Question about GE Profile JB968SHSS Electric Kitchen Range
Oven and Clock Display don't light up!
Just got the oven and the burners work fine , but the oven and display do not light up or work. I had to change the outlet from a 3 prong to the new 4 prong. Do I have it hooked up wrong? Would that cause this to happen? From my wall, I have a ground, black, and red wire. I hooked it up the way home depot said, but it doesn't work.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Oven, Broiler inopperable
Sandwich, is it your bake or broil thats not working? You have two ignitors, one for bake and broil. One of them is your culprit. This is not a hard job. The post header says broil not working so the part number for that is WB13K0003. Bake ignitor is WB13K0004. To get at the bake ignitor you have to remove the oven bottom inside panel, remove the flame spreader (both easy). The click you are hearing is the board relay sending power to the ignitor. The ignitor has to draw so many amps to open the gas valve. The oven is pilotless. Catriver..post back.
Posted on Apr 21, 2007
Krazytech
  • 725 Answers
SOURCE: Oven not lighting
Hi The gas valve will not open until the ignitor pulls enough amps around 3.2 . so from the infromation you wroke you may need a new ignitor..let me know what you can find out..
Posted on Sep 03, 2007
  • 1015 Answers
SOURCE: My oven won't heat
First you will need to verify if the igniter is coming on for the oven burner when the oven is turned on. You will need to remove the oven bottom cover. There is usually two screws at the back bottom of the oven compartment that holds the bottom on. If there are no screws then it should just lift out. You may need to slide the bottom away from you then lift from the back. You will need to remove the oven racks to make enough room to lif the bottom out. Once removed you should be able to see the burner(you may also need to remove a heat spreader on the burner). Now turn on the oven and watch for the hot surface igniter to start to glow. If it does then you will need to make sure the gas orfice and venturri for the burner are not plugged with debris. You can use a small can of compressed air to try and dislodge any debris. Then give the oven gas valve a light tap with a screwdriver or a wrench. Oven gas valve is usually located at the bottom of the oven. Remove the bottom storage compartment to reach it. If you tap it and the burner comes on there may have just been debris in the valve and you may have cleared it. Then turn the oven off and back on completely several times. If the burner comes back on you should be ok if it does not then it could be a weak hot surface igniter or a bad olven gas control valve. Now going back to the start if the igniter does not come on you will need to verify if the igniter is getting voltage. If it is then test the igniter with a ohm meter. The reading should usually be between 500 to 700 ohms. A common problem with hot surface igniters is that they will crack. Examine the igniter for any visible cracks. If the igniter is not getting voltage then you will need to verify that all wires are properly connected and none have come loose. Look for any melted wires from the self cleaning process. You may need to dis-assemble the back of the range to see if any wires have come loose or melted. Now I need to stress to you that safety is important. Be very careful performing these procedures. You can get shocked or possible burned.
Posted on Oct 06, 2009
  • 447 Answers
SOURCE: bought used ge spectra range had to change the
Did you hear a "pop" or smell like something was burning? Sounds like old oven could have been 3 phase, and you new oven single phase, Check the power requirements for oven and see what kind of power you are supplying it with.
Posted on Apr 01, 2010
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
GE Model J S968S0F4SS. During bake display goes bake, oven turns off.
Oven Does Not Heat, But The Burners Heat - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
Range - Oven Does Not Heat, But The Burners Heat. To minimize the ... Turn yourrange OFF and either remove the fuses or turn the breaker OFF. Then unplug ...
How To Fix Oven With Little or No Heat When Baking ...
Troubleshooting Why Your Oven Won't Heat ' PartSelect ...
? 2:54
https://www.youtube.com/watch?v=ketJHf3rrSk
Sep 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your oven may not be heatingproperly. ... Neither the bake or broil elements ..
Oct 31, 2015 | GE Kitchen Ranges
The touch pad on my Jenn Air Model JES9800BAF does not work. The clock does not display either. All four burners operate normally.
All burners work fine, clock display is blank, if the oven isn't working either, your display / control board is shorted out
Nov 13, 2009 | Jenn-Air JES9800BA Electric Range
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Burners and oven wont get hot and light wont come on
The input power is incorrect. The neutral connection may be missing
May 22, 2008 | GE Profile JTP18 Electric Single Oven
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-air slide in range/convection
I put a $.12 capacitor on the display board and the display came back. capacitor in position c3, part from mouser electronics, #746-uvy1v680med
Dec 19, 2007 | Kitchen Ranges
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
GE Profile JB968SHSS Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
