Goodman GMN100-4 heater in horizontal position leaks condensation
This unit used to be in an upright position and worked fine. The unit in a horizontal position now leaks condensation from behind and below the exhaust fan. Is there a fix for this or something that has to be repositioned?
  • 1,420 Answers
There is another location on the fan housing that needs to be used when the system is mounted horizontally.
Posted on Nov 28, 2008
I installed my new unit this summer and the ac worked fine, now the heater does not work
frist check that the thermostat and the mood is in right positions then check that thermostat give signal to Htr.if Htr is right ohms
Nov 11, 2013 | Goodman Manufacturing Goodman...
Water is leaking from the evaporator pan beneath the coils down the inside heater wall and onto tje floor. The condensate pipe is clear. The pan is not accessible within the sheet metal box sitting above...
Hello, if the condensate pipe is clear then most likey the pan is cracked, onlynway to acsess thenpan is by opening up the plenum by cutting into it with sheet metal tools.
Aug 22, 2011 | Goodman Heating & Cooling
Window too small for a/c
Unfortunately you cannot mount this type of A/C vertically. The compressor must be in the upright position or it will be damaged and not function in a short period of time.
May 30, 2010 | Goldstar R5050 Air Conditioner
I woke up to a wet floor. The furnace is working well. It has a Hartell KT-15-1ul automatic condensate pump, could this pump have quit working?
Have you condensate pump checked for a leak in the
mechanical seal. The pump may still be working, I hope.
Have this checked ASAP.
Jan 04, 2010 | Goodman GMS90703BXA Heater
Leaking water
how long have you had the unit,, depending on where you live you might be using your ac in your house and if the installer didn't install the condensate catcher on the flu pipe then you wil have water runing out of the unit, if it is happening all the time then you would need to have a service tech come out that would meen something like the tank or a water line is broken,, but since you said it's coming from the side I would have to say it is condensation
Jun 04, 2009 | Goodman GMS90703BXA Heater
Goodman CACF048B2A Air. need to know the location of the replacement filter
The disposable filter is always in the return air of an a/c unit. If your unit has a furnace attached in an upright position then the filter is under the furance blower wheel. You will have to remove the bottom access panel to see and replace it. If your unit is horizontally installed in an attic then the filter will most likely be up in that return air duct or possibly in the return air grille possibly mounted in a hallway or someplace like that.
May 30, 2009 | Goodman CACF048B2A Air Conditioner
Circuit board fuse keeps poping
Traced wires and found the wires to the humidifer were the cuprits. I beleive the solenoid may be no good. After disconnecting the wires to the humidifier, A/C and Heat are working fine now .
May 28, 2009 | Goodman GMS807034ANA Heater
Condensation not draining properly and causing rust in cabinet.
Probably a bad gasket between the inducer housing and the secondary heat exchanger. They may be available from a goodman dealer.
Dec 14, 2008 | Goodman GMS90703BXA Heater
Condencing unit
Check filters to see if dirty, clean or replace. Is the coil or condensing unit iceing up? If so, have your system recharged and checked for leaks.
Jul 03, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
