Question about Refrigerators
I have just bought a slightly used GE GDL2OKCSABS fridge, hooked up the icemaker and after almost 24 hours now... no ice. what do you think is the problem?
    Sergeant:
    Champion:
  • 311 Answers
Is I/M switch in the 'on' position? Is water pressure good at refrigerator connection? If so, call GE for free wty service.
Posted on Nov 28, 2008
Ice tray not filling
Open your freezer and remove the ice bin. You will see the mechanism and the tray that fills with water to make the cubes. On the left there should be a rocker switch that turns the ice maker on and off with a green light that tells you if its on or not, under the ice cobe tray there is a small paddle that should move, give it a wiggle. On the right you will see the wire for the ice maker, make sure that it is plugged in. Once the icemaker starts working (little green light comes on) you should have ice within 24 hours. You may need to remove the ice bin and a
small plastic louvered cover above it.
Hope this helps.
Jun 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
Ge fridge icemaker not working
Yes it could take ut to 12 hour or more for your refrigerator to stabilize. I takes 5 degrees in the freezer for ice production. Sea Breeze
Jul 25, 2009 | GE Refrigerators
My ice maker isn't making ice
the way the ice maker sits in the front of the freezer I personally think is not a good design.nice but not good.most every k.a. superba that had problem with icemaker that i have checked had a bad ice maker.replace the icemaker.but you may want to check all tubing connections from water valve to icemaker and make sure no break in line.most likely it is the ice maker.that ice maker is not a cheep one.good luck.
Mar 24, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer is almost always running....
If you look at the icemaker, you will see a metal wire which runs along the side of the unit. If you manually swing the wire arm up until it locks in place (about 90 degree swing from the normal straight down position) you will have turned the icemaker off. (Alternatively you can unplug the electrical plug from the icemaker which goes into the freezer wall.)
If the icemaker is not turned off, it will periodically cycle, which turns on the ice cube mode release heater during it's cycle, putting unnecessary heat into your freezer. You do not need to plug the ice maker supply line. This should be a Fix-Ya for your refrig.
Feb 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
New GE profile bottom freezer fridge intermittent buzzing
If the buzzing is a short (say 5 seconds) every once in a while, it sounds like the water is valve being energized. That would mean the icemaker is turned on and is cycling. Besides the noise, when it cycles it turns on the mold heater, which you do not need if not making ice, and thus is actually adding heat to your freezer, increasing operating cost. Just turn the icemaker off by flipping the toggle switch on the icemaker itself. It is a white switch near the bottom corner of the icemaker. Should be easy to spot.
Oct 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Ice maker/ Water Dispensor not working
ok try this for me and let me know how it works there is a water tank in the fridge and on installation you have to hold down the water for about 5mins to fill it up now the ice disp will be a separate issue hold my rating and let me know if your water flowes first
Jun 13, 2008 | Refrigerators
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
