Question about Acer TravelMate 2300 Notebook
Cursor in laptop freezed
When I have a USB mouse connected to the laptop works well but when I do disconnect the mouse and want to use the laptop pad only it doesn't work the cursor appears freezed, I can't remember how to activate the padding to make it work
  • 20 Answers
There are a few different ways that the touchpad can be deactivated especially if your notebook was pre-loaded with bulky management software.
First of all, most notebooks have a function shortcut for this. On mine it is function + F9. You should be able to see a picture on the keys that will describe this.
Secondly, as you did not specify which operating system you are using (or you did but it is in the hidden at the end of the details!), I will try and give a generic response:
- open control panel
- navigate to "mouse"
- open the "device settings" tab or similar
does this display anything about being deactivated? If it does, just activate it!
Posted on Nov 28, 2008
How do I fix my frozen mouse pad
Try pressing the Fn key (lower left ) and F7, this enables & disables the touchpad.
Jul 10, 2014 | Acer TravelMate Computers & Internet
Mouse touch pad not working
Try to Upgrade your Mouse Pad driver.
Your problem would be solved by doing so.
I have faced the same problem. I did upgrade Mouse Pad driver and Yes my mouse pad working fine.
Apr 24, 2013 | HP EliteBook 6930p Notebook PC
The cursor will not move and I cannot use the laptop at all.
The cursur moves from the sensory pad, if the pad went out the cursur will not move.. I would start by installing an external wireless mouse or even a basic plug in mouse to the usb port and see if you can cntrol the cursor then. Cheap wireless mouses with a small included usb donggle can be used in place of the sensory pad cursor
Oct 07, 2012 | Computers & Internet
Cursor freezing
Hi
It could be trouble with Motherboard or the chip under the track pad.
Try to re-install the mouse driver. and try to check.
In case if you have any trouble then do contact us here in Fixya.
Thank you
Aug 11, 2012 | Advent Computers & Internet
Jumping cursor on laptop
clean the mouse pad ,,, if doesn't work uninstall pad's driver and re-install the correct one... some laptops comes with joystick if yours have one clean it with a contact cleaner or disable it by unplugging it's cable ,,, if it didn't solve your problem replace the mouse pad or use a usb mouse ... :)
Mar 06, 2012 | Sony Computers & Internet
I have a Fujitsu Lifebook N6410. Sys. MS Window XP 2002. Is there a way to prevent the cursor from jumping when typing. It apparently is caused by accidentally sweeping over the touch pad.
Go to Control Panel > Mouse > USB Mouse Connection > Select Mouse pad is automatically invalidated.
This setting turns off the mouse pad whenever a USB mouse is connected.
Aug 15, 2011 | Fujitsu LifeBook N6410 Notebook
Acer aspire 1642 frozen mouse
Connect an external USB mouse to get at least the cursor to work, then download the latest touch pad drivers from Acer's site
Check that you have not disabled the mouse pad (FN and F7?)
If that fails, you may need to dismantle the laptop and check the small ribbon cable that connects the touch pad to the motherboard has not come adrift.
After that it looks like physical failure of the trackpad / touch pad assembly
Jul 18, 2011 | Acer Aspire 1642ZWLMi Notebook
The touchpad on my laptop does not work. Cursor is frozen. I have a CQ60-615DX notebook. What do I do? Please help!
Make certain the driver for your touchpad is running- usually it is synaptic- would be found under syntpenh.exe in your task manager. Make certain it is enabled in the mouse properties. If that does not work, then connect an external mouse and then disconnect it... sometimes that kicks the service back into starting correctly
Oct 02, 2010 | Compaq (153515-001) Touch Pad
Logitech LX5 Cordless Mouse
Try
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Nov 22, 2007 | Computers & Internet
Computers & Internet Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
