Question about Sharp VL-PD3U Mini DV Digital Camcorder
Cant get my computer to play my recorded tapes
Hi, a few months back my comp had a restore done on it which wiped out all my stuff. I dont know how I go about getting the comp to recognise my camcorder. Would I have had a disc to install first? and if so can I get a replacement? Sorry to sound so stupid about this and would really like some help on this problem. I have a few tapes that i would like to put onto disc if this is possible. Thanks for your help I hope . Regards Piglet
0 characters
1 Points
My XHA1s records but won't play back any tapes unless you're in ff or rw. One of the tapes I had just loaded part of on my computer a few days ago with no issues. As far as I know no settings have been...
Sounds like the edge of the tape has been damaged. The edge of the tape has the speed encoded so the playback will know what speed to play the tape. Look at the edge of the tape for wrinkles. If present, throw away the tape so you won't use it for an important recording.
Sep 04, 2013 | Canon XH A1 Mini DV Digital Camcorder
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Hi! I have many 8mm and Hi8 camcorder tapes which have my kids' childhood recorded in them. Most of them have not been even played back once or twice. They are in good condition. My handycam doesn't work...
hi,wath i think that is the tape pathern on the camera is different from one to the other, and as
to be adjust and clean the head system,because the traking pulse as to be match for both camera
you will need to see a camera tech because it as to be made with an oscilloscope.
hope that will help you, thats all i can do from here
regrads Alan.
Dec 25, 2010 | Samsung Video Cameras
"menu" button not working-wont record or play back tapes
when the light flashes it means that there is an error definetly.
turn the menu button on off position first and remove the battery.
reinsert battery and turn on recording mode.
Try to remove the tape and reinsert it and see if the operating light is clear.
let me know if the functionality is restored.
Oct 05, 2008 | Panasonic NV-DS65 Mini DV Digital...
Tape shows last 5seconds of previous clip before recording next clip
I'm not familiar with your particular model, but many cameras of this type have a "quick review" function that allows you to see what was recorded for the last few seconds to verify that all is well. This is critical in broadcast situations where you only get one shot to get the video. This is a quick way to verify that all is working without having a blank gap in the recording caused by an inaccurate rew/play/stop/rec sequence.
Check the manual for this "review" function.
Aug 18, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Playback *stops* on tapes where I used Aux input to record
It could be that.. you generally want a timebase corrector to properly record from analog tape to some other medium. But maybe not. Most tape-based devices also include a tension sensor, to detect the end-of-tape. If you're using tapes that are too old, cheap, etc. it could be that you're seeing this triggered.
I recommend trying the same VHS recording with a good quality, fresh tape. If it's still kicking off, you at least know it's due to the camcorder having issues with sync or something on the tape. If it works, blame the old tapes.
It's probably camcorder dependent, but I have done tape restorations using Digital8 and DV equipment, and have never known a camcorder to cut itself off due to dropouts or other problems on the tape -- mine just play through. So I think it's at least possible that it's just the tape.
Jan 20, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
No picture during playback on LCD or TV from my Sony DCR-TRV255E
Just use good quality Video Head Cleaning Cassette. Video head is dirty/ clogged.
Feb 17, 2007 | Sony Handycam DCR-TRV255 Digital Camcorder
Tape will not play or record - flashing eject icon and beeping
Hi! I think the Switch Block is defective. May be you need a service manual as well. examine and let me know. We can help you on the parts and manuals at a reasonable cost. may be you can seom of them in this link.
Nov 28, 2006 | Sony Handycam DCR-TRV250E Digital...
Sharp VL-PD3U Mini DV Digital Camcorder Logo
15 people viewed this question
Top Sharp Video Cameras Experts
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
