Question about Pioneer AVIC-F700BT Car GPS Receiver
MY PHONE MENU SCREEN IS DARK AND I CANT ACTIVATE MY PHONE SETTING
OR SYSTEM SETTINGS FOR THAT MATTER. YOU CAN SEE THE ICONS BUT I CANT OPEN THEM. WHAT SHOULD I DO?
  • rd62 May 11, 2010
    did you pair your phone with the radio?
The e-brake wire is required for these settings to be available. It has to be wired in as a safety measure. (So that the brake is engaged when you are fumbling with the settings, and not driving)
Posted on Jan 15, 2009
My screen very dark hard to read
Look for the "Contrast" setting in the Menu.
The PDF linked below is for a different model. But page 14, section 2.8 says
Contrast
You can adjust the screen's contrast from the CONTRAST-settings with the minus and plus icons.
Select the Menu icon from the screen and choose CONTRAST.
https://www.verifone.com/sites/default/files/VX680_Manual_English.pdf
Mar 19, 2018 | VeriFone Computers & Internet
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
I cant change my phone language from hindi to english
Menu-->settings-->phone settings-->language then choose english.
you could identify the above mentioned path by icons.
Note :
hindi equalent for phone setting and language- are
phone setting ---?₪«?₪¼?¥??₪¨ ?₪¸?¥??₪Ÿ?₪¿?₪??₪??¥?₪¸
language--?₪­?₪¾?₪·?₪¾
thank you
Nov 29, 2010 | Nokia 2690 Cell Phone
Screen dark and unresponsive to touch.
try to activate the touch screen option from your setting folders....if not....contact any phone technician to assit in repairing it...
Feb 23, 2010 | Apple iPod touch
Cant access Menu where the icons are on my KA08 mini iclone. Nothing happens when i push the button to try to go to where the icons are. I can recieve calls, but can make them since i cant get to dial...
take out the sim cards then turn the phone back on
click back and you will be in the menu screen
goto settings then sellect restore factory settings
default password is 1122 if thats wrong then 1234
it will say restore , press yes , the phone resets and its all fixed
hope this helps .
Dec 03, 2009 | Dual Electronics CECT P168 Cellular Phone
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
Only sign of apple is shown on the screen
restore your iphone using itune 8.2.then jailbreak and unlock
Jul 30, 2009 | Apple iPhone 3G
Please help, i cant activate use of my memory card on the lg viewty
If its a new card, have you formatted it in the phone? (go to Menu, Settings, Phone Settings, Memory Manager, External Memory then click on the Format button).
To activate its use, go to Menu, Settings, Phone Settings, Memory Manager, Primary Storage Setting and select External Memory.
Apr 16, 2009 | LG KU990 Viewty
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
Pioneer AVIC-F700BT Car GPS Receiver Logo
287 people viewed this question
Top Pioneer GPS Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
