Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Our dishwasher seems to be stuck in drain mode. My daughter put the wrong kind of soap in it. She accidently put Regular dish washing soap in rather than machine dish washing soap. We've got all the suds out. Seems to drain water just fine. However we cant seem to get it to add water. Does the soap have anything to do with it? Anything I can do from my end? Please Advise. Thanks
    Sergeant:
    Champion:
  • 311 Answers
Plastic base is full of water. Need to remove whole unit to access bottom and dry it out.
Posted on Nov 28, 2008
I accidently put dishwashing liquid soap in the dispenser. Now the water from the bottom of the dishwasher will not fully drain. I checked the filters, those are clean. Please help and Thank you.
In a small bowl, wash your hands in block soap. Tip the water into the dishwasher and it will kill the foam and bubbles.
If there are no bubbles in there, pull the machine out and undo the clips on the drain hose. Drain the machine into bucket or a deep dish. This should reset the water level switch.
Sep 21, 2015 | Kenmore Dishwashers
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
Extra suds due to liquid soap in the machine overflowing. How do I drain it?
This is strange. Are you using an electric dishwasher liquid soap, OR are you using a dish soap that you manually use to wash dishes?
REGULAR dish soap liquid that is not specifically made for dishwashers creates a foamy suds with lots of bubbles that will in fact bubble out of your dishwasher. on the other hand. Electric Dishwasher detergent will NOT create foamy suds with lots of bubbles.
Switch your soap. The next cycle any residue suds or soap will be gone as long as you use the proper liquid detergent. I would also recommend using a rinse agent which further helps break down and rinse off residue.
Mar 18, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Will not clear soap from machine, have to rinse multiple times
are you using regular dish-washing detergent....not liquid dish detergent like dawn....dawn and the like suds up tremendously....regular detergent is manufactured so it will not suds up.
does it drain completely? sometimes a blocked drain will keep enough soapy water in the basin that when the rinse cycle comes on it essentially throws soapy water back on the clean dishes.
hope this helps
Jan 21, 2010 | Haier ESD210 / ESD211 Built-in Dishwasher
Danby Dishwasher stuck in drain cycle after wrong soap use
There might be water in the overflow sensor. I unloaded the dishwasher and lifted the front so the dishwasher rested on its back. There's a narrow gray tube that runs down from the bottom right of the door. The tube runs into a white piece of plastic with some wires coming out of it. There is a rubber plug that covers a nipple on the plastic. Pull the rubber plug off. Mine was quite tight. Tip the dishwasher back onto its casters to drain the water from the overflow. Check to see if the dishwasher functions normally, then put the rubber plug back on.
Dec 10, 2009 | Danby DDW1805W Designer Series...
Put wrong soap in the SmatDispense container...
If you run it as is you will have a kitchen full of soapy water.
Take a pot or pan. Fill it with COLD water. Our it into the DW. Fillit to the regular water level, about 1 inch below the bottom rim.
Set the DW to a pump out setting and drain it.
You will have to repeat this several times to clear the soap out.
COLD water pump out. Cold water pump out etc.
Do not use HOT water. You will get instant suds and lots of them.
Mar 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
My bosch dishwasher gets stuck in wash mode. We have to turn the dial to move to the next cycle. When we check inside soap suds are built up on the bottom. We use less than a 1/2 of an Electrasol tablet,...
Have you checked it is draining properly? Partially-blocked drainage would likely be detected and cause the dishwasher to stop mid cycle, with soap suds left behind. I would check (1) the drain filters inside the dishwasher and (2) that the hose is not kinked (3) that all the S-bends etc where the dishwasher hose connects to the drain under the sink are clear.
Jan 30, 2018 | Dishwashers
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
223 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
