequency information in the source material, change your speaker settings to Front: SMALL / Subwoofer: YES , or Front: LARGE / Subwoofer: PLUS (see Speaker Setting on page xx).
• Check that the LFE channel is not set to -80dB , or a very quiet setting (see Bass Peak Level
on page xx).
• Check the speaker level settings (see Channel Level on page xx).
Regarding the Large vs Small assignment of speakers, what they mean isn't so much the physical size but the ability to handle real bass. Large if Yes.
Jan 12, 2011 | Boston Acoustics PV600 Main / Stereo...
I am thinking of buying a SONY STR DE725 (QS Series) AV receiver. I alreay have a set of home theater speakers with 5 x 80W 4 ohm and and active Sub-woofer (200W). I am wandering whether the receiver...
Yes, it will support a powered subwoofer.
If your existing speakers are from an all-in-one Home Theater in a Box and they have molded connectors you'll have to chop them off to make the ends bare wire and determine which is plus and which is minus on each. Loads of 4 ohms may present a problem at high volume levels.
Take the rated wattage of the sub and other speakers in an HTIB with a HUGE grain of salt. They plays numbers games with th low impedance and the allowable distortion levels to get the results they publish.
For all anyone knows, the speakers and their original electronics may have been designed to operate together to yield adequate performance (like Bose does). Breaking that pairing may give unpredictable results and risk of damage to the speakers or the new receiver.
Feb 18, 2010 | Sony STR-DE725
How do I hook up speakers?
If you are referring to 5.1 surround you would have to have 5 speakers plus one powered subwoofer. The front left and right as well as your center channel to the majority of the sound reproduction with the rear channel being there for intricate sounds and background noise. The subwoofer will be a preamp output from your receiver. That signal will then get amplified by your subwoofers power amp. Generally subwoofers are tucked away in a corner while the other 5 speakers form a box around your viewing area.
Feb 11, 2010 | Pioneer VSX-453 Receiver
Sub wont work, all connectionsgood,cable good
If your front speakers are defined as small, the sub is locked to ON.
My $.02 regarding speaker size selection in this context. Generally speaking, if a speaker can adequately handle real bass, regardless of its apparent woofer size (like many Bose systems), I define it as Large and I also define the Sub as Plus so Low Frequencies will still be sent to the channel(s) they belong to along with the sub for those real deep tones.
Aug 22, 2009 | Pioneer VSX-D510 Receiver
Replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
May 18, 2009 | Sony SA-WM500 Subwoofer
Subwoofer goes to sleep
The receiver automatic speaker set-up set the sub volume at -12 and since it was not getting any signals from the receiver it was doing what it is supposed to be doing (going to the standby mode). This was troubleshooted by Onkyo tech support on a Sunday. All the best about Onkyo customer support.
Apr 12, 2008 | Audio Players & Recorders
Subwoofer preout and bass
did you tell the receiver that you have a subwoofer connected (thru the quick setup)?
Apr 02, 2007 | Pioneer VSX-D514 Receiver
KLH HTA-4100 System Logo
440 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
