Laptop Compaq Presario 2700 Keyboard & Mousepad lost at all
I had a problem with the heat sink of my Compaq Presario 2700. Heat sink detached from motherboard. Well I just got 4 screws, push them from outside thru the plastic case under the motherboard and thru some ALREADY made holes to attach them to the heat sink. (Just in case... I didn´t made any holes or breaked or pushed the motherboard) Well at the end PROBLEM SOLVED. The heat sink works great, smoothly and no noise at all.
BUT NOW my keyboard and mousepad doesn´t work AT ALL. Drivers are OK, No problems reported at the Device Manager List. For Windows XP SP2 everythings is OK... BUT the fact is that my keyboard and mousepad doesn´t work at all. Not even from the very very start. I am not even posible to enter BIOS. The only way I can work with the laptop is to plug a USB external Keyboard & Mouse. There was when I discovered that when entering the BIOS (with the external USB keyboard & Mousepad) the BIOS post an ERROR 0222: Keyboard Error. Can anyone help me with this problem please ???
  • garettc Dec 13, 2008
    Same problem. Fixed the heat sink problem, but then no pointer or keyboard functionality. I don't see how it could be related to a third layer in the MB as it was a metal post that went through the MB and was soldered in place.
    I am anxious to know if the plastic screw thing worked.
  • 341 Answers
I read somwhere that most motherboards have a third layer of conductors laminated in the middle of board.It could be possible that you are shorting out something there. Take the screws out and try it without the heatsink for a minute or so. Most big DUI stores sell plastic screws in their hardware areas. These will work no problem.
Posted on Nov 29, 2008
Compaq presario a928ca laptop has overheating problem laptop overheats within a minute & we cant put it on table also we need to put some support below so that air can pass below it.
The first thing I would do is open the case and remove the fan and heat sink for the processor. You will probably find a little "radiator" looking device clogged with dust bunnies. Clean it out good with canned air and reinstall it. Be sure to clean the processor and heat sink then reapply heat sink compound. Clean all your fans and, with the case open, power up and look at all your fans. Are they all spinning at full power. If not, replace them. Reassemble the case. You should be good.
Mar 20, 2014 | Compaq Presario A928ca Laptop Lcd Screen...
My compaq presario c 700 laptop keys sticks and runs hot, also runs very slow
sticking keys well! theres only one thing you can do about that is take the keyboard apart and wash the parts in a weak solution of detergent and clean the rest with a damp cloth--someone must have spilt a cup of coffee over it at some stage.
if it runs hot replace the fan,clean the aluminum heat sink of dust ,,hot aint such a big deal as long as the plastic isnt melting
Slow--try anotherOS
Sep 07, 2010 | Compaq Presario 700 470024-192 Notebook
My Compaq Presario F730US keeps overheating the fan does not run properly what docking station do you recommend me to buy
I would recommend cleaning out the vents and geatsink grills with compressed air. I would then remove the heatsink unnit and replace the thermal grease on the heatsink and processor. Most laptops do not need any additional cooling if thier heatsinks are free of dirt, dust and debris. The compressed air can be bought at office supply chains. Just use short bursts of air and clean all the compartments including the cd tray. Just make sure to power down the laptop first and remove the battery.
Oct 05, 2009 | Compaq Presario F730US Notebook
Compaq Presario 3000 incredibly slow firing up, opening up anything. Loud fan all the time too
This advice relates to the Compaq Presario 3000 Notebook series but may also apply to other notebook computers as well.
The heat sink and fan assembly is probably clogged with dust and airborne particles. The clogged cooling parts can lead to heat problems with the CPU. When the system (CPU) gets to hot, the fan has to kick into high gear to try to cool things down. Once you remove dust and debre from the heat sink fins and fan, you will immediately experience better cooling and less fan usage. Your system may also be set for dynamic switching of CPU speed. If you CPU gets too hot, the system will reduce clock speed and ramp up fan and everything will slow way down. Use a good system monitoring software such as Notebook Hardware Control to monitor your CPU temperature, HDD temp and so forth. When the system starts getting too hot, first look at clogged heat sink fins as possible culprit. If you're good at electronics you may be able to service the unit yourself. Get a copy of the system's Maintenance and Service Manual or have a professional do the job for you as you will have to partially disassemble the computer to clean out the heat sink. Depending on the system, the job can take as little as 15-20 minutes once you become proficient at it.
May 09, 2009 | HP Laptop Keyboard for HP Compaq Presario...
Compaq Presario C769US PC Laptop heats up.
Right under that area of the keyboard there is a heat sink. If you look in the bottom of your laptop, in that area you will see a vent (and another towards the upper area of the bottom of the laptop). These vents are to keep the internal devices cool.
You can buy a laptop cooler online or in the store
http://www.xoxide.com/noco.html
Hope that helps!!
Mar 07, 2009 | HP Compaq Presario C769US Notebook
Distortion of images on my laptop screen
i may be due to over heating of components like heat sink. or the problem with the connecting display cable. check it out
Jan 08, 2009 | Compaq Presario Notebook
Compaq 2100 Laptop Monitor KBD & Mousepad (Not working)
The monitor is defective and should be repalced. Keyboard and mouse pad problem could be a driver problem. Try to reinstall their drivers.
Dec 02, 2008 | Compaq Presario 2100T Notebook
Noisy fan on a Compaq laptop Presario 2500.
Have you tried following the instruction in the Service Manual(pdf) published by HP online?
Nov 30, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Computers & Internet Logo
734 people viewed this question
Alun Cox
David Payne
David Payne
