Question about Sony Playstation 3 (PS3) Console
No color Audio and video working fine but only displays video in black and white
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 167 Answers
Sounds like you are having a issue with color format or a bad connection cable... In the US we use the NTSC color format, Japan uses NTSC-J, and Europe uses PAL. This matters quite a bit; if you have some Special Edition PS3 that they only sell in Japan and have it plugged into your Flatscreen TV in the UK no dice. Make sure you do not have conflicting regions for your hardware. Moreover, make sure the pixel resolution is not out of bounds for your TV's range. The PS3 has different connection cables for every kind of connection; RCA, HD, HDMI. I recommend using HDMI if your TV supports it.
Posted on Nov 28, 2008
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
Only black and white on fujitsu 42" monitor with s-video
You need to check the Format, either NTSC or PAL, USA = NTSC, Europe etc, PAL. Set this correctly.
Mar 05, 2010 | Fujitsu Plasmavision 42" TV
DVD plugged into red, white and green(Yellow) TV imputs, results
Yeah no color coz its black and white. Color coding commonly yellow wire for video, red and white wire for audio. It should also be from DVD to TV, video out and audio out going to video in and audio in. And switch the TV to play video and the audio inputted. Maybe TV/Video Switch or button.
Hope it helps
Apr 06, 2009 | Jensen TS2750J TV
Xbox 360 does not display any color on any game
definitely sounds like it is a problem with your vga cable. i would suggest trying a different one.
Mar 23, 2009 | Microsoft Xbox 360 Console
No color on secondary display
Dear Huzzah,
please try to re-install the software( driver) of Radeon 64mb 9550/X1050 secondary series maybe the software is crroupt, if still face the same problem then please contact to Vendour to replace this card, if this card is in warranty period.
Regards
Scorpionakku
Oct 07, 2008 | Diablotek RADEON 9550 Video Card - 64MB...
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
Inverted colors
be certain it is not the video card connect it to an external monitor and test,
and reseat the video connector from the panel to the card.
look for bent connectors too.
Mar 19, 2008 | Acer Aspire 5100 Notebook
Black and White video on S-Video output
The Concept of S-video is Splited Video Signal (Luminance for black and white, Chrominance for colors), in your case the luminance is ok but there is no chrominance out. Expert technician is required: Check for dry solder at the s-video out outlet. Good Luck Toufic Malek
Sep 23, 2007 | GE GTD120 System
No color on Sony TV, all other tvs are great
check the av cables in back of your tv and also check the wires connected up to the xbox 60 it's self
Sep 01, 2007 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
136 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
