Question about Sanyo DS27910 27" TV
CANT ACTIVATE THE VIDEO INPUT
I GOT THE TV USED, NO REMOTE. I PLUGGED A DVD INTO THE BACK VIDEO INPUT BUT CANT GET IT ON THE SCREEN.
APPRECIATE ANY HELPFUL HINTS.
  • Anonymous Jan 18, 2009
    help
  • 55 Answers
I'm assummiong you can't select the dvd input. go to this website and you can get a copy of the manual to tell you exactly how to select it. http://www.retrevo.com/support/Sanyo-DS27910-TVs-manual/id/17567dj493/t/2/ It will tell you to select the INPUT/TV-VCR button and select source TV ot AV1 or AV2. good luck.
Posted on Jan 17, 2009
How do I go from TV mode to the DVD screen with my remote
My TV remote has a 'TV/Video' button that when pressed, toggles the TV's screen back n' forth between watching TV or viewing your DVD/VHS. Pressing the button once displays a video-1 screen, twice, a video-2 screen, and third, back to watching TV programs (having two video option screens allows for another DVD or VHS player to be assessed, as long as the TV has another rear connection for a second unit). As long as the DVD player is plugged into the back of the TV, the TV's remote (not the DVD's remote) should accomplish the function.
Nov 11, 2016 | Televison & Video
Will not play on my TV
Well that is not very much information to go on, but I will try to help. You need to have a video cable (either co-ax or HDMI) between the DVD player OUTPUT and an INPUT on the back of the TV. With this done, and the DVD player ON, you will need to push the INPUT button on the TV remote until you see the DVD screen. The input label will match the TV's INPUT plug name that you plugged the cable from the DVD player into.
Aug 30, 2015 | Televison & Video
Troubleshooting a Fujitsu plasma screen. No picture, or audio.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 29, 2015 | Fujitsu Plasmavision 42" TV
How do turn my tv back to video mode so i can watch my dvd with a universal remote.
Check your universal remote for a TV-DVD or SOURCE or INPUT button and try that.
Dec 25, 2014 | Funai 24ME403V 24" 720p LED-LCD TV - 16:9...
ON SCREEN HAD POWER ONLY V8.02.8
FOLLOW this instruction and fix it. God bless you
Connect the component video, HDMI1 or AV1 cable from the component device (such a DVD player) to the appropriate input port on the TV. This port may say "Video IN" on the back of the TV. Ensure that the cable is connected securely at both ends.
· 2
Use the remote control's device button(s) to access the menu and select the input through the menu that matches the type of cable input connected to the back of the TV. For example, if you connect the cable to the HDMI1 input port on the back of the TV, selecting anything but the HDMI1 option with the remote control may cause the "No Display" message to appear, which usually means that the TV is not receiving a signal at the connection input you have selected.
· 3 Turn the power on to the component you want to view. If the power was off, turning it on will activate the display and replace the "No Display" message.
· 4
Test any other connected components at their selected inputs to see that the TV is receiving the video signal properly from those sources.
· 5
Check with your cable or satellite provider if their set-top box is the source of the "No Display" message and is powered on, to see if the problem is caused by a disruption in their service. If using an antenna, adjust the antenna and re-scan for available channels.
Jul 20, 2013 | LG 55LE5400 55IN LED HDTV 1080P 120HZ 4...
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
How to get dvb chanels on my tv ?
If you're talking about the DVD then it will depend on what input you have it plugged in to. Follow the cable from your DVD player to your tv and read the name of the plug it is labled with. Hit TV/Video on your remote several times until it gets to that lable on the screen. example, If you have you DVD plugged in to Video 1, hit tv/video button on your remote or on your tv until the cursor highlights video 1. Movie should play.
May 19, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I just got a rca tv mdl# f36668 36" it didnt come with the remote.my ? is how do i watch a dvd in it
the easy way is to buy a universal remote
the cost is around 8-10 dollars
Aug 15, 2009 | RCA F36668 36" TV
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
How to record from my Sanyo DTV to my Sony Recorder?
first have the video recorder connected to the tv correctly,either coax out, red.white,yellow out, componant out or hdmi.[ see on back of the unit & the tv which connection you used.input selector is also known as video/source/line in or aux, sometimes even game. if there no such button on your remote, scroll down from channel 2 and you should be in some aux input.have the dvd playing,then you should see the video when you get to the right input.
wg
Feb 17, 2008 | Sanyo DP26746 26 in. LCD Television
Sanyo DS27910 27" TV Logo
275 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
