Error 65 on imagerunner 105 - Office Equipment & Supplies
  • shglick Nov 28, 2008
    i cleared the error and turned off the copy machine and when i turned it back on it came back the error
    i wanna know what causes this error
    can you please explain me what the UFR Shutter inside the upper fuser roller is because i am not so familiar
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Canon error code "65" indicates probable fault at the Composite power board or the DC controller. this page might be of use to you.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 28, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    President:
  • 1,952 Answers
Error: 65 141 jtag.c:1444 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 0x00
Debug: 66 156 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
    Genius:
  • 1,239 Answers
Hi you should have firmware no,try it your problem will be solved,,
    Master:
  • 505 Answers
  • 734 Answers
Hey.. Thx for the quick reply. However, we found a more simple solution from another website. Fixya.com the tech spinal there suggested to go in service mode and reset the error, and see if it will solve the problem. If the problem presist, a code will appear and that will be the one we should work on. So we did clear the error, and the machine is functioning.
Entering service mode:
press Additional Function > press 2 & 8 at the same time > press Additional Function again
Clearing the Error:
press Copier > press Functions > press clear > press Err > press Ok.
Restarting the Machine:
Power off then On.
  • 2 more comments
  • futureloginn
    futureloginn Nov 28, 2008
    Workaround : In this case, the UFR Shutter inside the upper fuser roller was installed reversed (180 degrees out of postion). Installing the UFR Shutter in the proper orientation corrected the problem.
    Note: the UFR shutter installed in the reversed position will cause a noise and block the Main Thermistor when the shutter should block the Sub Thermistor. In turn, the shutter will block the Sub Thermistor when the shutter should block the Main thermistor. This will cause improper temperature for the Upper Fuser roller and cause the error code.
  • futureloginn
    Problem is in the upper fuser roller section of your machine.
  • futureloginn
    Need drum adjust, this may need to be adjusted, cleaned or replaced. Has to be done by a tech.
  • futureloginn
    Thanks
    Master:
  • 763 Answers
Sir can you pls give us some specific problem of your printer so that we can help you better. have you tried uninstalling and reinstalling the driver and software?
thank you for using fixya
CHARCOIS
Erro code e000086-0000
CANON IR 105 ERROR CODE E000086-0000
May 26, 2014 | Canon Imagerunner Ir 105 Copier Printer...
Canon ir 105
sir what solution error 69
Jan 29, 2014 | Canon imageRUNNER 105 Copier
Error e000111-000
laser colling fan drive signal
Feb 17, 2013 | Canon imageRUNNER 105 Copier
How do I print from my iPad to a Canon printer. I get a 105 error
hi what is the full name of your Canon printer?if anybody needs to see a list of airprint enabled printers which are ideal, they are here:
http://support.apple.com/kb/ht4356
no panic if not, you can still print from your ipad/iphone etc to a printer using a third party app. the one that seems particularly popular is print n share which i use. good luck
Jan 13, 2011 | Canon imageRUNNER 105 Printer
Where can i find pc drivers for canon ir 105
Go to www.canonusa.com and navigate to support and drivers. Then select your product and download what you need.
Apr 20, 2009 | Canon imageRUNNER 105 Copier
Printing speed slow
Try to run a clear server on your imagepass. (unless that is what you meant by clearing RAM)
You also may wish to restart the M3.
If you have a support contract, ask your dealer to upgrade or reinstall your fiery system software.
Mar 27, 2009 | Canon imageRUNNER 105 Copier
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
E000020-0010
Have you recently changed or added a new toner resently?? If so try to reinstall it or add a new toner. A E00020 is a toner desity problem. It may be a bad toner cartridge..
May 11, 2008 | Canon imageRUNNER 105 Copier
64 people viewed this question
jasbo
jasbo
