Problem for Sony VAIO PCV-RX753 PC Desktop
Cann't shut down properly
I have sony vaio vgn-sz34gp notebook. I fresh install all driver, but it can not shut down properly. if I disable camera driver. it can shut down. I check driver that is update version. and working properly. why?
Solution #1
posted on Nov 28, 2008
Rank: Wiz
Rating: 76%, 513 votes
un-install the camera drivers and install it again, if it works then ok, if not u may re-install windows.
Solution #2
Rank: Wiz
Rating: 83%, 109 votes
If you are trying to shut down with the camera still connected!!??GOTO the bottom right of screen and ""safely remove hardware"" see if the system will shut down.....sometimes a hardware driver does not want to shut down so you must turn it off and plug it in again when you start windows again....
Popular Solutions for Sony VAIO PCV-RX753 PC Desktop
Questions and Unsolved Problems for Sony VAIO PCV-RX753 PC Desktop
Do you recommend Sony VAIO PCV-RX753 PC Desktop?
i lost the code to my game
ibm keyboard model rt3200 parts breakdown part number 37l0888
buenas noches.¿podrian informarme. que caracteristicas necesita la tarjeta grafica? quiero...
(More)
buenas noches.¿podrian informarme. que caracteristicas necesita la tarjeta grafica? quiero instalar una tarjeta grafica buena en esta placa base: Les pongo 1º los datos de la placa base y a continuación los del ordenador. gracias. mod y caracteristicas de la placa: MF-845GV Motherboard MF-845GV/GE Motherboard Engineering Specifications MF-845GV/GE madre Ingeniería Especificaciones Product Name MF-845GV/GE MF-845GV/GE Nombre del producto Form Factor Customer Design Atención al cliente Factor de forma Diseño CPU Type Socket 478 (Intel Pentium 4 ) Tipo de CPU Socket 478 (Intel Pentium 4) CPU Voltage 1.1V~1.85V (VRM 9.0) CPU Voltage 1.1V ~ 1.85V (VRM 9.0) System Speed 1.30G~3.06GHz Velocidad Sistema 1.30G ~ 3,06 CPU Operating Frequency 400 MHz ( 100MHz x 4 ) /533MHz(133Hz x4) Frecuencia de operación de la CPU a 400 MHz (100 MHz x 4) / 533 (133Hz x4) Green /APM APM1.2 Verde / APM APM1.2 CPU Socket Socket 478 Zócalo de CPU Socket 478 Chipset Chipset Intel 845GV/GE Chipset Chipset Intel 845GV/GE GMCH: 82845G 760 PIN FC-BGA GMCH: 82845G 760 Pin FC-BGA ICH4: 82801DB 421 PIN BGA ICH4: 82801DB 421 BGA FWH FWH BIOS Award BIOS Support ACPI Function BIOS Award BIOS ACPI Función de apoyo Cache 128K/256K/512K Level 2 (CPU integrated) 128K/256K/512K caché de nivel 2 (CPU integrada) VGA 82845GV/GE built-in, AGP 4X,support CRT 82845GV/GE VGA integrada, AGP 4X, CRT apoyo LVDS & TV-out (option) Chrontel CH7017 LVDS y TV-out (opción) Chrontel CH7017 LAN Realtek 8100B LAN controller(10/100Mb) LAN Realtek 8100B controlador LAN (10/100 Mb) Audio ICH4 Built-in Sound controller + AC97 Codec STAC9750 (Line-out, Line-in, MIC.) ICH4 Audio integrado controlador de sonido AC97 codec STAC9750 (Line-out, Line-in, MIC). Memory type Tipo de memoria 2 x DDR 2.5V PC200/266/333 DDR SDRAM( without ECC Function) DIMM Module, Max. 2 x DDR 2.5V PC200/266/333 DDR SDRAM (sin ECC Function) Módulo DIMM, Max. capacity - 2GB Capacidad - 2GB LPC I/O Winbond