Question about Adaptec Computers & Internet
Hard drive stopped working. now it just clicks, does not come on
Failed hard drive
  • 95 Answers
If it's clicking none of the software will help - it's a mechanical failure. Most likely it has bad heads. This site should help you better diagnose the problem.
Posted on Nov 29, 2008
Clicking noise coming from hard drive
Clicking noise is giving you an indication that your hard drive is about to fail as clicking is one of the symptom of physical hard drive failure. This type of hard drive failure situation needs to be handle on time to rescue yourself from a data loss situation. Also i would suggest you to shut down your system stop doing anything on your system and immediately take expert data recovery assistance if you really want to save your data.
Feb 26, 2013 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
Dell Inspiron 570 loud hard drive hum.....(?)
Any strange noise like excessive clicking, grinding, some weird sounds etc. actually indicate a failing hard drive.
Failing hard drives often show warning signs of their imminent demise. If you're lucky enough to see or hear one of these signs, stop what you're doing and immediately back up your data. They say prevention is better than cure so if your computer's hard disk is making some strange clicking sounds, BACK UP YOUR DATA IMMEDIATELY (As the drive is not operating smooth and may fail anytime).
After making backup of your important data on CD/DVD or External Drive, you may scan the drive for surface errors, format it and see if it works properly or not. It would be better if you seek professional assistance for examination of the disk.
Hard drives are mostly under warranty for at least one year. Claim warranty, if possible.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Nov 23, 2011 | Dell Computers & Internet
I have a western digital 500 GB external Hard disk bought 2 years ago. Nowadays, it starts arbitrarily generating clicking sounds and then at that time my computer stops recognizing this device. The...
This is indicative of the hard drives, tracking head becoming stuck or misaligned.
I would advise backing up all the data you currently need off oth disk then replacing it as it is only a matter of time become the disk becomes completely unreadable,
Feb 28, 2011 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have a verbatim usb 2.0 1 TB hard drive and I can't disconnect it from my laptop. I get a message- windows can't stop your generic volume device because it is in use. I just installed Roxio for computer...
Look down in the corner, the right corner for an icon that looks like a small drive slanted with a green arrow over the top of it. If you click on this ICON, it will bring up a small window that says safely remove devices, click on your verbatim drive and it will give you a message. If it fails to do this then Ctrl+Alt+ Delete keys pushed all together one time brings up a window with six buttons. Select "Task Manager" and it will allow you to stop certain processes. Look for the Verbatim drive and halt it. Failing this, you can shut the machine down and remove the disk.
Jan 01, 2011 | Computers & Internet
When I turn my Toshiba external hard drive on, the led lights up and there is a very faint repetitive click but nothing else happens. Any ideas?
Hi
A clicking hard drive means that the mechanical parts of the drive are breaking down. This also means that the drive slows down and will eventually stop working. If you need to retrieve data from your clicking hard drive before it fails, you can do this with an external hard drive enclosure. This enclosure will turn your hard drive into a drive that is readable through a USB drive.
1)Place the hard drive inside the enclosure.
2)Push the enclosure's two rectangular cables into the back of the hard drive. These will power the drive and allow a computer to "see" the files.
3)Screw the enclosure tight with a Phillips head screwdriver. This will secure the hard drive within the enclosure, preventing it from moving around or falling out.
4)Connect the enclosure power cord into a socket. Place the enclosure's USB cord into the computer.
5)Click "Start," then press "My Computer." The drive will be located under the hard drive portion of "My Computer." Double-click it to open the drive. Drag the data you want to the computer for safe keeping.
In most cases the hard drives which clicks cannot be restore to normal functionality,so please ensure that you recover your data at the earliest before the hard drives fails completely.
Sep 26, 2010 | Computers & Internet
My pavilion s3100n when turned on just makes this clicking sound and the screen says "failed to boot replace disk and press enter" any clues
The clicking sound is most likely the "Click of Death" an indicator of a failed hard disk drive. The drive is having a hardware malfunction and the read/write armature in the drive is moving back and forth against the internal stops (this gives the click)
Replace the hard drive in the system
Oct 08, 2009 | HP Hewlett Packard Pavilion Slimline...
MY HARD DISK DOESNT WORK PROPERLY
This may be useful to you:
It is never a good sign when hard disks start to make notice. It means that your drive is starting to fail. Although there are variations, most drives are completely silent when they're running.
The tipoff is either a new noise are an intermittent noise. If the drive has always made a slight clicking noise when accessing data, that's probably nothing to worry about. If it just started clicking, or if it only clicks occasionally, this means something has changed. Change in a hard drive is a Bad Thing.
Grinding or squealing noise is definitely a bad sign and usually means the drive is on its last legs.
There are two ways to protect yourself against a failing drive; the first is to create a backup image of the disk and the other is to move all everything from the failing disk to a replacement drive. Also, make sure you have an up-to-date rescue disk so you can boot your computer even with a failed primary hard drive (the one with the operating system on it).
Creating an image won't stop the disk from failing, but it will give you a starting point from a known, good configuration if the disk fails. Cloning the disk to a new drive not only moves everything off the damaged drive, but it moves it in total so that you can start working on the new drive immediately.
If you suspect a drive is going flaky, it is relatively easy to cone your disk. Please see Drive to drive: Bring in the Clones for step-by-stepinstructions on duplicating your disk.
Using your image file, you can also deploy a new drive by restoring that image onto the new drive. Acronis True Image provides necessary tools to create and deploy a new drive.
The good news about discovering a potential hard drive failure today is that hard drives are inexpensive these days and installing a new one is easy. Many retailers and web sites sell high-capacity hard drives, up to 200 Gb, for $100 or less. If your drive shows signs of failing, replace it immediately, your data is far more important than the price of the disk drive.
Rate this!!
Aug 16, 2009 | Quantum Fireball 1.2 GB SCSI Hard Drive
Drive failed.
If using Windows -- Run Disk Tools by right clicking on the drive goto properties and perfrom disk check.
Aug 04, 2009 | Western Digital My Book Essential 1TB...
Odd clicking noise...
That clicking sounds if ever loud enough is one annoying symptoms of failed disc. When it accidentally drop the reader may come off the disc. It sad to say but you may consider to change your hard disc.
Jun 12, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Loud clicking
You're going to have to narrow it down by removing components. Start by removing the hard drive, if the clicking stops then you know that it's a component that needs or uses the operating system. If it stops then put the hard drive back and remove other components, CD drive, keyboard, etc... until you can either locate exactly where it's coming from or it stops. The CD drive could be the culprit, and removing the keyboard will expose some of the inner workings so you can hear it better and possibly find what it is. This isn't a simple fix, it will take a little effort, but I believe you will find the problem, this is the exact same way that I would do it if you were to bring the computer to my shop.
Jul 24, 2008 | Toshiba Satellite Pro 4600 Notebook
Computers & Internet Logo
138 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Martin Murray
Robert Graf
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
