Question about Lexmark X1240 All-In-One InkJet Printer
Printer not printing all colors
My lexmark x1195 all in one printer had the ink cartridge refilled and now it will only print in blue. Sometimes you get a bit of yellow or red but then goes to blue.
  • lulusmum Nov 29, 2008
    I gave it a good clean out and have used it all day today so thats been great. i'll make sure they don't run dry again.
  • 51 Answers
You must buy a new cartridge, because refilledcartridges sometimes have problems like the one you report.
Posted on Nov 28, 2008
Blue and yellow not printing
Just make sure you are inserting genuine Lexmark cartridges. Lexmark does not recommend the use of refilled, remanufactured or clone cartridges, you might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try cleaning the cartridge nozzles using the Lexmark software installed on your computer instead:1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark 2600 Series folder.4. Select Lexmark Solution Center.5. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean it from dirt and possible clogs.
Should the problem continue, please contact Lexmark Technical Support Center to have your genuine cartridge replaced. They might ask for your receipt so have them ready. If you're not using genuine supplies, please replace your cartridges with original supplies.
Dec 27, 2011 | Lexmark X2670 All-In-One Printer
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Sep 24, 2011 | Lexmark Z1320 InkJet Printer
I have a Lexmark X4650 I refilled the cartridge and now I cannot get the printer to recognize the cartridge it prints black only and tells me Color is low . any suggestions on how to bypass this prob get...
I own a Cartridge World ink refilling store and I can't refill the Lexmark 36 and 37 cartridges. Your printer deactivates the electronics on this cartridge when the ink levels get low. Your printer needs a black and a color cartridge with functioning electronics to print. I NEVER recommend Lexmark printers. They are poorly made, don't accept refills easily, and have the most expensive ink across manufacturers and it is designed to clog your cartridge unless you use it quickly. If you keep this machine you are stuck buying Lexmark brand ink (the return program cartridges are a little cheaper though).
Dec 24, 2009 | Lexmark X4650 InkJet Printer
My Lexmark z22 printer will not print corretly
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 09, 2009 | Lexmark JetPrinter Z22 Color InkJet
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Color printing with green tint
Most probably your ink color RED and BLUE has run out. Refill/replace the color ink may help to solve your problem.
YBC (/\)
Nov 06, 2008 | Lexmark X2500 All-In-One Printer
Lexmark x1270 not printing in color
Is the cartridge a Lexmark cartridge or a refilled cartridge?
Remove the cartridge from the printer, take a damp paper towell and wipe the cartridge in one direction on the bottom. Is Ink coming out? If yes then put the cartridge back in the printer and try to print again. If the answer is no and the cartridge is brand new you need to return it to you point of sale and get a new one as its a bad cartridge.
If the cartridge is a refilled cartridge that is probably the problem. Lexmark printers do not support refilled cartridges.
Thanks
Catherine
Sep 08, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1195
I re-cleaned cups and wiper between cups with syringe and meth. spirits. Also realised that the cartridges that I had tried that hadn't printed could have melted the jets, so found an old one , filled it right up, then withdrew at least 2cc with refill kit tools. Prints fine now.
There was a lot of sticky ink residue on the wiper (what I assume the strip between the two rest cups is) that could have blocked jets.
Mar 13, 2008 | Lexmark X1195 All-In-One Printer
Cartridge problem
in most of the cases the refill will work for a few times then will not work one reason is because the ink gets dry inside the cartridge and second the contacts does not work when you uses that several times and the third the ink is not compatible with the printer no matter if that say for that kind of printer so if you wants to get that right get the new cartridge and end of the problem
Nov 03, 2007 | Lexmark Z600 InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
80 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