W83627HF: IrDAx1 Parallel x1, COM1(RS-232),COM2(RS232/RS422/RS485), FDC 2.88MB/1.44MB,Hardware monitor(3 thermal inputs,6 voltage monitor inputs , VID0-4 , 1 chassis open detection ,3 Fan Header) LPC I / O Winbond W83627HF: IrDAx1 x1 Paralelo, COM1 (RS-232), COM2 (RS232/RS422/RS485), FDC 2.88MB/1.44MB, monitor de hardware (3 entradas térmica, 6 entradas de control de tensión, VID0-4, 1 de detección de chasis abierto, 3 Fan Header) Jumper selectable for +5V or + 12V at pin 9 of DB9 for COM 1 & 2 Jumper seleccionable para +5 V y + 12V en el pin 9 del DB9 para COM 1 & 2 Secondary I/O (option) Winbond W83627HF: COM3,4 (RS232) 2 x10 pin header ( 2 sets ) Secundaria I / O (opción) Winbond W83627HF: COM3, 4 (RS232) 2 x 10 pin header (2 juegos) Jumper selectable for +5V or + 12V at pin 9 of DB9 for COM 3 & 4 Jumper seleccionable para +5 V y + 12V en el pin 9 del DB9 para COM 3 y 4 RTC/CMOS ICH4 Built-in RTC / CMOS ICH4 Built-in Battery Lithium Battery Batería Batería de litio PS2 Keyboard/Mouse Controller Winbond W83627HF Built-in Teclado PS2 / Mouse Controlador Winbond W83627HF Built-in EPP/ECP Yes EPP / ECP Sí Local bus IDE ICH4 built-in ,IDE1,IDE2 (Ultra DMA 33/66/100) Local bus IDE ICH4 built-in, IDE1, IDE2 (Ultra DMA 33/66/100) Board Size Customer size Tamaño de la Junta de clientes de tamaño Power Connector ATX P4 type Conector de alimentación ATX de tipo P4 Expansion slots EISA slot for PCI & AGP Ranuras de expansión Ranura EISA para AGP y PCI USB (Universal Serial Bus) 4 ports ,USB Version 2.0, 2 ports in the front and 2 ports in the back side. USB (Universal Serial Bus) 4 puertos USB versión 2.0, 2 puertos en la parte frontal y 2 puertos en la parte trasera. IrDA (Infrared Ray) pin header ,This allows infrared wireless communication. IrDA (Infrared Ray) pin header, esto permite la comunicación inalámbrica por infrarrojos. Watchdog Timer ( optional ) Yes ( 256 segments : 0,1,2,...255 sec/min) Watchdog Timer (opcional) Sí (256 segmentos: 0,1,2, ... 255 seg / min) System Voltages +5V,+12V,-12V,5VSB,+3.3V Sistema de tensiones de +5 V, +12 V,-12V, 5VSB, +3,3 V Other Features Modem Wakeup, LAN Wakeup , Otras funciones de módem de despertador, LAN despertador, Operating Temperature 0¢XC~60¢XC (32¢XF~140¢XF) Temperatura de funcionamiento 0 ¢ XC ~ 60 ¢ XC (32 ¢ XF ~ 140 ¢ XF) Storage Temperature -20¢XC~80¢XC (-68¢XF~176¢XF) Temperatura de almacenamiento -20 ¢ XC ~ 80 ¢ XC (-68 ¢ XF ~ 176 ¢ XF) Relative Humidity 10%~90% (non-condensing ) Humedad relativa 10% ~ 90% (sin condensación) MTBF 70000 hours MTBF 70,000 horas ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- mod y caracteristicas del PC DATOS DEL ORDENADOR : Propiedades de la Placa Base Identificación de la Placa Base 06/11/2003-i845GE-W83627-6A69VTE9C-00 Nombre de la Placa Base Desconocido Propiedades del Bus principal Tipo de Bus Intel NetBurst Ancho de bus 64 bits Reloj real 133 MHz (QDR) Reloj efectivo 533 MHz Banda pasante 4267 Mb/seg Propiedades de la memoria del Bus Tipo de Bus DDR SDRAM Ancho de bus 64 bits Reloj real 100 MHz (DDR) Reloj efectivo 200 MHz Banda pasante 1600 Mb/seg Propiedades