Question about HP PSC 2355 All-In-One InkJet Printer
Scanner won't scan
The scanner goes through all the proper processes as if scanning into my computer, but right at the end of the process when the scan should appear instead on the screen a window pops up that says ' unable to resolve file alias' , and no scan appears. I've tried reloading the software but it makes no difference. Any ideas?
  • 1 more comment
  • Indra Shann Oct 19, 2007
    Thanks Blue hammer for your response. What happened in the end was a friend came round and after scanning changed the setting from 'Open in application' to 'save as a file' and the scan then arrived on the computer. I should add that I have an apple mac computer so there maybe an incompatibility thing going on. Thanks for your suggestion
  • Anonymous Mar 12, 2014
    reloaded hp6313 printer software but scanning process just hangs and will not complete
    Novelist:
    Scholar:
  • 167 Answers
Try connecting it to another computer. If it works, then it is a prblem with your computer, otherwise it is with your scanner hardware.
If you can open the scanner clean the circuit board with (Isopropyl alcohol) IPA solution. you can also try replacing the ribbon type cables connecting the print head.
If the problem arised due to dust accumulation, the above action should solve the problem.
Posted on Oct 19, 2007
  • Deepu Amalan
    Deepu Amalan Oct 19, 2007
    In the solution I have mentioned as 'print head' replae it with "Scanner lamp assembly"
Hi, I scan documents (recto and recto-verso) using the InformatikScan software and the scanner Canon DR-9080C. When I scan for ex. 30 pages, after 10 pages the scanning process slows down in...
The scanner creates a Raster Image and if it is grey or color, the size is big. After a few images are scanned, the 'buffer' inside the scanner is full. It may take more time to process the scanned image by the scanner if it is 24 bit color. The image is sent to the computer Harddisk and if the disk is full or if it had not been defragged for a long time, the sectors may not be contiguous for speedy writing, This will slow up the scanning. Ensure the disk has large space. 'Scan ahead' slows down scanning speed. (Without scan ahead, the next page is fed only after processing, whereas when selected, just after the previous page is scanned, the scanner start the next one)
S. Mohan, India, Chennai
Jul 04, 2011 | Canon DR-9080C Path-Through Scanner
Scanning Slides from Epson Perfection V700PRO
Hi
Please reinstall Epson Scanner software it will solve your problem
Thanks
Apr 11, 2008 | Epson Perfection V700 PHOTO Flatbed...
Can Lexmark x2470 scan and print a double sided document?
after reading the manual, http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf, yes it is possible - not that it tells you how to do it though so read on.
Until you become familiar with the process just use one sheet of paper at a time in the printer.
As you know, in the scanner the top right of your document goes to the right hand front corner of the scan bed (the clear window), place the page on the scanner and scan.
Pick up the printed sheet of paper and flip it so the left hand side edge is now in your right hand and the right hand edge is now in your left hand and you are now looking at the blank side of the paper.
Insert the page back into the sheetfeeder.
Flip the page to copy in the scanner so the rearmost edge of the paper is now to the front of the scan bed and the front edge of the paper is now towards the rear (you should now be looking at the page you scanned previously).
Scan the page.
you should have now scanned both sides of one sheet of paper to another sheet of paper.
as your printer does not have a sheet feeder for the scanner you have to do the process manually. hope this helps.
Apr 20, 2011 | Lexmark X2470 All-In-One InkJet Printer
How do I use my x5495 to scan a resume and then to edit it with my Dell XP computer?
You'll need to scan the document with an OCR software package (Optical character recognition) that will recognize the letters themselves and transmit them to word processing application, such as Word for Windows. Most scanner packages come with some form of OCR utility, so check your installed software. You may already be set up!
Best of luck, William
Mar 03, 2011 | Lexmark Office Equipment & Supplies
How do I scan a document please?!
you can a document using a scanner.
1. you have to find a SCANNER machine that is responsible in scanning the files you want to scan.
2. Then after you find a scanner, next thing to do is to place the document file in the scanner and make sure that your scanner is properly connected and turn on.
3. Click and run the software that is bundled with the scanner to scan the document and then you have to set the path where your scanned file is to be place.
4. Then after the scanning process finished then click the save button to save the scanned files.
Thanks
Sep 15, 2009 | Office Equipment & Supplies
Scanner in use
close all the programs that are running and restart your computer. also turn off the scanner and disconnect it from the PC and power. plug it back after 5mins, reboot your computer, start the scanner program and reconnect the scanner. try to scan again. if it fails, disconnect the scanner and unistall the driver, there might be a conflict somewere. reboot your computer and reinstall the software then connect the scanner and try to scan again.
Jun 23, 2009 | Office Equipment & Supplies
Scanned image is blank, although the page inside the scanner has text &/or picture.
Scanner contains Unlock botton below it, just unlock it it will scan fine.
Vikrant
May 08, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Lexmark p-3150 scanner
Is the Scanner bulb goes on, during process, Is there any movement.
If not then the installation is not done properly, or either the Scanner driver are missing from the setup of All-in-One printer.
Let me know if you need further help.
Oct 01, 2008 | Lexmark P3150 All-In-One InkJet Printer
Can't uninstall microtek 5900 scanner
This is a funny problem. Try & locate SCanwizard 5 files and delete them. Complete the registry deletion as suggested. Run scandisk. Install and uninstall Scanwizard 5.
Mar 07, 2008 | Microtek SCANMAKER 5900 Flatbed Scanner
HP PSC 2355 All-In-One InkJet Printer Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
