Question about Magellan MAESTRO 3100 98083401 GPS Device
Magellan GPS RoadMate 4250 Will Not Hold Charge
I have a RoadMate 4250 that is less than a year old. The problem I am having is the inability to turn on the device once it has been disconnected from a dedicated power source. I have tried fully charging the device with the AC adapter as well as with the car charger. The device works and can be used when plugged in. If the device is unplugged from the car charger, for example, and you select "no" when the prompt asks whether you want to continue in battery mode, it cannot be turned on again using the power button. The device is in excellent condition, is always stored inside and has not been dropped. Any suggestions as to a remedy that does NOT include sending it back to Magellan would be greatly appreciated.
  • cablekulli Dec 05, 2008
    Mine won't even stay on using the car charger.
  • Anonymous Feb 01, 2009
    Top Expert:
  • Magellan Master
  • 24,739 Answers
Send it back to the manufacturer under warranty for repair/replacement.
Posted on Mar 26, 2017
  • 50 Answers
SOURCE: GPS freezes when I need it to work!
i have a 800 also but it does not freeze because i make sure it is up to date on all firmware and software,if i was you chk out for updates on the magellan website2.gif after you register your unit then if ther is, which i know do the update and you will have no problems after that.let me know how it goes.
Posted on Jan 06, 2008
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
  • 4 Answers
SOURCE: Magellan Maestro 4250
I just called Magellan.....1-800-707-9971. I got my 4250 for Christmas 2007 and never did register it. We did that over the phone and then he gave me a repair order and an address to send the unit to them. It will be fixed under only cost is the UPS or FED EX shipping. He said I will have it back in 7 to 10 days. OUTSTANDING service.
Mine was stuck on the blue screen.......and the pin reset did nothing. of luck to you all......and I highly suggest calling Magellan.
Judy in Arizona
Posted on Aug 23, 2008
  • 54 Answers
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Posted on Mar 10, 2009
  • 5 Answers
I got the touch screen from ebay, with search key word "4250 digitizer".
Posted on Aug 22, 2009
My magellan Roadmate 5220-LM powers on but will not go past the first screen. I have tried to use the reset button but it still will not work
Hello Liz, You may have two problems. If your unit is several years old, the battery may need to be replaced. First charge the battery overnight. To get the screen unfrozen , you need to remove the screws on the back, open the case, and unplug the white battery connection . Reconnect the battery connection after a few seconds. If this works, it is usually a temporary fix . Either your battery does not hold a charge or your charger connection is poor at best and can not deliver a full charge to the battery. It could be both.
Mar 17, 2014 | Magellan RoadMate 5220-LM GPS Vehicle...
Will not hold battery charge
If the battery is one to three years old, chances are it will need to be replaced, the fact it will not hold a charge is a sign the rechargeable battery needs to be changed.
Mar 26, 2011 | Magellan Roadmate 1200 Car GPS Receiver
Turn on get a screen saying magellan thats it
  • Check if the unit is fully charged. Because if the unit is not charge you will just stay in the magellan logo.
  • If the unit is full charge and still stay in the Magellan logo find the reset button and press and hold the reset button for 15 seconds while its on and then release.
  • If still the same thats the time need to call the technicall support hotline of magellan if they can repair it free of charge.
  • If you need clarification feel free to reply to this solution.
Jun 12, 2010 | Magellan Maestro 4250 GPS
Can I charge my Magellan roadmate with USB cable connected to the computer?
It depends on the Roadmate that you have. :
- If your Roadmate has a separate plug-in port for charging your unit IN ADDITION TO a USB port, then no, your Roadmate cannot be charged using your computer via the USB cable.
- If your Roadmate only has a USB port available for charging your unit, then yes, you can charge it via your computer via USB.
However, please note, according to Magellan, charging your unit using your PC via USB can take up to 12 hours to charge vs. 4-6 hours when using the vehicle power adapter.
FYI: This is mainly due to USB constraints on pretty much all electronic devices. USB cannot carry the same amount of power to a device. It uses what is commonly known as a 'trickle' charge to recharge a device. It carries much less current than a full-blown charger (like an AC power adapter).
Apr 18, 2010 | Magellan RoadMate 1340 GPS Receiver
Magellan Roadmate 2000 will not charge
charge it up for a few hours, then hold the power button for a few secounds till it starts. if that fails, hit the hard rest on the side. it should start right up unless it has a proplem with the power port, which is a common problem on a lot of magellan...
Jun 30, 2009 | Magellan RoadMate 2000 GPS Receiver
Battery of Magellan Maestro 4250
Here is a link to some batteries.
A couple of screws out, to replace the battery, 10 minute job.
Hope this helps
Mar 16, 2009 | Magellan & RoadMate 1200 North America GPS...
I lost the ability to charge mine after the female piece of the adapter on the unit itself was worn after a year of use. The company has been clueless, and three attempts to urge them to simplify my efforts to fix this have all met with frustration. They suck at Magellan. I threw it in the trash and bought a Garmin.
Jan 04, 2008 | Magellan GPS 310 GPS Receiver
Magellan Roadmate 360 reset
Called Magellan tech support, According to them you can't delete previous addresses, the unit will just override old destinations as you put in new ones.
Dec 01, 2007 | Magellan RoadMate 360 GPS Receiver
Magellan MAESTRO 3100 98083401 GPS Device Logo
520 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
