Question about Yahoo Messenger
Yahoo messenger 81003005 problem
Hi..i had an issue with the yahoo messenger lately,i installed a new version 9.0 and im using a wi-fi access at home,when i tried to log-on it says error 81003005 and then i had a flight to another country upon arrival in the hotel i accessed the internet by a cable(using the same laptop)..and signed in the yahoo messenger,i was able to log in..but i think the same problem will occur at home when i use the wifi access..pls gve me some ideas on what to do..thank u
  • Anonymous Feb 17, 2009
    she is not connecting
  • 734 Answers
To get away from errors you need to use YM8.1
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either. Stick to 8.1 until they work out the Bugs. Including people using 8.1 trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it. http://www.ymessengerblog.com/blog/2008/...
Download 8.1 here;
Yahoo 8.1: http://www.soft32.com/download_30.html.....
Use this method: Start,My PC, C drive, open Program files.Next open Yahoo file then Messenger file.Click on UNWISE to Un install messenger 9 completely. Do not just delete yahoo file as this can cause problems with other Yahoo programs.
Your contacts list and messages are stored online and will be there when you return to 8.1 messenger.
Another big problem is with the latest update for Flash Player
Flash player 10 Does have conflicts,and 9's latest update 9.0.124.0 Can have conflicts with Yahoo(very rarely, if you are using it with no problems keep it) and is causing some Yahoo Messenger services to not load.Use the link below for a download of Flash player #9.0.115.0 It should work as it's the latest before 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel, then download the older version.
http://www.soft32.com/download_500.html....
More help can be found here; http://www.freecreed.com/userid.html...
3 weeks ago
Source(s):
Soft 32 is showing "errors" on the link. updated links;
Download 8.1 here http://www.filehippo.com/download_yahoo_...
http://www.adobe.com/support/flashplayer...
Posted on Nov 28, 2008
I try to sign in in yahoo messenger, but have sign in problem my account has been locked (81003003)
Hi, This is what yahoo had to say.
We released an updated version of Yahoo! Messenger 10.0.0.1270. This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code "81003005" when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, we recommend installing this latest version.
http://messenger.yahoo.com/download/win
(or)
Reset your password.
Nov 16, 2010 | Computers & Internet
Account has been blocked(81003003)
hi this is kamal This is what yahoo had to say. We released an updated version of Yahoo! Messenger 9.0 today (9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code ?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, we recommend installing this latest version. http://messenger.yahoo.com/download/win http://www.ymessengerblog.com/blog/ best regards kamal singh
Oct 09, 2009 | Yahoo Messenger
Messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
Jun 16, 2009 | Yahoo Messenger
I cannot sign in it tells me try aagin (81003004)
change ur yahoo version..try to use yahoo 9 or 9.1..evrything will b just alright..
May 12, 2009 | Yahoo Messenger
Error 81003005
[Solution #1]
Here's how I solve it:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
My solution is good only if you have set your proxy server previously in your Internet Explorer. I've noticed this behaviour since in our school, I need to set the proxy server to access the internet. But at home, I don't need to. So when I am at home, this is the normal situation I encounter when I forget to unset back the proxy settings.
On the other hand, the other way around should work. What I mean here is, if you connect to a network that has a proxy server, you need to setup the proxy settings in order for you to use their internet services. Thus, access to yahoo could be established.
[Solution #2]
One area to look also if the proxy is not the one causing the problem, you can check if you have your DNS Server address(es) set, which - in case you have changed your network, can't be accessible to the new network. Thus, it can cause this error.
So, you may unset the DNS Servers (Go to Network Properties >> General Tab >> TCP/IP Properties >> General Tab >  Obtain DNS Server address automatically) and try logging in your YM.
[Solution #3]
If the above solutions does not go well, this last one might be the savior. Instead of constantly banging your heads with those re-logins and reconfigurations, you can track back your YM version and replace it with an old version instead. I did this and it works for me well. I had before a version 9 Yahoo Messenger and when I replace it with a version 8, the problem was solved. This should be your last resort if the previous won't work. Remember also to be patient. If it bugs you, don't bug down... bug up!
source: http://www.stephenhaim.com/resources/yahoo-messenger-81003005-error
Feb 23, 2009 | Yahoo Messenger
81003005
try two things.
Go to internet options in your explorer. Go to Connections tab and click open lan settings make sure your proxy server is unchecked. than click ok and try again.
If not
this will work.
Uninstall messenger(i know pain in but), and download the new version http://messenger.yahoo.com/
save it instead of just running the program, install it and try it that way.
That is usually and update or proxy error.
Good Luck let me know.
Feb 15, 2009 | Yahoo Messenger
Yahoo messenger 81003005 error how do u fix it?
New 9.0 version: fix for sign-in issues February 5, 2009 on 1:32 pm | In 9.0 version | 32 Comments
emot_wink.jpgWe released an updated version of Yahoo! Messenger 9.0 today (9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code “81003005” when trying to sign in, this latest version should fix that problem. Even if you were experiencing a different kind of sign-in issue, we recommend installing this latest version.
Dec 19, 2008 | Yahoo Messenger
Yahoo 81003005 error
hi u
i had (or maybe have) this problem
but a solution that i found is :
you set a proxy in internet explorer ,
clear that with this steps:
and for this time , i solved problem, hope it works for you
Dec 01, 2008 | Yahoo Messenger
Signing in problem with messenger: 81003005
i have a problem error 81003005 how can i remove that error ?
SOLUTION
Make sure messenger is off, then go to start>run> regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
Sep 28, 2008 | Yahoo Messenger
Yahoo Messenger Logo
184 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
