Question about Nokia 5610 Blue Quadband 3.15MP A2DP + Gift + WTY Cellular Phone
Memory card not detected
Hi, I am using nokia 5610 which has inbuilt 1 gb card .I removed that card and put it back into given slot but phone is not detecting that. What could be the problem ...Please let me know the solution.
waiting for reply...
Thanks in advance...
  • ajay_kakkar Nov 28, 2008
    thx for providing the ans. but it couldn't solve my problem ...I was doing exaclty the same for 9-10 times.
    I got solution...the problem was : After puting memory card back into mobile...I remained open backside cover of my mobile to avoid extra work (like i had to again and again remove the cover then take out the card and put it back).
    After so many attemps...once i placed backside cover after putting card into its slot ..it automatically start detecting the card...without restarting it.
  • 495 Answers
Have you inserted your memory card properly?. If you have inserted it properly , then just restart your mobile
Posted on Nov 28, 2008
Its internal memory is 6 mb it is said that it suppots memory card upto 2 gb but it isnt detecting the card.should i activate it where and how
there's no activating stuff and all...
  • make sure that your memory card is working.(put it in your friends phone and check it)
  • then 2nd your memory card slot fine and working.
these are the only reasons which can be behind it.
  1. faulty memory card.
  2. faulty memory card slot.
have a great day!!
Jun 13, 2011 | Nokia 5200 Cellular Phone
How do I insert a memory card into my Nokia 5310d? Thank you
Insert a microSD card
Use only compatible microSD cards approved by Nokia for use with this device. Nokia uses approved industry standards for memory cards, but some brands may not be fully compatible with this device. Incompatible cards may damage the card and the device and corrupt data stored on the card.
1. Remove the back cover of the phone.
2. Insert the card into the microSD card slot with the contact surface facing down, and press it until it locks into place.
Jun 12, 2011 | Cell Phones
MEMORY CARD NOT SHOW........?
Hi. Nokia 3110 uses microSD card up to 2GB only. Please check the size/capacity of your memory card and make sure it is 2GB or lower. Higher capacity will not be recognized.
If your memory card is below 2GB, remove the card from your phone and use a card reader to connect that to any computer and see if you can see the drive. If your memory card appears in the computer but not on your phone, you may have a bad slot but if card did not appear in your computer, you may have to consider replacing the memory.
Good luck.
Sep 03, 2010 | Nokia 3110 Cellular Phone
try to backup the data from the card and then format the card.and clean the phone slot for memory cards with some alchohol.but be carefull.
Feb 08, 2010 | Nokia Cell Phones
Memory Card not formatted Error
check ur memory card on a laptop. may be the cradle of memory card has not been fixed after lcd replacement. if ur memory card is reconignized by the laptop that means there is some problem in ur mobile
Jul 21, 2009 | Cell Phones
Memory Card not detected !!!
back cover has a peg or spike that push down one pin on the right of the camera lens, if your back cover is not properly closed, warped or you have something (such as a spare simcard) wedged inside, the memory card will not be detected. To save the hassle to get a new cover, wedge something tiny on that pin before putting back your back cover. If this does not solve your problem, better send your phone to a service center.
Jul 06, 2009 | Nokia 6300 Cellular Phone
Memory Card Lock
If this is the mini sd card that stores your pics,music and video then try connecting your phone to your computer using a USB cable. Your phone should b detected by the computer and you should select data storage mode on the phone.
(You can also take the card out and use a memory card slot if your computer has the right one.)
Find the phones drive on your computer it should be listed either as Nokia 5610 or as a removable device. Right click on it and selec FORMAT. WARNING: THIS WILL erase any files you have saved on the MEMORY CARD!
Good Luck! I hope this helps :)
Apr 17, 2009 | Nokia 5310 Cellular Phone
My memory card is asking me for password
if you cant remember the password then format it to be able to use it again. there is no program that would be able to detect or know your password. better format it!
thank you for using fixya
CHARCOIS
Nov 19, 2008 | Nokia 6300 Cellular Phone
Nokia 5610 memory card
5610 back cover has a peg or spike that push down one pin on the right of the camera lens, if your back cover is not properly closed, warped or you have something (such as a spare simcard) wedged inside, the memory card will not be detected. To save the hassle to get a new cover, wedge something tiny on that pin before putting back your back cover. If this does not solve your problem, better send your phone to a service center.
Aug 12, 2008 | Cell Phones
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Nokia 5610 Blue Quadband 3.15MP A2DP + Gift + WTY Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
