Question about Fuji FinePix E550 Digital Camera
Adapter ring cover problem
Removed the adapter ring cover in order to mount an adapter tube and wide-angle lens. I'm finished with the wide-angle so I removed the adapter tube and attempted to re-install the adapter ring cover. It will not lock into place despite anything I try. Has anyone out there got a solution to this problem other than taking it to a repair shop? Thanks.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Maybe the adapter ring release button is stuck after you pushed it in to release the cover. Try giving it a good flicking until you are sure it has popped out.
Posted on Mar 24, 2008
SOURCE:
Vivitar screw mount lens, Nikon D-80 camera. Is there an adapter for this?
The M42 mount was used by several camera manufacturers, most notably Pentax. Nikon is not one of them.
Vivitar made many lenses with a T-mount. This consists of a screw mount on the lens and a suitable adapter, depending on the camera body. This allows a lens to be used with different cameras simply by changing the adapter.
If your lenses are T-mount, then yes, there are adapters available. One source is here.
Be aware that you'll probably lose any metering capability when using any lens with this adapter. You'll have to use a separate light meter or else view the resulting picture on the display and adjust the exposure appropriately.
Dec 22, 2011 | Nikon D80 Digital Camera
Hi, I bought a CANON FD - 28 mm f 2.8 WIDE ANGLE LENS for my OH's eos 400D, he says it doesnt fit, its too small. Is there an adapter or anything or should I just look for the right one? Many thanks
Canon FD lenses date back to before the mid 1980's. They use a totally different mounting system to the later EOS mount which was a redesign to suit the needs of auto-focussing.
Unfortunately they are chalk and cheese: you cannot realistically fit an FD lens to an EOS camera.
Your fix is to sell the lens and to buy one with an EOS mount.
Jul 20, 2011 | Canon FD 28mm f/2.8 Wide Angle Lens
I have 400 & 640mm Novoflex lenses latest type I wish to use on Hasselblad 201f (focalplane shutter). First, will these lenses cover the 6X6cm format? Second, what kind of adapter do I need and...
Yes they will. You need a Novoflex HAPRO adapter which can be ordered from your camera store. You may also need a new focus tube if your lens is set up for a 35mm camera as the flange focal length for 35mm is different then for your camera.
May 15, 2011 | Novoflex Hasselblad Lens Adapter Ring Lens...
I want to use PL filter with DMW-LW 55. Can I
No, there's always going to be a compromise.
In this case you'll find that having the wide-angle converter further from the lens will affect the angle of view a little, but the main effect will be vignetting. All you can do is try it and experiment with different aperture settings to minimise the effect. In any case, you'd be better off in every respect by mounting the DMW-LW55 directly to the adapter, and then mounting the adapter onto the filter. To do otherwise will lead to dreadful colour fringing as the adapter and wide angle converter lenses are optically matched and designed to be a particular distance apart.
Feb 26, 2010 | Panasonic DMW-LW55 0.7x (DMWLW55) Lens...
I want to add lens to my fujifilm s5600 to take better pics
There are lenses available to add with an adapter ring. I have the wide angle lens (which I LOVE) and a 2x telephoto lens. The wide angle lens allows me to macro from several feet away. It is an amazing lens. The telephoto lens is something you really need to use with a tripod. But yes, there are lenses you can add to your camera.
Dec 16, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Lens adapter mount cover is broken
having the same problem ...G5 can't get the original plastic ring to come off in order to change to a different lens...
Dec 08, 2008 | Canon PowerShot G5 Digital Camera
How to fis additional lens for canon power shot S1 IS
On the lower right side of the lens (as viewed from the rear) is a small button that releases the ring around the lens barrel. Removing the ring reveals a bayonet-style mounting flash that allows you to attach a lens adapter for extended telephoto, wide angle, or macro capabilities. Visit your photographic stockist for info on what is available
Apr 23, 2008 | Cameras
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
62 size
If you want to add other lenses, either macro, wide angle, telephoto or just filters, they go directly on the adapter. That's why the thread size (62mm) is important because that's the best fit for that adapter. If you get other sizes you can still use them with step rings but that adds to the expense and stepping down can cause vignetting. In case you were wondering, here is a link to the Phayee auction: http://cgi.ebay.com/... ...wItem&rd=1&item=3865219929&ssPageName=STRK:MEWA:IT
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Wide angle adapter
I wouldn't worry about the adapter. I'm going to try ordering a telephoto converter this weekend.
Sep 06, 2005 | Panasonic Lumix DMC-FZ1 Digital Camera
Fuji FinePix E550 Digital Camera Logo
69 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
