Question about Canon PIXMA MP160 All-In-One InkJet Printer
Will not print
Printer acts like it is going to print and feeds paper through but will not print.
  • 385 Answers
Replace the cartridges!they r most likely clocked!
Posted on Nov 28, 2008
SOURCE: Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Posted on Apr 13, 2007
SOURCE: PRINTING PROBLEMS
i have had so much trouble with the epson stylis photo r1800... it doesn't feed right every so often and it is so frustrating. It seems to be with the rollers that pull the paper in, I don't think the rollers are pulling at the same strength and causes the paper to feed a bit off and the printer thinks that the paper is loaded incorrectly. Has this happened to anyone else and what can I do to make it work properly. This is also my third printer, Epson keeps sending me new ones when I conplain because they can't seem to help me...
Posted on Dec 18, 2007
  • 2072 Answers
SOURCE: Paper will not feed
What you need to do is remove the tray, and look for the feed rollers and clean them with either alcohol or a soapy cleaner like Fantastic.
Clean them a few times, make sure they are dry then try again.
That may solve it completely, or your rollers may be slick and need replaced.
When those rolls get dirty, it's like trying to drive on ice. You just slip. Also, if those rolls are needing replaced, I wouldn't be upset with the refurb work. Sometimes those rolls fake you out. They appear and to touch feel perfectly fine, but try and feed a piece of paper, and it just won't.
If you can, look into the paper tray with a flash light, and see if they are turning. If they are, then dirt or slick rolls is the only problem you have.
Posted on Mar 01, 2008
cabrooksjr
  • 13 Answers
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Posted on Jun 21, 2009
thbestofme
  • 64 Answers
SOURCE: printer wont feed paper through to print on
there are a lot of steps that u need to follow.. I tried to get the detailed link but it didnt seem to work properly.. so try this link below.. http://tinyurl.com/2kdp28 once on this page.. go to support & service.. and search for FEED PAPER... and select the second answer there.. and follow steps there.. let me know if this was helpful to u.. regards, guru
Posted on May 05, 2010
As soon as you press print it acts like it's going to work then the wheel makes a sound and it stops, like the wheel is locked up or something. It says printer error. Remove back access and unjam the...
That usually means that the paper feed rollers are not pushing the paper into the printer. Take a paper towel and some isopropyl alcohol and clean the rubber rollers were the paper is set and feed into the machine.
Aug 25, 2010 | Office Equipment & Supplies
Paper feed
Make sure your paper is not curved. Fan the paper and make sure it sits in the hopper evenly. Also make sure that when you were installing the printer you did not drop something or a piece of the packaging is not stuck in the side. Use a flash light to inspect the paper path
May 28, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Jun 21, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Paper doesn't always feed, and when it does, the paper rolls through without printing
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
May 16, 2009 | Epson Stylus Photo R1800 InkJet Printer
Printer is not feeding the paper through but acts as though it is printing
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-7
Apr 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My printer will feed paper, but no ink is printed..
i im  josh in cebu phils.may i help you? Friend the printer that prints and without ink appears even though not run out of supply. the problem is not the ink  but the tank lever that carries the cartridge.there maybe stuck dried ink on it came from previous ink installed that drain on the lever. Solutions: 1. try to remove all the ink and clean the lever with a soft cloth. 2. go to settings and perform the head cleaning and nozzle check. 3. do the printing repeatedly until the ink comes out. thats all friend good luck hope i helped you.
Mar 14, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Will not feed paper to print
Do a Mr. clean act on all rollers coming in contact with paper. I use distilled alcohol and cotton and it has worked for me.
Sep 06, 2017 | Dell 1700n Laser Printer
Since I changed ink in my pixma mp 600, paper gets stuck in both feeders. I can not get it to print.
Go here. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13800#SupportDetailAct
Click on the Service & Support tab. Type in the search window: Paper does not feed through printer. Click search. Typed in Red you'll see, "Paper does not feed through printer". Click this link & follow the instructions.
Jan 26, 2008 | Computers & Internet
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
