Question about Maytag MZD2766GES Side by Side Refrigerator
Loud, continuous buzz from Imperial heavy duty commercial freezer
Buzzes immediately when turned on, even when it's been unplugged for several hours.
    Sergeant:
    Champion:
  • 311 Answers
Sounds like bad compressor. Turn off t/stat. If buzz starts when you turn it on then that is what is wrong. May be under mfr wty. Call Maytag to find out.
Posted on Nov 28, 2008
Have a Imperial heavy duty commercial model uf20x runs all the time turn control knob does not make a difference.
possibly defective switch and only a repair shop can assist you .we do not have one here
Dec 18, 2017 | Food Mixers
Our old Imperial heavy duty commercial model uf20x needs seal. Where to find it?
Commercial refrigerator parts supplier can make it same day. Check google for your nearest supplier.
Feb 01, 2014 | True 72 cu. ft. / 2039 liter Commercial...
What is the best way to defrost a heavy duty commericial Imperial freezer?
a commercial freezer should have it's own defrost cycle. I would look into what the issue is that is causing you to do a manual defrost.
The 2 most common AND safe ways to defrost any freezer is either using hot water or a hot air source such as a hair dryer.
Dec 04, 2010 | Freezers
Freezer ajar loud noise
Yes Evaporator fan that has ice accumulation in it. Turn off the unit and leave the freezer open for about an hour or two re-start it and hopefully the frost that built up from the freezer being ajar will have thawed and melted away.
good luck to you!
Jun 17, 2010 | Sub-Zero Bottom Freezer Refrigerator
I have lost my turnkey for an Imperial Upright heavy duty Commercial Freezer. It is locked and I have no way of getting inside... Where can I get one?
you can visit the website of the company and make a request for the key or get the door forced it to get open and get a new locker key for it.
Feb 16, 2010 | Amana 19.7 cu. ft. / 558 liter Upright...
Frigidaire FRS26R4CW1, buzzes. When I noticed that the freezer was warm the unit was unplugged. The refrigerator was left unplugged for about 20 hours. When it was plugged back in it was ran, was quiet and...
Yes, what you are asking is possible. It is also possible that the compressor motor has a flat spot or is even siezing up when hot. If you are comfortable changing the cap. then I would do that first a see what happens. Changing the compressor will be much more costly and maybe more than you want to put into you refrigerator.
Nov 17, 2009 | Refrigerators
My pots and pans are covered with soot. We us propane for our 6 burner heavy duty gas range
u stove is designed for natural gas you need to retro fit or change the gas valve over to propane or locate a propane adapter kit for ur stove check with appliance part stores or product company
Oct 29, 2009 | Imperial Commercial Cooking Equipment...
No sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
Mar 30, 2009 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
Maytag MZD2766GES Side by Side Refrigerator Logo
602 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
