The laptop doesn't boot up always.
Okay, so, in a short summary... The laptop boots up only sometimes. I switch on the AC power and it shows that the battery is charging. When I switch it on, it shows the HP logo and then goes black. Sometimes, it loads Windows and goes black. Sometimes it shows the pointer for a while after that before going black.
If I shut it down directly, it shows the options to start normally or repair. If I switch it off after booting Windows and going black, it shows the options for Safe Mode.
I have also noticed that the battery stops charging in this process, and the next time I restart the AC power, it shows it is charging. I noticed this problem and tried to remove the battery at startup. After that, it booted up quite correctly. Then I slid the battery in.
How to get rid of all this?
  • Anonymous Nov 28, 2008
    same problem
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Posted on Nov 28, 2008
I have a samsung R620 laptop but the laptop is not booting but the battery and ac adapter are working properly on the system because the battery light shows or indicate tha the battery adapter is okay but...
By pressing power button it is powering on or not if yeas the display light is comming or not? if yes then what is the bios error code please check. If not powering on then remove the battery plug in power adapter and press power button if not on then it is hardware problem go to service centre
Sep 13, 2017 | Samsung R620-64BR Laptop Computer
The laptop will not come on?
Try a hard reset. Sometimes it works and is always the first step to take. Remove the battery and the ac adapter plug from the laptop. Press and hold the power button for forty seconds. Install either the battery or ac adapter power and press the power button toattempt a boot into the OS.
Hope this helps. Shiboram
Sep 18, 2011 | Toshiba Satellite Pro 4600 Notebook
Dell inspiron m5030 wont boot up, ac adapter has green light then once it is pluged in light goes out.
Install the battery and ac adapter .Now press the power button to attempt a boot into the OS.
If that doesn't work then remove the hard disk to see if it gets past the splash screen and the BIOS whines that it can't find a boo-table OS. That would indicate a hard disk failure.
Also try to remove the memory module(s) from the DIMM slots and then reinstalling them. That reset the modules and cleans some oxidation off the module pins (if there is any)
Hope this helps.
Let me know if you need more information
Apr 26, 2011 | Dell Inspiron M5030 Laptop
Laptop won't switch on although blue power light on is showing power is getting to the machine
Check the power adaptor led is not flashing. Flashing Adaptor LED indicates fault with laptop charging circuit / powerboard
If it will not boot on battery, and you know the adaptor to be good, the issue lies with the motherboard.
Sometimes, removing the battery, and unplugging, pressing the power button and holding it for 30 secs, replacing the adaptor only will allow it to boot up, but this will only work if the motherboard is not damaged r the CPU fan has not failed.
Jan 27, 2011 | Toshiba Satellite P200-13Z Laptop AC Power...
Power switch will not power on the Laptop
power button switches are usually very reliable and very unlikely to fail. However, sometimes the button that presses on the switch can become stuck in the on position - if it is stuck in that position the mboard cannot boot - make sure it isn't stuck. next check the AC adapter is working and is capable of charging the main battery? Most laptops will not boot when just the AC adapter is connected, and the main battery must be capable of being charged to at least a minimal level and be charged to at least that level in order for the AC adapter to work to help boot the computer. hope this helps
Oct 26, 2010 | Gateway Computers & Internet
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
HP Pavillion DV8000 Laptop won't boot.
When your computer hardware appears to power up okay, but the Windows XP operating system won't boot properly, you have to begin a troubleshooting expedition that includes getting into the operating system, determining the problem, and then fixing it. To help you get started on this expedition, here are 10 things you can do when Windows XP won't boot.
Click here for more information
Nov 27, 2009 | HP Computers & Internet
I have IBM LAPTOP thinkpad T43 SERIES. it was working tiil yesteraday. Suddenly it turns switch off. I thought its the problem with AC adapter. I bought a new one. It shows it turn it on but its switch...
It's not necessarily hardware related, can you boot into Bios? If you can try to boot info safe mode, that's F8 for most PCs. I would suspect something with your motherboard drivers, then again it could just be your battery. Not all laptops will operate with the battery out, there is some kind of failsafe to prevent overheating in some, because without a battery the power supply can be fried sometimes.
Hope this helps
Dec 04, 2008 | IBM ThinkPad T40 2373 Notebook
D800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Nov 28, 2008 | Dell Latitude D600 Notebook
Nc6320 Laptop power
hello the first thing to make sure of is that the ac adaptor cable is not having any partial contacts ofany kind whereby power gets into the laptop irregularly.this could have adverse effect on the circuitry. it is not enough just checking the output of the ac adapter by a meter.try straighten the cable from the adapter and check the meter for voltage fluctuations. if the above is okay then the problem could be on board leve.
Aug 10, 2007 | HP Compaq nc6320 Notebook
Computers & Internet Logo
486 people viewed this question
David Payne
David Payne
