Question about Fujitsu LifeBook U810 Mini-Notebook Tablet PC
Fujitsu U810 problem ( not booting )
How to boot our Fujitsu U810? a message appear during bootup. message: "use cd-rom and repair windows". acpi.exe
  • feelvoi Nov 28, 2008
    thanks very much frenzy19! but i think it has a Vista installed in it. and i think there is no cdrom included with the laptop. i also think that the Vista has a recovery partition built-in to the laptop, we couldn't initiate the recovery partition that is why we are having difficulty repairing the windows. if incase we use an external cdrom drive and try to format it with a Vista media kit(MS Vista cd), we might erase the default recovery partition of the laptop.
    Sergeant:
    Champion:
  • 258 Answers
That means that you need to repair it in order to get the laptop back to its normal condition insert windows xp disc and repair the system that's what i think
Posted on Nov 28, 2008
  • Efren Javier
    Efren Javier Nov 28, 2008
    ok if it's vista you should have the vista cd and run the setup it's easier to repair than in xp where all files must be replaced anyway thanks for posting
No bootable device, hit any key
The bios cannot find any device it can boot from. This can occur because of hard disk failure, a loose connection or file corruption. There usually is a boot menu that you can get to from the bios by hitting some key specified by your bios manufacturer during the POST bootup process. Usually there is some message on screen like 'press esc for bootup options' or 'press f2 to enter bios setup' or something similar. As your machine starts up, try hitting ESC, F2, F5, F8 or F12 -one at a time-hitting each key several times during bootup (maybe your manual can give you a hint). If you get into the BIOS setup screen, look at the screen that tells you what the BIOS thinks you have attached for storage. If you don't see a hard disk there, you have a definite hardware problem. If you get into a boot option screen, try putting a Windows Installation CD, or a recovery CD from your laptop manufacturer, in the CD-ROM drive of your computer and enabling the machine to boot from the CD-ROM. If the PC boots from the CD-ROM, you may be able to use Windows Recovery mode or your manufacturer's recovery disk to get your hard drive working again. If you have any files you can't live without on your hard drive, look into getting your hard drive out of your laptop and into a USB drive enclosure that you can use another PC to try and read those files from the hard drive prior to attempting any recovery options, as some of them erase all files on your hard drive. Also check to see if your PC has manufacturer diagnostics that you can boot into to check your hardware with before attempting any other type of repairs.
Sep 04, 2014 | Gateway Computers & Internet
I tried to re-install windows xp to clean my computer (running slow). It aske if I wanted to include web updates and I answer yes. Computer went to a blank screen and no won't load from recovery disc or...
Hi, you will need to reformat your hard drive before installing XP, First boot into BIOS by pressing the F1 key during bootup, change the primary boot drvice to CD rom, save changes. Insert XP cd into drive and reboot PC; select boot from CD when this appears during the initial boot fase. Allow files to be installed. When this finishes, delete partion and then repartion hard drive. Select format hard drive, when this completes your PC will reboot, do not select boot from CD and XP will start to install normally.
Hope this helps, if not come back to me.
Aug 04, 2010 | Computers & Internet
Misssing partmgr file how can I load this thanks
To resolve this issue, start the computer from the Windows XP CD, start the Recovery Console, and then use the Bootcfg.exe tool to rebuild the Boot.ini file. To do this, follow these steps:
  1. Configure the computer to start from the CD-ROM or DVD-ROM drive. For information about how to do this, see your computer documentation, or contact your computer manufacturer.
  2. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive, and then restart your computer.
  3. When you receive the "Press any key to boot from CD" message, press a key to start your computer from the Windows XP CD-ROM.
  4. When you receive the "Welcome to Setup" message, press R to start the Recovery Console.
  5. If you have a dual-boot or multiple-boot computer, select the installation that you have to use from the Recovery Console.
  6. When you are prompted, type the administrator password, and then press ENTER.
  7. At the command prompt, type bootcfg /list, and then press ENTER. The entries in your current Boot.ini file appear on the screen.
  8. At the command prompt, type bootcfg /rebuild, and then press ENTER. This command scans the hard disks of the computer for Windows XP, Microsoft Windows 2000, or Microsoft Windows NT installations, and then displays the results. Follow the instructions that appear on the screen to add the Windows installations to the Boot.ini file. For example, follow these steps to add a Windows XP installation to the Boot.ini file:
    1. When you receive a message that is similar to the following message, press Y: Total Identified Windows Installs: 1
      [1] C:\Windows
      Add installation to boot list? (Yes/No/All)
    2. You receive a message that is similar to the following message: Enter Load Identifier This is the name of the operating system. When you receive this message, type the name of your operating system, and then press ENTER. This is either Microsoft Windows XP Professional or Microsoft Windows XP Home Edition.
    3. You receive a message that is similar to the following: Enter OS Load options When you receive this message, type /fastdetect, and then press ENTER.
      Note The instructions that appear on your screen may be different, depending on the configuration of your computer.
  9. Type exit, and then press ENTER to quit Recovery Console. Your computer restarts, and the updated boot list appears when you receive the "Please select the operating system to start" message.
Apr 13, 2010 | Computers & Internet
Computer doesn't boot up. tells me windows/system32/winload.exe is corrupt or damaged. what can I do?
go to bios menu then give priority for cd- rom then enter f10 to save the setting after doing the setting the computer will automatically boot from the cd .if it does not bootup somtimes the problem is with your cd or cd rom
Jan 18, 2010 | Toshiba Satellite A215-S7422 Notebook
Missing boot.ini cant find it and missing logon.exe
      [1] C:\Windows
Oct 03, 2009 | Acer Aspire One PC Notebook
Windows vista ultimate will not boot up
Press enter and submit the changes :) computer should repair itself from a back up file and start as normal.
Regards
Jun 08, 2009 | Acer Aspire 3680 Laptop
Fujitsu Siemens Scenic T on windows 2000 Pro SP4
to fix it:
u should boot up with windows 2000 cd
go to repair windows then go recovery console from cd rom
now u'r in dos mode:
if u'r cd rom drive is d: and u'r hard disk is c:
just type this:
c:\copy d:\i386\ntldr
it's ntldr not ntdlr
then type:
c:\exit
u'r pc will restart and everything should work fine.
Hope this Helps. Regards Khushroo
Mar 09, 2009 | Fujitsu Siemens Computers & Internet
Cannot open my computer, laptop model PCGK45.
thats simple ur windows xp is corrupted there is only one thing u can do that is put in the xp dvd and reinstall xp
Dec 17, 2008 | Sony VAIO K45 Notebook
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
Fujitsu LifeBook U810 Mini-Notebook  Tablet PC Logo
191 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
