Question about Dell 0Y3740 Keyboard
I cant get the space bar on right - Dell 0Y3740 Keyboard
  • Biju Thomas May 11, 2010
    Space bar on right?
    Genius:
  • Dell Master
  • 1,102 Answers
Does it need cleaned
please give me more information
Posted on Feb 08, 2009
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
Acer Aspirre V5-572P-6646 laptop space bar doesn't respond as well as before
It may just need a clean underneath. You can remove the keys, but be careful if you do it because they can break if not done right.
Apr 26, 2014 | Acer Aspire Computers & Internet
When I hit the spacebar it jumps 2 spaces
Look closely at the space bar. try to lift it on the right side and on the left. The bar may have popped out of place. Specifically a metal rod that holds the space bar in place. Or the space bar is not resetting fast enough, ( soda, honey, something sticky) causing the bar to reset slowly.
Nov 01, 2013 | Lexmark Wheelwriter 10 Series II...
Right and left click do not work, space bar slow
Hi
As you said that the Right and left buttons are not working as well as the space bar, then it could be the issues with some dust particle inside the keyboard.
Try to clean it. Try to use it hope it will work , but in case it don't work then you need to replace the Keyboard.
In case if you have any more trouble do contact back in Fixya.
Thank you
Aug 11, 2012 | Sylvania Computers & Internet
How do I unlock right margin on a Swintec 7040 typewrite?
move your carriage to right margin by using "tab" or "space bar". then press "margin release" and using "space bar" locate carriage where you want right margin to be, then press "right margin".
razors
Nov 03, 2011 | Swintec 7040 Typewriter
I have a 2003 toyota highlander with a failed cv joint. I want to change the whole axle, but i cannot get the axle out of the transaxle.
Okay after you get the outter part of axel free with rotor off and everything ,,,you have to get a small pry bar or flat screw driver what ever works and pry the small hub right after the boot there should be a small space where you can fit the pry bar between the hub on axel and trans houseing and pry it out Im doing a hyundai right now and looking for that just right space to do the same thing,,also when inserting the new axel it will push right in and you will hear the click when in all the way, if you cant get it send me a pic of the axel inserted into trans,,,,,,,,thunderz@live.com Ill help you get it out.
Feb 22, 2011 | 2003 Toyota Highlander
My key board fell off and the space bar came off Itried puttingit back but it doesnt work
You can easily fix your space bar. I fixed mine last month when my daughter pulled it out of the keyboard. I used this video tutorial guide to help install the space bar key back into place. Its really very simple. have a look:
http://www.laptopkey.com/installation_guides.php
Oct 10, 2009 | Dell 0Y3740 Keyboard
Right Margin: I need to move the right margin.
Space bar to where the current right margin is. Press "margin release" key once. Space bar to where you want right margin to be. Press "margin right" once. This should work.
Aug 20, 2009 | Brother ML-100 Typewriter
Just got a new laptop - password requires a space - where is space bar? when i type all i see is .......... all dots - no space
the space bar is the long thin key on bottom of keyboard. when you type in a secure password its normal for it to show dots. this is done so a person cant stand close to you and see your password, so a space would show up as a dot like a letter would when you type in a pasword
Dec 10, 2008 | Toshiba Tecra A4 Notebook
Margins
Most electronic typewriters work the same way to change margin settings. You use the space bar to move to the desired location then press the right margin key. You should hear a beep. If you need to set it farther to the right of the current position, then use the space bar to move the carrier to the current position, once it stops moving then press margin release then space to the new position then press right margin key.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2008 | Brother EM-530 Typewriter
Dell 0Y3740 Keyboard Logo
46 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
