Question about Electronics - Others
PEN DRIVE SHOWING 0 FREE SPACE AND ZERO USED SPACE
I TRIED TO FORMAT FORM CMD USING FORMAT H: COMMAND BUT IT IS GIVING INSERT DISK WHEN READY..IF PRESS ENTER..IT IS SHOWING TYPE OF FILE SYSTEM RAW.PLEASE USE /FS SWITCH TO SPECIFY THE FILE SYSTEM YOU WISH TO USE ON THIS VOLUME
  • Anonymous Jan 20, 2009
    i am in trouble with 0 space showing pen drive of 32 gb
  • Anonymous Mar 16, 2009
    WHENEVER I TRY TO OPRN MY PEN DRIVE ,I GOT MESSAGE " THE DISK IN THE DRIVE K IS NOT FORMATTED DO YOU WANT TO FORMAT IT"
    PLS HELP SOME ONE
    SHARMA21PANKAJ@GMAIL.COM
Hi
Just go to My Computer.right click on Manage.Then click on Disk Management.In the bottom tab you can see your pendrive.click on it get a new partiotion using NTFS.
Posted on Jan 06, 2009
    New Friend:
So, now, you are asked to format this pen drive and also find it is shown as RAW file system in Disk Management? OK! No panic! In my personal experiences, there are often two steps to resolve this RAW flash drive data loss troubles:
Step1. Stop adding new data on this RAW pen drive and start pen drive RAW file system recovery software to take original USB drive data out.
Step2. Back up restored flash drive on another drive or location and format this drive from RAW to NTFS.
Therefore, you also can follow these two steps to see whether your problem could be successfully fixed.
Posted on Oct 16, 2015
Transcend jet flash v33
Hi Virus or Trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert the pen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Mar 30, 2014 | Electronics - Others
My transend pen drive is not working. I am not able to access my pen drive when an error comes it says " Please insert a disk into drive H: " Also i tried to format it and again an error comes it says "...
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you could see a yellow question mark? right click to reinstall drivers or
insert transend pendrive go to control panel administrive tools computer management disk mangement you you can right click select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
hope this helps
Oct 23, 2010 | Computers & Internet
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk please help!
Aug 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hello, i am not able to format my transcend 8gb pen drive. whenever i format this pen drive after a few second's i got a message "WINDOWS UNABLE TO FORMAT". Properties shows used space 0 bytes and free...
Try it on another usb port..or If the windows can't format try formatting it from the command prompt if it's not working than must be pendrive.. i think there's no problem with other pendrives.. or the one that you have
Aug 18, 2010 | Computers & Internet
My pn drive shows used space & free space is
see if you can format it if not it is bad
Apr 13, 2010 | Transcend (589307) Media
Pen drive is not working
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove Hardware icon and then click on USB flash drive you want to remove)
Dec 14, 2009 | Kingston Technologies 512MB DataTraveler I...
Pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
Aug 17, 2009 | Transcend (589307) Media
Can tot open pen drive
you format your pendrive
or
go for nearest transcend service centre
or
your your pendrive is out of order
Jul 31, 2009 | Transcend (589307) Media
Million thanks for the one who solves this for me
Hi Sweet_Rascal,
If I understand you right, all you want to do is to successfully complete the format of a 4Gb Jet Flash/Transcend Flash Drive. You were unable to complete it using the Windows built-in format function. Further you can not access, read from or write to the said flash drive.
May I suggest you to use HP Drive Key Boot Utility instead of the Windows built-in format command.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 28, 2008 | Electronics - Others
Electronics - Others Logo
1,549 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
