Question about HP Office Equipment & Supplies
I Have a c6180 all-in-one printer now and I want to change to a c7250 all-in-one do i have to uninstall the old one first or just install the new one?
  • 734 Answers
No problem Just install new one.
but dont replace existing files when you install new one.
Posted on Nov 28, 2008
When installing new printer cartridge, the install date is wrong.
please change the printer date and time setting in going on setting menu.
Sep 25, 2015 | HP Photosmart C7250 All-In-One Thermal...
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
Photosmart C7250 All-in-One. Copier, fax and printer work. But I cannot find my scanner icon where it was on my previous computer.
Were you able to install the correct driver for your OS? Usually the scanner application can be found in the list of Programs >> HP Photosmar C7250. If what you are referring to is the icon on your System Tray (lower right corner), you can always add an icon there by right clicking the blank space in your system tray and choose properties. On the taskbar tab, click on Customize, look for the icon for your scanner, click for the behavior and from the drop down button, choose "Always show".
Try to scan also by pressing the scan button in your printer and press start to initiate a scan.
Jan 03, 2010 | HP Photosmart C7250 All-In-One Thermal...
Fatal error while installing hp c7250. reads MSI.dot4wrp.
Very simple.Insert the printer installation software cd
First right click your cd drive and select open then go into the folder called util.
Then go into the folder called "CCC".
In that select uninstallation l3
once this uninstallation completes.
go into Local Disk C:\program files\hp\
and delete the digital imaging folder as much as can be deleted.
restart the computer.
goto hp.com and download the software for officejet 6500
After downloading it run it and when the type of uninstallation comes select advanced.
Next select custom installation and uncheck.
hp updates.
Hp Customer Participation Program
Hp Web Printing.
click on next first select usb installation and click on next(irrespective of whether it is a usb or wireless connection).
click on next and dont plug in the usb cable.
at the bottom there will be a box that says check this box if you want to connect your device later.
click on next.
the installation will finish.
Now insert your printer software installation cd and click on add a device or install and now you can choose your type of printer connection and your issue will be resolved.
" by nalin_elliot
if fails, yet try this free util for windows install repair tool on these syte
http://wiki.DjLizard.net/Dial-a-fix
Oct 05, 2009 | HP Photosmart C7250 All-In-One Thermal...
Windows installer and not find status.msi
Sometimes when you delete a program you have to restart your computer for it to uninstall. Then when you reinstall using your disc that came with the printer if anything remains it will ask if you want to replace or add click replace and finish the install by the prompts from the disc and printer should work.
Sep 20, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C7250 AIO won't print wirelessly from my laptop
Do Add Port in Printer Properties Ports tab and choose Standard TCP/IP. Enter IP address of the printer and follow steps to finish configuration.
Hope this helps!
-michan-
Jul 20, 2009 | HP Photosmart C7250 All-In-One Thermal...
We purchased a new windows vista computer and it was not compatible with our hp C6180 all in one printer that we already had with our old windows computer. I downloaded the compatible software for windows...
just uninstall any drivers you have installed and then reinstall it.Also do this for all printer related softwares. Also this can happen if your computer is infected.SO scan your system using any of the online scans available.almost all good antivirus companies websites will have link for an oline scan.
Jan 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180 stopped scanning after installing leopard
Unplug the printer from the computer, uninstall the printer software, and download the latest software and drivers from the HP website.
Leave the printer unplugged from the computer while you reinstall the software. When the installation program asks you to plug in the printer, do so.
One the software has completed installation, reattempt the scanning function.
Jul 24, 2008 | HP Photosmart C6180 All-In-One InkJet...
HpC6180
Hi, Based on your post/description, I will assume that your printer is connected to your network by either by WiFi or Ethernet and not by USB to a particular PC. If it is USB connected to a PC, then it should still work since it is not physically connected to the router. Since your "Internet radio" was just recently upgraded, it is possible that the networking configurations have been changed. Having said that, it is perhaps required that you likewise changed the networking configuration of the C6180 to conform with the new settings. Pls post back with information on: 1. How is the C6180 connected; by LAN to your router or by WiFi? 2. What is your new/current networking configurations (IP add, Subnet Mask, Default Gateway, DNS, Network/Workgroup name)? 3. Do you still have the original CD installer/driver, the user's manual and the quick installation guide? 4. Do you still have the original USB cable that came with the printer? Alternately, you can checkout the installation guide at the HP website (http://h10025.www1.hp.com) or go through the installation procedure again using the CD that came with the printer (of course you must initially uninstall the HP C6180). Hope this be of some help/idea. Pls post back with additional information/details so we can figure things out. Good luck and kind regards.
Oct 01, 2007 | HP Photosmart C6180 All-In-One InkJet...
Ben Johnson
