Question about 10 10 Computer 1000 ft. Stranded Wire Patch Cable (4PRL5ENGRN)
COLOUR COMBITION OF WIRE
I AM NOT GETTING THE RIGHT COMBITION OF COLOUR WIRE. I MEAN WHAT IS THE SEIRAL NO. OF WIRE.WHICH COLOUR WIRE WILL COME ON 1ST NO.
  • Anonymous Mar 12, 2009
    color combination of stp cable
  • Howard Lester May 11, 2010
    iS THIS CAT5 cable?
  • 112 Answers
Posted on Dec 15, 2008
Have a 1988 Chevy Cheyene p?u with a Am radio in it now. Want to install a factory AM/FM radio. AM has a solid wire going to radio. How do I hook up AM/FM with clip?
Following are colour codes for your radio curtesy of;
Source(s): GM dealer tech over 30 years. HyperGforce
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
The solid wire (casing) would enclose a number of thinner wires that may or may not include these colour codes.
You have to match up the wires and their functions in your new radio with these colour coded wires, have fun..........
Oct 16, 2017 | Car Audio & Video
Lambda sensor signal wire
If u mean bypass as in putting a new wire in, I'd be in plugging the Ecu connector and lambda sensor then running a simple test to make sure u got the right wire , a four wire lambda is 2 heater wires usually the same colour which when on is positive 1 5v Ecu feed and a earth
Jun 27, 2015 | 2003 Chrysler Voyager
I have taken the defrost thermostat off and there is no way of adjusting the thermostat. However I can tell it has been taken off before and has been wired with the brown wire to the orange and the orange...
hi tom.(DEFROST THERMOSTAT).u mean temperature thermostat and NOT defrost timer right?well if it it's def/timer then same colour to colour.if temp/stat with 2 wires only then it makes no difference.have a go.good luck.ALI
Jul 09, 2012 | Maytag Refrigerators
Dont know what colour wiring is what
what do you mean by what colour wiring, different speaker headsets are different but basic wire colour if it helps red or brown is the live and blue or black is the neutral
Jan 30, 2011 | Car Audio & Video
My 110 chinese atv starts and idles ok most times, but when throttling up it misses and wont pull itself. I've changed plug, checked plug wires, fuel is ok. Any ideas???
There might be a problem in a air combition chamber and air filter just check it and clean it with the proper tool like bush for air filter and petrol kerosene disel or oil for air fuel combition chamber. Now your bike will smooth up on throttling up.
Jun 04, 2010 | RTO 110cc Basic Manual ATV # ATD-125C
1995 Isuzu Rodeo 4X4 3.2 5 speed manual, reverse lights on in 1st
the wiring on the gear box is connected to switches wrong, there bullet head connectors red to red wiring and blue to blue from switch to loom is correct
both wires on one switch are red connect these to the 2 red wires one has colour trace on it also. the other switch blue wires to blue wire on loom with possibly another colour wire but they are together. you cant go wrong the connectors are male on one wire and female on the other on each switch(detent switch)
Nov 22, 2009 | Isuzu Rodeo Cars & Trucks
Safety 1st Video baby monitor - replacement wires?
I would suggest that you contact the manufacturers (Dorel UK), the link is below:
http://www.dorel.co.uk/safety-1st/
Sep 14, 2009 | Safety 1st Two Ways Tandem 01-668 Twin...
Wire colour coding for radio Holden Nova LF
Car Radio Constant 12v+ Wire: Blue/Yellow
Car Radio Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Aug 30, 2009 | 1994 Toyota Corolla
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
JVC 48WP55
The 1st step is to determine if this is a problem with the vcr or your tv/monitor. Does the problem occur when the vcr is plugged into ANY tv or monitor?
Have you tried a different input? For example, if you now use the S video input on your TV, try the video input (RCA jacks), or the RF input (coax cable input).
Please reply in order to continue the troubleshooting process.
Oct 17, 2007 | JVC HR-S9500 S-VHS VCR
10 10 Computer 1000 ft. Stranded Wire Patch Cable (4PRL5ENGRN) Logo
160 people viewed this question
Top 10 10 Computer Computers & Internet Experts
Reg Varney
Reg Varney
Level 1 Expert
Tony
Are you a 10 10 Computer Computer and Internet Expert? Answer questions, earn points and help others
