Question about Nikon 2880AF F3.3-5.6G Zoom Nikkor, Picture Angle: 74°-30°10' (28 80 AF, 28-80-AF) Lens
What does it mean when FEE is in the view finder
    Guru:
  • Nikon Expert
  • 362 Answers
FEE means that your lens is not set to the smallest aperture setting. If you are using your camera's auto-focus mode, the lens must be set to the smallest aperture setting which, on your lens, is probably f22 (the smallest aperture is the largest number). Once you set the lens aperture, you should slide the aperture lock to the locked position. The aperture lock is located just right of your largest setting f3.5. This slider should line up with the orange line. To verify that the latch is engaged, try to change the aperture by rotating the aperture ring. In the locked position, the ring will not turn.
Posted on Nov 28, 2008
Fujifilm FinePix S1600 The monitor display is not working. Can it be replaced and if so how easy is it?
It could be that you have it set for EVF which means that you are using the tiny view finder instead of the LCD screen? It should have a button close to the view finder labeled EVF/LCD, you can alternate between the LCD screen or the tiny viewfinder? This function if mainly to conserve battery power or if you are out in the sun and cannot frame a shot and so you use the view finder like the old cameras, hope this might help you?
Dec 09, 2014 | FUJIFILM Cameras
Off lens,view finder is not workink
The view finder is the little window on the top left of the camera. If you want to use the display as a view finder, you have to press the button with the camera logo. It is called the life view mode. you use the same button to switch off the display. Be aware using the display, will drain the batteries quicker. Somewhat faster then with modern cameras.
see page 19 of the manual.
Dec 02, 2013 | HP Photosmart M307 Digital Camera
My camera view finder shows"Check
Good day,
The CHECK DIAG appears in the view finder when the camera's automatic self diagnostic function detects an abnormality.
From here you must first perform error checking on your camera by doing the following:
Press the menu dial.
This will perform the error check on the Digital Signal Processing(DSP) and the Memory Circuits.
When no error is detected OK will appear.
If an error is detected it will be displayed next to DSP or Memory on the screen. Diag Error will also appear.
If Diag Error appears contact your Sony dealer!
What this means is that the camera is doing a routine check or has detected an abnormality with the system.
I hope it is just performing a routine check and there is nothing wrong with your camera!
Best of luck and let me know if this was useful!
Kind regards
Dec 01, 2010 | Sony DSR-500 Mini DV Digital Camcorder
There is an error code FE E which will not allow pics to be taken. It shows up when the camera is turned on and when look thru the view finder, it also shows in the bottom.
This is a Nikon SLR error for something is broken. Here is a link. http://www.loeki.tv/log/archives/85-FEE-error-on-Nikon-DSLR-fixed.html
May 02, 2010 | Cameras
TApe recording
try using a different tape, some tapes are what you call "wet" meaning they have a lubricant inside them and some cameras don't like them. Try to use Maxell Brand tapes I have used the for over 4 years and never had a problem
Apr 07, 2008 | Canon XL1S Mini DV Digital Camcorder
N75/ fEE
The camera requires you to set your lens aperture at the minimum setting, usually orange coloured. I.E. f22 f32. Nikons control the aperture through the camera, not setting the ring manually like old style SLR's
Feb 25, 2008 | Nikon N75 with 28-105 lens 35mm Film...
Sigma 170-500mm APO lens on Nikon D50 won't autofocus or shoot
When you get a flashing EE, it means there is an Eror somewhere. Most cameras have a botton you press to reset it. Usually it is the battery check button. Try that. Also try taking the lens off the camera, unlocking the aperture ring, remount the lens and then lock the aprture ring to the minimum F stop. I think this should solve the problem.
Aug 06, 2007 | Sigma APO 170-500mm f/5-6.3 DG for Minolta...
Canon S1 IS view finder / LCD monitor black out
This is a defective CCD that Canon is repairing free of charge. Go here for details: http://www.usa.canon.com:80/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8044&keycode=2112&id=29819
Nov 24, 2006 | Canon PowerShot S1 IS Digital Camera
Cameras Logo
328 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
