TV runs for a limited time, then goes to standby
Please help with my LG 29FX5BLE-TG 74cm. It switches on and plays for some time, thereafter goes on standby. I have checked for dry joints and tested transistors and diodes, yet still stuck with the same problem
  • kgotso_raphe Dec 04, 2008
    Sorry for not getting back to you sooner had to go first try the advices
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
The LG 29FX5BLE appears to be a Korean domestic model. There are a number of possible causes for the auto shutdown as you have described. Assuming that this is a conventional single CRT TV, lets start with the vertical amplifier IC. This would be very near the 4 wires the goes to the yoke. This IC would have an aluminum heatsink and could be anywhere from 7 to 15 pins single inline package. The have been known to develop cold solder especially the Vcc pin. It may also be worth your while to trace the Vert B+ line to the resistor diode from the secondary of the FBT.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 28, 2008
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
Lg 50pk550 wont turn on
Repair kit Now available on Ebay.. BUY NOW
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200884727409
If you have any one of these LG Models TV below, and all of a sudden, the screen lights for only a few seconds, then goes into standby with a clicking noise. [Stuck in standby] When you try to switch it on, it tries but then just clicks and goes back to standby? In this video, I show you the components that goes bad, and the culprit that causes it all. The power supply board has already been bought from Ebay, but I'm still selling the voltage regulator that is dang near impossible to find on ebay, as well as the REPAIR KIT for this power Supply Board. Board model number EAY60968801. With any one of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Remember, the component, and the repair kit will only repair power supply model (EAY60968801) with the appropriate PCB numbers. You buy at your own risk
Mar 10, 2012 | LG 50PK550 50 in. TV
Tv will not switch on
the problem on this tv is the power supply , the power sypply has some bad capacitor and that way is not working , need to take cover off at take a look at power supply there you would see the capacitor with the top pop
Feb 03, 2012 | LG Televison & Video
When I switch tv on at button on tv I van hear the tv goes on. No Picture. If I press buttonds on the remote I can see the red light come on that indicate the remote is sending signal. Here comes the best...
Replace , front panel switches , one or more switches goes high resistance
when suppose to be open circuit , my sv2918 74cm was doing weird things
with these switches going bad
May 10, 2011 | Sansui D 27" TV275 TV
When i plug my lg lcd tv in, it does not turn on, instead the standby light on the front of the tv flashes as if its coming on and then goes. i have tried plugging it back in many times but cannot find a...
Have you tried switching it on using the remote control for your TV? It appears your TV is on standby mode and only the remote might do the trick to get it to fully power on.
Post a feedback or update if this tip does not help you out.
Oct 12, 2017 | LG 32LX1D 32 in. LCD Television
I somehow stretched the picture on my LG FLATRON TV model 29FX5BLE-TG-UFBLLBK using myremote. How do I get it back to original size?
press ok on the tv panel& press ok on remote same time to enter service mode, then adust hs (horizontal size) eu, ev to get the perfect size
Apr 07, 2010 | Televison & Video
Hi, I have an LG Flatron TV which I bought 6 years ago. Good picture, no problems until now. I put the set on standby via the remote. Later, when I put it on via the remote all I got was sound and no...
Since the screen keeps turning off and sound only remains have a look at the inverter board for any buldging capacitors which look like blue cans, there is most probably a short in the inverter and the powersupply is sensing this thus turning it back into standby to prevent damage to the tv.
jonno
Nov 04, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
I HAVE LG PROJECTION TV MODEL 52SZ30 REPLACED PROJECTION KAMP RESET LIFE TIME OF LAMP .BUT TV GOES TO STANDBY AFTER ONE MINUTE OF OPERATION CAN ANY ONE HELP PLEASE
Normally when this happens, this is because of the power supply board is going threw some abnormal fluctuation. i would check this board for minor solder breakage.
Feb 06, 2009 | LG RE-44SZ21RD 44" Analog Television
Is the fan running ,if the fan has dirt on it clean it off with contact cleaner.Set will stop playing if fan stops.
Nov 28, 2008 | LG Televison & Video
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