del chipset del Bus Tipo de Bus Intel Hub Interface Ancho de bus 8 bits Reloj real 67 MHz (QDR) Reloj efectivo 267 MHz Banda pasante 267 Mb/seg ------------------------------------------------- Propiedades de la CPU Tipo de procesador Intel Pentium 4A, 2800 MHz (5.25 x 533) Alias de la CPU Northwood, A80532 CPU Stepping D1 Velocidad de reloj original 2800 MHz Código de pista de caché L1 12K Instructions Datos de caché L1 8 KB Caché L2 512 KB (On-Die, ATC, Full-Speed) Información física sobre la CPU Forma del componente 478 Pin uPGA Tamaño del componente 3.50 cm x 3.50 cm Transistores 55 millón(es) Tecnología utilizada 6M, 0.13 um, CMOS, Cu, Low-K Tamaño interno 131 mm2 voltaje del núcleo 1.475 - 1.55 V Voltaje de entrada/salida 1.475 - 1.55 V Potencia típica 38.7 - 82 W (dependiendo de la velocidad de reloj) Potencia máxima 49 - 103 W (dependiendo de la velocidad de reloj) Fabricante del procesador Nombre de la empresa Intel Corporation Información sobre el producto http://www.intel.com/products/browse/processor.htm Uso de la CPU CPU nº1 0 % --------------------------------------------------------------------------- Ordenador Sistema operativo Microsoft Windows XP Professional Service Pack del Sistema Operativo Service Pack 3 Internet Explorer 7.0.5730.13 Nombre del sistema CA09E3AA44124E9 Nombre de usuario lochos Nombre de dominio CA09E3AA44124E9 Placa base Tipo de procesador Intel Pentium 4A, 2800 MHz (5.25 x 533) Nombre de la Placa Base Desconocido Chipset de la Placa Base Intel Brookdale-G i845G Memoria del Sistema 2039 MB (DDR SDRAM) Tipo de BIOS Award (06/11/03) Puerto de comunicación Puerto de comunicaciones (COM1) Puerto de comunicación Puerto de comunicaciones (COM2) Puerto de comunicación Puerto de impresora (LPT1) Monitor Tarjeta gráfica Intel(R) 82845G/GL/GE/PE/GV Graphics Controller (64 MB) Acelerador 3D Intel Extreme Graphics Monitor LG Flatron 795FT Plus (100016843009) Multimedia Tarjeta de sonido Intel Onboard AC'97 Audio Controller with STAC9750 Codec Almacenamiento Disquetera de 3 1/2 Unidad de disquete Disco duro Alliance Flash Disk USB Device Disco duro SAMSUNG SV0411N (40 GB, 5400 RPM, Ultra-ATA/133) Lector óptico HL-DT-ST DVD-ROM GDR8164B Particiones C: (NTFS) 38201 MB (9313 MB libre) Dispositivos de entrada Teclado Teclado estándar de 101/102 teclas o Microsoft Natural PS/2 Keyboard Ratón Mouse compatible PS/2 Red Dirección IP principal 127.0.0.1 Dirección MAC principal CC-01-80-02-24-02 Tarjeta de Red NIC Fast Ethernet PCI Familia RTL8139 de Realtek Dispositivos Impresora Adobe PDF Impresora Enviar a OneNote 2007 Dispositivos USB Dispositivo de almacenamiento masivo USB. Agradecido por su atención , gracias . lochos de coruña.
Wish to install Dragon 10, visual problems Have copy of Dell Dimension 8400 Desktop . Where do I...
(More)
Wish to install Dragon 10, visual problems Have copy of Dell Dimension 8400 Desktop . Where do I place microphone? Tried Microsoft, Speech to Text doesn't work.Tried it under lip section, and back.Can't get sound Help
zenith tv drovers ver. 3.0 pls search and send me id www.ravikant7722@yahoo.com
