Question about Dell OptiPlex GX240 PC Desktop
Replaced dvdburner with older cd drive not coming up
Ok my optiplex 240 dvd drive kept getting stuck and my kids would hit the top and it would open any finally it wouldnt open any more so i took it out the disk inside was in a million pieces so i thought ill replace it with to old cd writer in the old compaq we had put away. anyway installation went fine no probs. but there is no d drive on the computer anymore ive tried add hardware but it says there isn;t any how do i get the cd drive to appear
  • 849 Answers
CHANGE THE JUMPER OF DRIVE (AT BEHIND THE DRIVE NEAR TO DATA CABLE) TO SLAVE. IDENTIFIED AS MA SL CA.
MA=MASTER
SL=SLAVE
CA=CABLE SELECT
GOOD DAY
RATE THE SOLUTION
Posted on Nov 28, 2008
Windows 7 has been installed in my optiplex gx 240 pc but this is no drivers for sound , lan drivers to fix the problem
Go to the Dell support site on another computer,and look for drivers for you computer model. Download them on a usb drive or on an SD card and install them on you Optiplex computer.
Sep 22, 2013 | NEC Black Nec/dell Optiplex Gx-150/240 Ide...
How can I use External USB DVD rom for Boot to dell optiplex GX260 series.
You have to change the boot settings in bios (hit F2 as you see the Dell Logo) and in the boot menu look for one that says boot from USB, or external CD drive, and move it to the top of the list so it will boot before the hard drive does.
Jul 23, 2011 | Dell OptiPlex GX260 PC Desktop
My PC won't start,I get DISC READ ERROR
If you can boot from a boo-table CD then you hard disk drive has a problem. To boot from a CD disk, power onyour computer and tap the key to bring you to the "One time bootmenu". Insert the CD into the top CD/DVD drive and then select "Boot fromCD/DVD" and hit key. Select the "Run the 32 Bit DellDiagnostics.
If all tests pass then reload OS ( Operating Software ).
Jul 04, 2011 | Dell OptiPlex GX270 PC Desktop
Well i just bought a dell optiplex gx620 (full tower) and im trying to install windows pro but every time i put the disk in the pc and turn it on it keeps saying that theres no bootable device...so i tryed...
From the info you supplied...
Boot (power off/on) and go into the BIOS (Usually hit F2 as it powers on and the white bar goes across the bottom for self test).
F2 will probably be listed as an option along the top (right). You only have a limited time to hit the key.
One of the menus should show what devices are connected (CD, hard drives). Make sure the system sees you're hard drive and CD-DVD. If the CD/DVD is not listed anywhere I would guess it is not installed correctly. I am not sure if the 620 will support an external USB C/DVD. This is another option and again, boot order would have to be changed.
Another menu has boot order. Make sure CD/DVD is at top of the list since you stated the drive is blank. I would make sure hard drive is second in the list. Save/Exit BIOS
Be CAREFUL MAKING any CHANGES to the BIOS.
Jan 11, 2011 | Dell OptiPlex GX280 PC Desktop
How do i replace dell optiplex 760 cd-rw/dvd
Here is the link to the service manual for your computer, since we do not know what formfactor the case is, go to the link, pick your case form and look through the manual for case opening instructions. Be sure to save a copy of the manual for yourself for a refernce.
http://support.dell.com/support/edocs/systems/op760/en/sm/index.htm
Oct 14, 2009 | Computers & Internet
CD is hung up in the player and does not come out with the tray
There are a few solutions:
1. hit it ok just kidding
make sure when you are trying to open it does not say "disc Lock" or some sort. You can solve this problem by hitting the device menu and typing in 2005
2. Open up the device by unscrewing the six case bolts and then the 4 dvd section screws. After this I had the problem where my dvd was stuck in the play mode so the tools would just not let go. I had to gently wiggle them apart however be very careful. I have also heard that it might be a tired arm on the side that just needs some coaxing. HOpe this helps
Mar 23, 2009 | Toshiba SD-3990 DVD Player
Internal CD ROM will Not Open
Unless you can do electronic repair yourself and have the schematics for the drive it will be far cheaper and easier for you to simply replace it. Any DVD drive for computers will fit in there. I would buy a new one rather than used so you make sure and get the software with it. Replacing the drive is a 30 minute job at most.
Dec 31, 2008 | Sony DVD-ROM DDU1615-ZB 16X IDE 512KB 100...
CDDVD RW drive won't open /won't burn CD
Drive is more than likely fried. It's not uncommon to have DVD/CDRW drives or any burning drive go bad especially if you use it frequently. Check www.newegg.com for a replacement they shouldn't be more than 30 dollars for a decent model now.
Jan 09, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX240 PC Desktop Logo
77 people viewed this question
Alun Cox
