Just got "Pet resort" -
Just got "Pet resort" - Installed it - try to access - get box saying "pixal dimmer not available" / Ok - won't load game. Suggestions?
  • 70 Answers
Http://www.valusoftsupport.com/Results.asp?search=full&show=titles&results=20&submit=prod&pid=526
First, check to make sure your PC meets the minimum system requirements. If it does, then update your video drivers. Lastly, uninstall, then reinstall the software.
Posted on Nov 28, 2008
Dimmer lights installed but go out after 10 minutes?
Hi Frederick,
I'm an electrician and would like to help you solve this problem. I have several questions to ask to help narrow down the cause.
Is this switch installed in the same box as another dimmer switch?
Did you need to modify the heat sync fins to fit the switch into the box?
Was this dimmer recently installed to replace a switch or old dimmer? If so, what was there before?
How many bulbs and their correscponding wattage and type (incandescent, compact fluorescent, etc.) are being controlled by the dimmer?
Is there any non-lighting load connected (paddle fan, etc.)?
Can you provide the dimmer manufacturer's name & model of the dimmer? You said you have a "2 way" dimmer and there is no such beast - I suspect that you have a 3 way dimmer.
Without answers to the above - I suspect either an excessive heat issue due to overloading or ganging of several dimmers in one large box or improper use of the dimmer controlling a motor or other non-lighting or non-dimmable load.
Leave a comment with the answers and I can help pinpoint the problem.
Feb 28, 2013 | Electrical Supplies
Problem with fuzing dimmers
Hi Peter, I'm an electrician and I'm going to try to help you with this problem.
You're controlling just 315 watts, which is considerably less than the 600 watts which that most "garden variety" dimmers sold at Home Depot, Lowes', etc. can handle (without having to buy one designed to handle 1000 watts or more). You should review the wattage rating of the dimmer to be sure. You can find it on the box (if you still have it) or stamped somewhere on the switch itself.
What you're describing sounds like an overload issue, yet the wattage you're controlling is relatively low. Let's dig a bit deeper.
If the dimmer is located in the same switch box that has additional dimmers, then you must derate the wattage rating of ALL the dimmers. This means if you have two 600 watt dimmers, they can only control 500 watts each, if you have three dimmers, they can control 400 watts each. A Lutron chart can be found here. Any derating specified by the your dimmer's manufacturer would take over ride Lutron brand chart however. The derating is required because of the need to remove the cooling fins from the dimmer. If they are not removed in a multiple-switch box, they won't fit correctly. Of course, if the installer is breaking the cooling tabs off when it isn't needed - he has effectively reduced the wattage capacity of the dimmer. In other words, only remove the cooling fins as needed.
Next, it the type of load. I am assuming that these seven 45 watt loads are incandescent - or lamps with a filament. Types the require a ballast or starter, such as fluorescent, neon, etc. are NOT designed to be dimmed unless the manufacturer specifically states otherwise. These devices present an initially much larger load on the dimmer that over time, causes the lamp and dimmer to fail.
The next part of the load issue is motors. Motors such as those found in paddle fans, etc. must never be put on a dimmer. To control any motor, a dimmer must not ever be used. Use a motor controller instead. They are designed for the loads a motor presents and prevent overheating of motors as opposed to use of a dimmer. Motor controls for fans look very similar to a dimmer switch, but often have 3 or more preset positions that click into place as opposed to being completely variable like a dimmer.
I hope this was helpful and good luck. If you have more questions, provide more information about the load you are connecting.
Mar 05, 2012 | Electrical Supplies
Installed a dimmer switch to a light. Put power back on and the light came on. Wouldn't dim however and when I turned it off it would not come back on. fuse is OK
Is the dimmer rating higher than the load? Are you trying to dim fluorescent lamps? A flourescent requires special dimmer switch.
If you over loaded or mis-wired a transistor or wire wound dimmer, you may have damaged it.
Is this a three way light circuit?
May 30, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Petz 5 not working.
Right-click on the Icon > Go-to Properties > Click the "Compatibility" tab > Click the check box next to "Run this program in compatibility mode for:" and select Windows 98 or Windows XP if available.
You may need to disable visual themes or other options.
Hit apply once you are finished configuring.
May 07, 2009 | Ubi Soft Catz 5 (Windows) (680901) for PC
Not able to even start to play pet resort. The
well first you have to set up a pin so how you do that is go to the computer inside the house then press the A button then go to the one that says expansion then press the A button then press the one that looks like a rabbit then the first one is free so tap it into it says yes then press buy then you have to wait intill the next day then you will have the pen then you will have to wait for a person to come and give you a rabbit!!!!!!:)
Mar 06, 2009 | Atlus Paws & Claws: Pet Resort for DS
How do you administer medicine on pet resort paws and claws ds thanks
ok you have to go to town and go to the store it will pull up something and on the top go to the second littlle cirle and then go to the red cross go and it will have on the side bought and say yes then go back hom and in the first room at the bottom of the screen is her head click on it and at the right side there willll be a red cross drag it to the little circle at the bottom then go outside and say feed rabits and it will have the red cross it might not do it right away but keep trying TEXT ME FOR ANY MORE Q's at lilybay_101@yahoo.com thanks
Jan 03, 2009 | Atlus Paws & Claws: Pet Resort for DS
I have a Dell 5200series(Ithink) w/Windows XP -is 5 yrs old - 28GB on hard drive w/approx. 18 GB available.I recently added 512KRAM to go along w/existing 256K RAM - I am on dial up - Ihave used Reg Cure...
Hi 1MLucke51,
Thanks for the posting in FIXYA.
Please can you tell me the Dial up connection speed.
Please delete all Prefetch files, Temporary Internet files, Temp files , and then empty recyle bin.
How to Do:
Step 1: Delete the prefetch files from time to time.
Click on start ..run .. type .. prefetch
ok
Select All and delete
Step 2: Delete temp files
1. Quit Internet Explorer and quit any instances of Windows Explorer.
2. Click Start, click Control Panel, and then double-click Internet Options.
3. On the General tab, click Delete Files under Temporary Internet Files.
4. In the Delete Files dialog box, click to select the Delete all offline content check box , and then click OK.
5. Click OK.
Step 3: Temp Files
Click on start .. run .. type
%temp%
ok
Press Ctrl + A key and delete all files
Note: Skip if some of files not delete and warn by computer.
Then Empty recycle Bin
Regards
Ellin
Sep 12, 2008 | Computers & Internet
The computer will power up, however, the monitor will stay black and say "Monitor going to sleep." It works sometimes, but the screen will get look really pixally.
Check the cord between your monitor and the computer, and try replacing it.
you could also try installing the latest graphics driver for your pc
Jul 27, 2008 | HP Computers & Internet
Just purchased pet resort unable to load..msg says pixel shader
do you have pci express video card? i think it needs a good video card
Apr 01, 2008 | Computers & Internet
Pet resort software
hmmm..what computer you using?
Feb 18, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
