Question about Frigidaire PLGC30S9EC Stainless Steel Gas Cooktop
Need to know part nos. of gas burners and blackcaps, PLEC36S9ECA
I have a brand new Cooktop . one of the small burners and its
black cap is missing due to to bad factory packing. To order the right one i need the part numbers
of all the burners and caps for PLEC36SECA
Chella Kundanmal
    Novelist:
  • 222 Answers
Try to bring the small part wen the place the burner cup(black cap) in the store wat brand u have also use other brand but bring it to put it in actual.
Posted on Dec 02, 2008
I have a very old Magic Chef gas cooktop. One of the burners lost full strength. I cleaned out the pinholes on the stem but this didn't help. Do you have any suggestions?
Have you had a spillover? Lift the burner cap the round thing on top of the burner then pull out the burner you might see a small hexagonal brass thing with a hole in the centre if it's blocked clean it with some acetone/ nail polish remover.
Apr 04, 2014 | Magic Chef CGC2430 Gas Cooktop
Adjust flame
Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
My smeg cooker is brand new! after cleaning it - one of the rings will not ignite properly, it clicks so gas is coming through but no flame! any sugestions?
Brand new means you have a warranty, get the service agent to check.
I have found that you can easily place the wrong burner cap on the incorrect burner ring(the smaller burner caps).
Could also be dirt or water in burner ring or the burner jet(use needle to clear jet).
Are sparks coming from all ignitors? You might have damaged the spark plug.
May 01, 2010 | Smeg 23 in. SE64 Gas Cooktop
Thermador Vent Gas Cooktop Model GGCV36 Serial # 89020071
Just google the repair clinic and partselect,they are selling spare parts online..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Thermador SGS36GS Gas Cooktop
Dacor 46 inch 6 burner cooktop
The cost of the parts you want t o replace will usually exceed the price of a new cooktop.
Jun 08, 2008 | Dacor Preference SGM466 Gas Cooktop
Cooktop burner problem
Your plumber should know that the pipe service your cooker must be of a suitable size. Normal half inch pipe is only good for a couple of small burners. Most installations require one inch! There is a simple formulae for working out the flow rate of the gas. Your gas installer will know it.
Apr 18, 2017 | Cooktops
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Kenmore 32099 Cooktop burners regulation
remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Jul 25, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
Gas not igniting
aknot, make sure each burner cap has a good ground to the burner. You can use some light sandpaper to scrub them. Where the burner fits around the ignitor is a small orfice. Use a paper clip or small sharp object to clean out the orfice. Try this first. Catriver..post back.
Mar 19, 2007 | GE 36 in. Profile JGP963 Stainless Steel...
Frigidaire PLGC30S9EC Stainless Steel Gas Cooktop Logo
146 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
