Question about Frigidaire Washing Machines
What is the capacity of the top load frigidaire washer FWS445RFS2? And if possible, other specs. Thanks.
  • PThakkar Nov 29, 2008
    I checked the online manuals as you mentioned - as well as couple of other websites. None of them specify the capacity.
    Thanks for trying.
    Best Regards.
    Sergeant:
    Champion:
  • 311 Answers
Should be in the manual or advertising info. Go to frigidaire.com and you should be able to find it. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
Capacity frigidaire fwt445ges2 load
Good Afternoon Friend,
I understand you want to know the capacity of your Frigidaire washer, model# FWT445GES2. After researching your model, I found that the capacity of your washer is 4.5 cubic feet. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire super capacity 2speed - 3/4 motor i
Good Afternoon Carlos, thank you for your post!
Based on the symptoms you are describing it sounds like something could possibly be lodged in the blower wheel or your laundry center has a failed motor. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Oct 13, 2013 | Frigidaire FEX831CS Top Load Stacked...
Pump dose not come on spin cyl fws445rfs2 top loader
Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Oct 07, 2012 | Frigidaire GLWS1233A Top Load Washer
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Frigidaire fws445rfs2 will not spin but agitates
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 24, 2011 | Washing Machines
I have top load washer, model #FWS445RFS2 that is leaking at the bottom where the motor mounts to the tub. Is this easily repaired?
this could be the main seal which would make this repair expensive, if it coming out the centre of rotor cap on the direct drive motor
Dec 21, 2010 | Frigidaire Washing Machines
Good afternoon! We have a Frigidaire top load washer, model # FWS445RFS2. The tub continuously fills with water and we must manually stop the washer and then turn the dial to spin & drain. It cannot...
Joe, remove panel to get access to outside of outer tub. You will see a "bell" with a soft 3/8 clear line coming from it. That is your water pressure hose and it goes to a switch in the control panel. Remove one side from the bell housing, outer tub, and check for gookus. Clean out all obstructions. If there isn't any obstruction in the line, you need a new pressure switch up in control panel. There is a small chance that there is something on the inside of the outer tub which is obstucting air bell but I don't see this very often. Hope this helps,
Rich
Western Appliance Repair
Appliance Repair Nampa
Oct 09, 2010 | Frigidaire FWS833A Top Load Washer
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
1,776 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
