Question about HP Compaq Motherboard
Halt on option in hp compaq 330ut
Sir i wan to know , how to change the halt on settings in bios. other machines have a option HALT ON -all errors, no errors... option but this model does't have that kind of option .
how can i change it?
  • 30 Answers
Usually it is in the same page as time and date.
lookat the botton of the screen.
If it is not there please consider contacting me here again for further advice if possible.
Thank you for using agaycom.
Posted on Nov 28, 2008
Floppy diskette failure
Restart your computer during the boot process you will see a certain key to press to enter set up (BIOS) press and hold that key usually the
Delete or F2 key right after you switch on your pc. then will see the bios menu. press enter at the first menu and press down arrow until u see "halt on". it supposed to showing "all error". change that to "no error" and press f10 and then ente r
hope this helps
Sep 10, 2012 | HP TouchSmart IQ506 PC Desktop
I have a laptop HP Compaq 6720s and now I get the following code t.w. 0x4001001300001002 and when I will restarted the computer the message boot.mgr missing. What must I do?
That error means that the Boot Manager is Missing. This is usualy caused by either a failed hard drive, or a failed attempt at recovery. If you try to do a recovery and then suddenly halt the process, weather on purpose or due to somthing like power failure, then the first bit of the Recovery boot process, the BTMNGR, can be hosed. If this happens then your only option is to order recovery disks from the manufacturer and install the OS that way.
You might boot into bios (F10 on startup) and do a hard drive self test first to make sure you dont have a hard drive problem...
May 31, 2011 | HP Compaq 6720s Notebook
Every time I boot up my computer I get a pop up telling me ASUS keyboard has experienced a problem.... How do I fix this?
You will need to enter the BIOS and turn off, or disable Keyboard Errors. It should be on the first page, but varies on some models.
On the first page, there should be an option Halt on: All errors, change that to Halt on: All but keyboard or Halt on: None.
The options may vary depending on your BIOS version, but should be very similar if not the same.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 16, 2011 | ASUS Computers & Internet
Acer laptop gets hanged every time it is opened. on dignosis it shows code 0211= key board error.pl advise
Try this:
  • open BIOS
  • Look for HALT settings
  • Change settings of HALT ON ALL ERRORS to HALT ON ALL ERRORS EXCEPT KEYBOARD
  • Wait for windows to boot then try your keyboard again
Oct 19, 2010 | Acer Computers & Internet
How do I run a Fujitsu PC headless?
while booting press F2 to enter to bios setup.
in the main tab go to Boot Features.
the first point in Boot Features is POET Errors will be "Halt On All Errors" then you have to change it to "No halt On Any Errors"
May 13, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
I have an IBM 300 pl desktop and when I start it I get "Keyboard Error"
If you want it to go aheand and boot with the bad keyboard or PS2 socket, go to the BIOS and change the "Halt on All Errors" to not halt on keyboard errors. Otherwise, you need to replace your keyboard and/or make sure it's not your PS2/keyboard socket on your mobo.
Dec 31, 2009 | IBM Aptiva E 805 (2170-805) PC Desktop
F11 does not work for restoring my PC
-you might try to hit F8 and get to safe mode
-From there, you can try to restore your PC from start<-all programs<-accessories<-system tolls<restore
-Choose the earliest date that your want your PC to restore back to.
Hope it helped
Mar 25, 2009 | Dell Dimension 3000 PC Desktop
I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem...
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Mar 11, 2009 | Computers & Internet
Restarte again and agian
check your cmos CR2032 battery on the motherboard as this can cause restarts because of bios settings,when booting press F2 or Del and check the date and time to see if incorrect. Also it maybe a faulty driver causing the crash, you can tell the bios to halt on all errors instead of rebooting, this can be found in the main cmos settings menu normally below the list of drives and check to see if halt on all errors is enabled, this way you can try to see what is causing the reboots.
Jun 24, 2007 | NEC Galileo 845GL (N4-IBFGL) Motherboard
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
HP Compaq Motherboard Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
