Question about MTX Ford Explorer/Mercury Mountaineer/Mazda Navajo 1991-2001 Thunderform Loaded with 10 Inch Woofer and ... Car Speaker
Rough idle ON 97 FORD MECURY
The motor idling is rough
engine shut off when in idle mode
  • 962 Answers
The problem may be a buildup of carbon or fuel varnish deposits in the idle speed control valve (also called the idle air control valve or IAC valve). The cure for this condition is to clean the valve with some aerosol throttle cleaner or engine top cleaner. disconnect the air ductwork from the throttle body. Start the car and run at about 1500 rpms spray the cleaner directly into the throat of the throttle body. Turn off the engine and let sit for a few minutes. Then repeat the process a couple of times. if that does not work, you can remove the IAC and clean it by spraying into the two holes on the underside of the valve. If not, then you need to replace the valve.If that does not work , then check for a code. the throttle position sensor may be the problem. you can have it scanned at an AutoZone or other parts store.
Posted on Nov 28, 2008
My 97 Thunderbird is rough idling. I cleaned the bank 1 02 sensor and it still has a rough idle. I can floor it and the idle goes away.
You don't clean O2 sensors , if bad you replace them . An only if there is a DTC - diagnostic trouble code or you check out O2 sensor performance with testing , using scan tool , lab scope or multimeter . A rough idle is usaully caused by a vacuum leak , a engine misfire , IAC - idle air control air passages clogged . There are videos on youtube on how to test to find rough running problems .
Nov 06, 2016 | Ford Thunderbird Cars & Trucks
What would cause a 97 Ford Probe GT to idle rough and misfire at idle only Buck Run better when it's cooler outside and it also stalls when it has a rough idle
Check for any sources of unmetered air entering the engine. ( Vacuum leaks ). Check air intake hose going from air filter box to throttle assembly for any signs of splits/cracking causing a lean condition. Possible Air flow sensor dirty/defective
May 27, 2016 | Ford Cars & Trucks
89 ford probe hesitates when leaving a red light, then runs fine otherwise, fuel filter?
Engine Runs Rough, Stalls, Hesitates on Acceleration, Hard ...
repairpal.com > Problems > Ford > Probe
Ford Probe Engine Runs Rough, Stalls, Hesitates on Acceleration, Hard Starting, Poor Performance. This is a verified problem based on 9 reports. Learn more ...
Starting Problems - 1997 Ford Probe - RepairPal
repairpal.com > Questions > Ford > Probe > 1997 Ford Probe
Dec 5, 2010 - Starting Problems on 1997 Ford Probe ... If the engine runs rough,stalls, hesitates on acceleration, is hard to start, or has generally poor ...
A new misfire/hesitation on accel. Problem.. - ProbeTalk.com Forums
forums.probetalk.com > Tech Section > 2nd Gen (93-97) V6 2.5L
Feb 05, 2016 | Ford Cars & Trucks
Car wont idle
There re few possibilities that can cause no idle issues.To troubleshoot the issue help links are provided below.Click the link below:---
Idle Problem? http://whatisbyme.blogspot.in/2012/05/2001toyota-corolla-idle-problem.html
Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------
Stumbling and stalling at idle after engine rebuild? http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
Cooling fan Shuts OFF and Idle Drops? http://howtobyme.blogspot.in/2012/05/toyota-celica-cooling-fan-shuts-off-and.html
Rough Idle and Vibration? http://whatisbyme.blogspot.in/2012/05/2006-ford-f150-rough-idle-and-vibration.html
Steering Wheel Vibrates at Idle? http://whatisbyme.blogspot.in/2012/05/1993-toyota-corolla-steering-wheel.html
Runs Fine But Idle Is Low? http://whatisbyme.blogspot.in/2012/05/2004-toyota-highlander-runs-fine-but.html
Vehicle Will not hold Idle? http://whatisbyme.blogspot.in/2012/05/2003-lexus-es300-vehicle-will-not-hold.html
Engine Idles Rough and Dies? http://whatisbyme.blogspot.in/2012/05/1994-lexus-es300-engine-idles-rough-and.html
This will help.
Thanks.
Jul 17, 2012 | Cars & Trucks
Car idols rough no power
Mar 03, 2012 | 1999 Suzuki Esteem
1997 Ford Contour with a rough idle while stopped
This is a common complaint on these cars. I own a 96 myself.
Assuming that you engine is fine and runs smoothly under normal operation, and just is rough "feeling" at idle while stopped; then I would suggest changing the motor mounts...the mounts may not be broken, but the rubber isolators get worn and soft, and transffer normal engine vibration into the chasis of the vehicle. Mine was doing the same after changing the mounts good as new again.
Please note...don't use cheap mounts, by the better grade/quality mounts.
Aug 27, 2009 | 1995 Ford Contour
Car Audio & Video Logo
208 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
