TV is about 3 years old, I was told it was the LCD panel, need to verify and find the part. Thanks
Was the telvision impacted? Usually a Blue line on various tv sets such as Sharp and Sony can also indicate a firmware upgrade being needed. Try that first, as to a panel if this is a panel we have in stock cost could be between $200-400 for the part that part cost from Sony coulb be double if you need to purchase new. Call or reference us if you need TV repair in Colorado
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
SOURCE: My Bravia KDL-40S4100 lost all 3 of it's HDMI
There is a problem with the processor. The only way to resolve this issue is to replace the main board. It is called the A board in your TV.
There are two for this model and the correct one will depend on what your serial number is.
Part numbers are as follows:
part # 185709211 for Serial #
1,000,001 - 1,350,000
1,700,001 - 1,750,000
1,800,001 - 1,804,270
1,804,271 - 1,818,372
1,818,373 - 1,830,000
list price: $504.87 core charge: $680.00
part # 185709231 for all other serial numbers
list price: $505.87 core charge: $600.00
Testimonial: "Thanks, Now I wonder who all shares the same problem and if Sony is willing to do something about their defective products..."
SOURCE: Sony Bravia KDL - 40S4100 LCD
You do know that the screen alone will cost you approx. 75% or more of the price of a new TV don't you? Good luck !
Testimonial: "Probably just toss it if that is the case. Like to think I can find one for less though. I've found everything else I've wanted at fair price on line"
