Question about Balance CP4401 PC Desktop
Computer screwed up0 sense installing Explorer 7
Installing Explorer 7 was a big mistake. My DSL Service told me they were advising everyone to uninstall it. I have went back to Explorer 6, but the problems have stayed. I keep getrting error reports, this problem was caused by Logitech SetPoint and was created by Lame Project, there is nothing in my computer that has this name. I have searched everywhere. When I start my computer up ,it take 4-ever to get rid of pop-ups stating ,found new hardware, I did not insatt any new hardware. When you do get on line an error will pop up and you can push cancel or send to microsoft then everything go back to Icon page. Also you cannot use restore point because the computer starts shutting down and stops on shutting down page. The only way to shut completely is to unplug power. My computer worked find until I downloaded Explorer 7. Everytime an error pop up it refers to Logitech SetPoint created by Lame Project. Is there any other way to fix this problem other than Reformatting.
  • Steve Toth Jan 14, 2007
    No I have not had anthing like that hooked up to it. What I have came with the PC
  • Steve Toth Jan 15, 2007
    thanks for the solutions, but I guess it was to far gone for anything to work. My advice to everyone,STAY AWAY FROM IE7!!!!!!!!!!!!!!!!!!!
  • 624 Answers
Internet Explorer 7 is a better browser than most but has some real issues that need to be resolved before I?ll force it on my users. I too experimented with it, removed it and then discovered it hadn?t quite removed itself. I?m visiting my parents this weekend and found their computer is suffering from the same problem. In my first case after I removed IE 7 IE 6 would no longer work at all. I reinstalled IE7, rebooted and removed it again. The problem went away. In my parents case that didn?t work. What I wanted to do was reinstall IE6 from scratch; however, as you probably already know you can?t do that since its now an integral part of Windows. If you try to reinstall it you receive the following error: ?Setup has detected a newer version of Internet Explorer already installed on this system. Setup cannot continue.? There is a way to force a reinstall but it involves changing a registry value; please note that changing a registry value incorrectly can result in really bad stuff happening. So please take heed, make sure you have your data backed up and your recovery disks at hand just in case you computer no longer boots. - Click Start, Run, type regedit in the box and click the OK button. - Open the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{89820200-ECBD-11cf-8B85-00AA005B4383} -In the right hand panel find and double left click on the *isinstalled* Value Name. -Change the Value Data from 1 to 0 Exit Regedit program. -Now you can reinstall Internet Explorer 6. Sometimes the Microsoft download site for IE 6 can be hard to find so here is the link: http://www.microsoft.com/windows/ie/ie6/downloads/critical/ie6sp1/default.mspx Good luck, let us know how it goes or if you have any other questions. As always please rate the posting.
Posted on Jan 15, 2007
    President:
  • 2,961 Answers
Have you now got or had before a logitech mouse,keyboard or web cam attached to your system? I have constant problems with IE7, and because of the non responsive browser, it throws up a problem with my laptop touch pad.
Posted on Jan 14, 2007
I have made a mistake and put fluid in the big nut on top of gear tronic how do I rectify
Oops, this is a big mistake, but fortunately not the end of the world.
The 27 mm bolt anchors the B4 transmission band, which is what gives you third gear. If you were to drive the car now, you can't shift into third, but you can skip over it (geartronic) and shift into 4th.
There is a way to use a small screwdriver to try to shift the band back into place to where the threaded part rests right under the bolt hole.
If that fails, then you can drill a small hole in the 27 mm bolt and use a screwdriver through that hole and hold the band in place while you snug the bolt, then seal the hole (tap it and use a small screw, etc.).
If that fails, the trans comes out and has to be disassembled and reassembled.
Read more at the link below and good luck!
2002 XC70 Transmission Nightmare EVERYONE PLEASE READ Page 7
Mar 07, 2015 | 2003 Volvo XC90
Cannot download security essentials or 7 update advisor Win XP
Security essentials does not work with Windows XP. Moreover XP will not be supported OS after the 14th this month. So if you still have XP, it is advisable to move to Win 7
Apr 03, 2014 | Microsoft Windows XP Home Edition
Installing windows 7 on hp pavilion d7 1120wm not permitted
I know this is common in Windows 8 PC's, never saw it in Vista. I would recommend upgrading the BIOS if an update is available from HP. Really makes no sense as Win 7 is based on Vista's framework. According to HP, they made 20 versions of this model, if you can get back to me with the complete model number (from the sticker on the bottom) that would be a big help.
Feb 10, 2014 | HP Pavilion dv7-1129wm Notebook
My Towhiba Satellite p755-s5120 laptop will not boot after I installed a BIOS update.
Big mistake. You NEVER upgrade bios unless it is absolutely necessary. It is basically a dangerous procedure because very often the upgrade does not take or work properly and you are left with a paper weight.
You have learned this lesson the hard way and now you have to deal with it.
Your cmos is corrupted - if you can go back to the original bios, great. If not, go shopping! (Of course, you can always get a new mo bo but with the cost of parts and labor, it will not be cost effective.) And stay away from HP - their service sucks big time since they will only provide assistance during warranty period. After that they refer you to forums or advise you to get another computer - an HP of course!
Sep 16, 2017 | Toshiba Satellite P755-s5120 Core I7 Pc...
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 27, 2011 | Computers & Internet
I cant get this sylvania 7 smartbook , model # synet07wicv to get internet.
Dec 25, 2011 | Sylvania G-Netbook
Wire less internet not connected
It woule be great if you provide the exact model # of your notebook, operating system details and specific error.
However, you may try some of the basic troubleshooting for the Windows 7 Operating System from the below link.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1007553
Jun 15, 2011 | Sony VAIO Notebook
Need to know how to install rounter with out start
following are steps for manualy setup of router
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
regards
prakash
Dec 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Formatting c drive
yo can do this when you installing windows it asks you weather you want to format
Jan 13, 2009 | Computers & Internet
Balance CP4401 PC Desktop Logo
91 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
