Question about Jenn-Air M170 Microwave Oven
Microwave won't heat.
The touch control panel works, the clock keeps perfect time, but after punching in a time or control setting I hear a small click and then nothing happens. The oven will not cook. Do I just need to replace my microwave with a new one?! This one has been working faithfully for ten years.
  • Jenn-Air Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Dec 02, 2008
My microwave turns completely off... Touch pad and lights inside... I have to wait 10 seconds to 10 minutes and then it turns back on and will ask if you want to set the clock. Sometimes it will let me...
Hi Ben,
This has got to be an intermittent power to the control PCB problem. The control board asking to set the clock means that the CPU has been reset by losing power. First, make sure that the problem is not the outlet by plugging in a small lamp or digital clock to see if it works intermittently or resets. Leave it plugged in for at least 24 hours.
(If using a lamp, put in a small 20 watt light bulb or CFL).
It could also be a bad connection to or at the fuse holder in the microwave oven. If all of the wiring and connections look good, it's most likely a bad connection on the control PCB probably around the transformer on the board. Be careful.......
Oct 22, 2013 | KitchenAid KHMS2050SSS Microwave Oven
How do I change the time on a Kenwood microwave
Please follow the below mentioned steps to resolve the i
Press the "Clock" or "Time of Day" key on your Kenmore microwave's control panel.
Push the number keys to input the time. For example, "945" or "0945" equals "9:45" on the display. If you have a microwave with a 24-hour rather than 12-hour clock, also set the time of day: touch "Enter/Start" or "Start" on the panel and then push "1" for "AM" or "2" for "PM."
Touch "Clock" or "Time of Day" again, "Enter/Start" or just "Start" to save the setting.
Mar 13, 2011 | Kenwood Microwave Ovens
Sharp Microwave on "Lock" and
The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
Mar 08, 2011 | Microwave Ovens
Kenmore Microwave Oven, Model#66568680891
you should change the touch panel and or the control module.check to make sure the power supplied is correct and all connections to the board are all secure.
Feb 24, 2010 | Microwave Ovens
Touch screen not responsive. Can operate oven only by pressing one-minute button. Cannot set clock, change settings, etc.
try opening up the control panel,disconnect the connector ribbon coming from control panel and connected 2 control board by just pulling it out and cleaning end of connector ribbon and iserting it back.some times this works.if not then 4 sure touch panel needs to be replaced.
Aug 15, 2009 | Kenmore 63792 Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Viking microwave has digital lights but will not turn on to cook?
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
Jan 29, 2009 | Viking DMOC205SS Microwave Oven
Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
Aug 13, 2008 | Sharp R-420DK Microwave Oven
Microwave panasonic model nn 6358 about 10 years old
In most cases, you press Clock, enter the numbers for the time, then press Clock again, or possibly press Start.
Sometimes you have to press Clock, Clear numbers, then Clock or Start.
Or Clear, Clock, numbers, then Clock or Start.
In some older models, they had a very small mechanical clock button located at the top right corner of the controller near the display window. If yours has that, press it, then the numbers, then that button again or Start.
If this doesn't do it for you, could you post a clear photo of your control panel?
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 21, 2008 | Microwave Ovens
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Open Questions:
See all Jenn-Air M170 Microwave Oven Questions
Microwave Ovens Logo
183 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
